Question about Samsung PCH521R 52" Rear Projection Television
I have a PCJ534RF Rear Projection TV which is HD ready. When using the DTV input with a blueRay 1080i the picture is distorted (pincushion effect). Is there any procedure to adjust the pincushion? Thanks
  • 1 more comment
  • nmolina505 Mar 15, 2011
    Thanks for you help, but unfortunately this does not solve my problem.
    I know how to hook up the DTV signal and I've been using the TV as such for a while. The problem is that the image is distorted due to pincushion. The pincushion is OK for the standard mode but gets "out of adjustment" when in DTV mode. When I bought the TV back in 1999 I couldn't check that because I did not have any HD device.
    I know that there are no pincushion adjustment through the menus, however I thought this might be possible by means of a an internal potentiometer. Do you have the schematic for this TV? I'm an electrical engineer and also a technician and fixed TV, VCRs, etc.. in the beginning of my career, so I'm familiar with this. The only thing is that I don't want to try any pot that I don't know the exact function. Also, I couldn't find any obvious adjustment for that.
    Best regards,
    Nilson
  • nmolina505 Mar 23, 2011
    Please, I know the basics. My question is very simple (for a technical person):
    How can I adjust the pincushion correction for the DTV mode in my TV?
    Thanks
  • nmolina505 Mar 29, 2011
    I downloaded the service manual for the correct model (PCJ534RF). It appears that in service mode I can adjust the pincushion (as well as many other parameters) in both HDTV modes (480p and 1080i) independently. I was able to do that in 480p but the issue is that I couldn't enter in the 1080i mode (I have a blueray player connected to the DTV input configured in mode 1080i). The procedure to enter in service mode is: turn-off TV, press mute then 1 then 8 then 2 then turn the TV ON. Theoretically if the unit is receiving a 1080i signal it should go to the 1080i service mode but this does not happen. Any ideas??
    I think I'm closer to solve theissue now. You are the only person that understood the problem so far and helped me by suggesting to get the service manual. Any additonal thought are appreciate.
    Best regards,
    Nilson
    Top Expert:
  • Samsung Master
  • 74,243 Answers
Hello
There is no other adjustments than convergence. It is used to rectify the spreading of colours and not for pincushion. If you see pincusion effect with1080i only, it should be its internal card problem. Normally this type of fault occurs to video card, and should be replaced as card basis. No repairable parts inside it or cannot be repaire by normal soldering methods. As far as all other resolutions are OK, fault occurs only for this resolution indicates and confirms it. If so, the work should be done by a well experience service personal, as it is a very very skilled work, and after it, the technician have to enter its servcie mode and have to make several adjustments; all of them are critical. He should gave a good qquality pattern genereator also, besideds all other service tools.
If you are aware in electronics and have experience, you can do this. Without these, never attempt to rectify this fault by yoursef. It will go worse. OK.
Posted on Mar 23, 2011
  • Samsung Master
  • 11,800 Answers
The pincushion can be adjusted from the service menu , but this is a general setting, it will apply on all inputs. If you have problem just on the DTV then the deflection circuits are not strong enough to apply the correction when high frequency is used - you will have to check them and identify and replace the aged components.
Where are they and how to test them can be found in the service manual, which you can get from here
http://www.free-service-manuals.com/Television/Samsung_Televisions/Samsung_PCH521R_Service_Manual_L67351/
Posted on Mar 15, 2011
  • Samsung Master
  • 2,098 Answers
Hi nmolina505,
Your unit is capable of receiving DTV 480p and 1080i format and will automatically configured by the system when switching to DTV mode. Make sure that the cable connected to y,Pb, and Pr video output of set-top box are properly attached to your unit. Double check the connections and your cable wires. There is no such pincushion adjustment in your set-up menu.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
How do I change settings from 480i to 1080p?
Set the unit to DTV input (this uses YG,PyR,PbB) . then in customer menu go to advance features, SD video format & change from 480i to 1080i. There is no 1080p
Feb 15, 2015 | Mitsubishi WS-65809 65" Rear Projection...
How do i get rid of purple horizontal distortion lines?
This is a older model and likely the first generation of HD set made by Mitsubishi---where the HD input is on rear (DTV?) ARE THERE TWO JACKS MARKED H sync and V sync?
If they are there set needed an external box made only by Mitsubishi for for later HD use.
Apr 12, 2012 | Mitsubishi VS-60111 60" Rear Projection...
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
I have a 2002 Mitsubishi Medallion TV. The only input for HD is DTV (no DVI or HDMI inputs). Is there a converter box from HDMI to DTV that will allow for 1080i resolution?
From looking at the back panel of the TV, the DTV input can be configured as a component video. The M-Link/DVI-HD port is also a DVI with HDCP port and maximum signal handled is 1080i. The M-Link should work with an HDMI to DVI cable or adapter. For this to work, the source must not be a computer or another device using the default computer video output (computers give RGB output). The DTV port would need an HDMI to Component video converter. See this page for some examples: http://www.hdtvsupply.com/hdtocoad.html . The first one in the list (for Netflix and Boxee among others) will give 1080i out if the source is set correctly.
Most DVI-HDMI cables are single link. I've seen some examples where DVI-I (single link) and DVI-D (dual link) cables are not interchangeable. If you have video problems, check your cable. An HDMI to DVI adapters will let you run an HDMI cable up to the TV and then converter at the TV as a separate connection.
I hope this helps.
Nov 17, 2010 | Mitsubishi WS-65613 65" Rear Projection...
If we have an hd-ready television and we have dishnetwork hd does their box make our tv hd? Or do we have to have their magical piece of equipment to make our television hd?or tv is the WS-55315 model.
You need a HD box connected to the DTV input on the back of the set (it is marked 1080) This set has only one HD input for this---HD ready means it will work only with a box (some newer sets have a HD tuner built into them and for basic HD channels do not need a box).
SD TECH
Jul 11, 2010 | Mitsubishi WS-55315 55" Rear Projection...
I have a Sharp Aquos LC-30HV4U which is supposedly HD ready. I am a Dish Network satellite subscriber. I do not know what to do to make this HD ready set receive HD signals.
Your reciver is already set for the hd. Alls satellite programing and cable already come in hd format. You can also get any info here.
http://www.dtv.gov/
Good luck and please rate FixYa!
Apr 07, 2009 | Televison & Video
Mitsubishi WS-65315 plug in HD comp shows as 480i
Greetings,
In the input assignment menu make sure that the DTV (the only 1080 input on this tv) is set to Y/Pb/Pr and see if that fixes your issue with at least the HD-DVR.
BTW- the HDMI information "1080i HD can only be selected if TV has HDMI inputs". is not correct.
Feb 25, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Mitsubishi WS-65869 tv
You should have everything you need. I really don't think you have to order anything. Make sure you have whatever set top box you are hooking up to TV on the correct mode or setting... 1080i 720P 480P 480i etc....If you have any other questions... email me back or hopefully this was enough to get you up and running. Good luck and Happy Holidays....Jay
Dec 28, 2007 | Mitsubishi WS-65311 65" Rear Projection...
No HD 1080i
have you got the slider switch at high definition and not TV at the connecting end at the xbox that leads to the tv input
May 21, 2007 | Mitsubishi WS-73411 73" Rear Projection...
Samsung PCH521R 52" Rear Projection Television Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
