Question about Bosch Nexxt 300 Series WFMC2201UC
The error code Sud is on, what does that mean? How do I fix it?
  • 33 Answers
That's because there was too much soap put into the machine . Try to run empty cycles ( 1 towel only , no soap) until the over sudsing is gone.
Posted on Mar 15, 2011
MHW6000XW LIST OF ERROR CODES AND WHAT THEY MEAN
F20 water only problem insufficient water supply open both hot and cold unclog hoses
F21 Drain problem clogged,frozen kinked
SUD excess sud using non he detergent or to much detergent
F22 front door lock door not closed properly
For these select poepwer/cancel twice to cancel cycle
Other f codes select power/cancel twice select drain& spin if youhave excess water
Jul 10, 2015 | Maytag MHW6000XW - MaximaTM...
He4t error sud and f2
Hi, "F02" is a Long Drain error code. This is an indication that you may have an obstruction somewhere in the drainage system somewhere. In most cases this means there is a clog in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean.
The "SUD" error code can often occur in conjunction with the "F02" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Jun 16, 2011 | Kenmore Elite 45986 Front Load Washer
I am getting a sud erroro code
This usually means that you have used an excess of detergent. Front loaders use less detergent as well as less water. Try running the machine without detergent to remove the over supply of detergent in the machine. You may have to physically remove the excess by hand at first. Hope this helps!
May 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code "SUD"
SUD error means there is to much soap being added, the washer will shut down, if it cents to much soap
Jan 12, 2010 | Kenmore Elite 45986 Front Load Washer
Spinning and draining does not work, F error or sometimes Sud
Sud means you using to much soap and the f code means soap is locking the drain pump up and wont allow unit to drain and spin.
Nov 22, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet Washer-error code "sud"
Just take off the bottom kickplate (3 screws on the bottom). You'll see the pump front and center. Twist the front face of the pum slowly to the left. All the trapped water will flow right out towards you. There could be a sock or some other debris there. Unclog, screw that faceplate back in and start it up.
Sep 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Error codes
I own a HE3 kenmore elite for 4 years now and the troubleshooting codes are: SUD When excessive suds are detected, a suds routine automatically starts. This causes the cycle to go longer to remove the excess suds. Reduce detergent amounts or use HE detergent. The F02 error I had with mine and it is a drain problem. Book says check the hose for kinks, clogged or is it more than 96 inches above the floor. On mine it was the fan pump on the forward motor that drains the washer. It was worn and not pushing out the water fast enough. You will hear a high pitched whine at the front bottom of the washer if this is bad. To reset the washer from the F02 error, select pause/cancel twice to cancel the cycle. Unplug washer or dissconnect power. good luck
Jul 07, 2007 | Kenmore 46462 Front Load Washer
Bosch Nexxt 300 Series WFMC2201UC Logo
421 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
