I have a bfh5000 bionaire electric heater and it wont turn on and the red light blinks ???????
    Brigadier General:
  • 4,736 Answers
First turn the heater off using the On/Off switch. Then unplug the heater for 12 - 15 minutes. This will allow it time to reset itself if possible. Then plug the heater back in and turn it ON. If it didn't reset itself, check the receptacle its plugged in to to make sure that it's still working. If it's not, the circuit breaker for that receptacle has been tripped and will need to be reset in your home's circuit breaker panel. If the heater trips it again, there is a short somewhere in the wiring of the heater, which will have to be repaired.
Hope this helps you Troubleshoot the problem. Please let me know.
Posted on Mar 15, 2011
Bionaire heater sometimes turns on at very low intensity and just kind of chugs along as the yellow button flashes. It works fine just wondering why it does that
Amazon.com - Bionaire Heater with Rotating Grill ...
www.amazon.com > ... > Space Heaters
Amazon.com, Inc.Amazon.com - Bionaire Heater with Rotating Grill, BFH2242M-SM - Space ... The ultraquiet Bionaire® Heat Circulator with Rotating Grill circulates warm air ... High-intensity, sun-like warmth, Gentle heat, Medium intensity, whole room .... When temperature reaches what you have set it to, the heater turns off and sometimes.
Bionaire Office Heater with Worry Free Motion Sensor
www.amazon.com > ... > Heaters & Accessories
Amazon.com, Inc.
Rating: 4.4 - ‎71 reviews
Amazon.com - Bionaire Office Heater with Worry Free Motion Sensor - Space Heaters. ... Heat turns off after 30 minutes of no motion detected. ... If you place it under the desk, your feet will be very warm, but not so much the rest ... CONS: The High setting gets too hot sometimes, while the Low setting doesn't get hot enough.
Bionaire® Electric Fireplace Heater BEF6500-UM - Bionaire
www.bionaire.com/bionaire-site.../bionaire...heater/BEF6500-UM.html
The Bionaire® Electric Fireplace Heater provides the ambiance and warmth of a ...Flame Intensity; 12 Hour OFF Timer; Free Standing or Wall Mountable; 2 Heat .
Jan 30, 2016 | Bionaire Heating & Cooling
My Bionaire BCH9221um wont turn on.
You might want to open it up and check the thermal fuse. This is usually a small cylindrical device with a cone at one end and wire leads coming out of both ends. It opens permanently when it gets over a certain temperature, and sometimes will open prematurely. Check it for continuity with an Ohmmeter. If it is open, then it is the problem. You can usually read the temperature, or a part number on the side. Look it up on the web, or go to your local electronics parts store. You can get one for a buck or two. Replace it by crimping it on to the wires, do not attempt to solder it, as the heat will likely destroy it.
Good Luck.
Nov 26, 2014 | Bionaire BCH9221UM Ceramic Electric Heater
Bionaire bfh5000um just blinks when i try to turn it on?
Do you have the owners manual it should tell you
Try looking up the mfg with as search engine
www.bionaire.com/
Oct 19, 2013 | Bionaire BFH5000UM Electric Heater
Heater bionaire bch9224-cn no heat
The Bionaire BCH9224-CN is a ceramic space heater, one of apparently 4 related units. The 9224 is the tallest in the family and I also have the shorter BCH9212-CN. They are electric so I have no idea what all this talk about 'gas', 'pilot light' and 'flame' is. My 9224 failed in a way that seems quite common with Bionaire space heaters in general, namely, first the smell of burning electrical insulation, then a snap or pop accompanied by a flash of light out the lower side, and then no more heat. It is possible that the original questioner had this happen but wasn't around to witness it. Now it is possible that the failure is in the electrical control board but in my case (and in fact I'm betting for many or most of the Bionaire failures) it was a wire running to the ceramic heating block (element) that fried at the connection to the ceramic element. I would say it is very unlikely the failures of the Bionaires are in the ceramic heater blocks themselves, and in fact the 9224 and the 9212 (and I assume many or most of the other Bionaires) actually have two ceramic blocks/elements fastened together, one being used for the 750 watt heating and both for the 1500 watt heating. The central wire running to the blocks must support enough current (about 12.5 amps) for both of the blocks, whereas the wires to the individual blocks need half that (about 6.25 amps). In my 9224 unit the weak spot was clearly where the central, common wire was connected to the spade-like connector that was crimped onto the central, common tab of the ceramic block pair. At first I thought I'd just toss the thing but then I opened it up, did the autopsy and repaired it by replacing the 3 wires from the circuit board to the ceramic blocks with 14 gauge wire, and made the connection of the wires to the three soft metal (tin or tin alloy?) tabs of the ceramic blocks by carefully drilling holes in the tabs and bolting eye, crimp-type wire connectors to the tabs using small screws. Oddly enough I opened up the smaller unit (the BCH9212-CN) and it has the same ceramic element pair but no indication of burnt wires.
Jan 08, 2012 | Bionaire Heating & Cooling
I have an Bionaire BPH1520 Micathermic Electric heater which will not heat up. I turned it off after use and now will not heat up when switched on. Digital display still lights up? Is there an internal...
AUTO SAFETY SHUT OFF
The heater has a built in safety device which
will switch off the heater automatically in case
of accidental overheating. It can only resume
operation when the user has reset the unit. For the
BPH1520 (OH)will display in an overheat situation.
To reset the heater:
1. Unplug the heater and wait for 30 minutes
for the heater to cool down.
2. After the 30 minutes, plug the heater in
again and operate normally.
fOR FUTURE REFERENCE HERE IS A COPY OF THE OWNERS MANUAL
http://www.bionaireuk.co.uk/Manuals/MANUALS/BPH1520-UK_43_91313392.PDF
Jun 07, 2011 | Bionaire BPH1520 Micathermic Electric Wall...
I have the bionaire oil heater boh2513g. I placed a towel over it to dry and I think it's went into overheating safety mode because the three lights are flashing but the appliance wont come on. Is there...
Turn the Master switch to OFF and plug the heater and leave unplugged for 30 minutes, That should give it time to reset itself. If it doesn't work after that, it's probably fried.
Mar 15, 2011 | Bionaire BH3930 Oil Filled Radiator Heater
I have the Bioaire Air Heater - BH3930-U. It is working but all of the lights on the front of the heater are blinking?
This is probably due to the fact that its in aux. mode. Can you tell me which lights are blinking?
Jan 27, 2011 | Bionaire Heating & Cooling
Will not start up??
Same problem here. Opened it but everythng seemed intact. Red light flashes momentarily during initial plug in. Has power, oscillates but no fan rotation.
Nov 05, 2007 | Bionaire BAP1500-U Air Purifier
Heater won't turn on, the lights keep flashing.
HI There is a product recall for this particular model of heater, you can search the internet for details on how to get the item collected by Bionair and get a full refund, these are a fire risk.
Jan 03, 2007 | Bionaire BH3930 Oil Filled Radiator Heater
Heating & Cooling Logo
149 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
