Question about Crosley Refrigerators
Need repair manual for crosley model cs24g6d. Small puttle of water leaking under freezer (right door)
SOURCE: leaking fridge
Its probably the defrost circuit either the heater or the timer
Posted on Oct 30, 2007
fridgetech
  • 473 Answers
SOURCE: Kitchenaid Superba 42 Refrigerator Leak under Freezer when Water Used from Door
Either the water filter isn't seated properly or there is a crack in the tubing or the water line isn't seated properly in the coupling behind the grill at the freezer door. Also, inspect for breakage in the line in this area as well (coupling area).
Posted on Dec 26, 2007
  • 1122 Answers
SOURCE: Kenmore elite refrigerator door leak
your drain in the bottom of freezer is clogged or frozen,use a hanger or if it is frozen use a hair dryer,thanks-mike
Posted on May 31, 2008
  • 400 Answers
SOURCE: There is a water leak inside the freezer
You need to remove the bottom two baskets, or more to make space. Using a hairdryer, defrost the back area. You should be able to locate a drain hole in the center below the freezer coils. This drain hole is connected on the outside to a drainpipe which has a p trap and often gets blocked up. You need to force water down the drain hole. You can use a turkey baster or similar type of plunger filled with water. Once you have cleared the blockage pour hot water till it runs freely. Hope this sorts your problem, don't forget to rate me.
Posted on Mar 11, 2009
  • 4 Answers
SOURCE: side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Posted on Apr 19, 2009
I have a small amount of water appearing on the floor, on the right side under the freezer drawer. I do not see any water under the fridg. I've also found ice in the freezer on the right side. What might...
It appears you may have a blocked or frozen defrost drain. As the repair involves a complete teardown of the freezer compartment, you may want to contact a qualified Samsung technician to make this inexpensive repair.
Jun 28, 2014 | Samsung RF265AA Bottom Freezer French Door...
Why is water leaking from front of bottom freezer?
Your refrigerator defrost on the average about every 8 hours so the water that accumulates during defrost has to go somewhere right? You have a defrost drain blockage.
We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! Not all blocke drains act the same when your refrigerator leaks so please ask should you have questions. Please provide the model number found around the fresh food section door frame. Kenmore model numbers look like this example=> 321.1234567 If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Jun 26, 2013 | Whirlpool Refrigerators
Crosley WCF16/W3 freezer
Insure you are getting good airflow. Check to see if t'stat is set right. Is it freezing at all. If not, you may be low on freon. There may be a small leak in the line. Are your door gaskets properly secure and seal well. If unit is 10-12 years or older, then consider replacing. This may be the beginning of the end.
Feb 14, 2013 | Crosley CFUM21LW Upright Freezer
My Crosley CS23B5 is leaking water out the front left (freezer side) sometimes lately. Why is it doing this now?
door is not shutting correctly, look for a bad door gasket or the door iasn;t sitting square in the fridge
Aug 10, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Water does not drain and freezes under freezer draw
I am sending a couple links for the LG manuals but that sounds to me that water is either overflowing into freezer compartment from the fresh food compartment or when the freezer goes into defrost the drain that carries the water out to a condensate pan below refrigerator (Location #105A) has either ice or sludge caught in the drain. Here is the=> LRFD22850 Exploded View then scroll to page 44 where you will see the location number 319A That will be the condensate/drip collection tray where the water from defrost should be going. If the drain location # 105A is the drain assembly, pipe Z coming from under your freezer drawers. Where you say you see the water pooling and freezing. And the Service manual Click Here=> LRFD22850 Service Manual I will try to make this simple but I must try to explain with photos and notes with other links=> Leaking Refrigerators Just What May Be Happening and here=> Leaking Refrigerators! This may take some detective work because as you see any place there is water there may be water flowing down to the area below freezer drawers so look for any water that may be coming even from the water filter area inside fresh food compartment.Even a slight lean will cause the water to pool up and freeze there and close the drain slowly. If you should need parts scroll to page 51 in your Service Manual and on left is the photo location and on right is the part number under the model LRFD22850 then enter the part numbers into search feature here=>
Repair Clinic or Sears Parts Direct Here is the new=> Adobe Reader X
I also will be here to answer any questions you may have, Thanks, Sea Breeze
Jun 05, 2011 | LG LRFD22850 Bottom Freezer Refrigerator...
I have a side by side Kenmore refrigerator model #363-9562510. Water leaks from the bottom right corner of the freezer door from a small round cut out hole. This is the door that has the ice and water...
couple of things to check if you have a dispenser on this model there is a hose that goes up into the bottom of the freezer door you need to remove bottom kick plate and take a look at this...also if no water from that hose and its actually coming from the door you could have a ruptured line in the door itself.... next make sure the water is not actually coming from the freezer compartment as the drain in the freezer could be clooged and leaking over on defrost mode and out door...
hope this helps good luck...
Jan 05, 2011 | Kenmore Refrigerators
Changed head gasket and engine lite and coolant light comes on and going through water
Is there a water puttle under your car is there a sign of some sort on were the water is coming from. It could be a number of things, it could be a freeze out plug leaking it could be the water pump leaking. What you need to do is put some cardboard or something under the car when you shut it off. Then keep an eye on where the drip or water leak is coming from.
Nov 02, 2010 | 1994 Ford Escort
Leaks water inside fridge when door is opened. Also leaks water under fridge when closed for long periods of time.
if this is a top mount freezer / the drain needs to be cleaned . it could be iced over or pluged with algi . hope this helps mm
Sep 01, 2010 | Crosley Refrigerators
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Need replacement freezer door for model Crosley WCK05W
are u sure thats the right model # ..can't bring nothing up on that model # Did u get it off a tag that said model#?
Sep 27, 2007 | Crosley WCK05W Compact Refrigerator
Refrigerators Logo
98 people viewed this question
Top Crosley Refrigerators Experts
Colin Stickland
Colin Stickland
fta777
ray gallant
Are you a Crosley Refrigerator Expert? Answer questions, earn points and help others
