Question about Coleman Powermate Proforce 6,000 Watt 12 Hp Portable Generator #PM0106000
I have a coleman 6000. It runs for a whileand when I load it up it trips off.
    Sergeant:
  • 259 Answers
Make sure the governor is working properly. When you put a load on it the engine should increase in speed slightly. Make sure the engine is running at the correct speed 3600 rpm. Try plugging in an item that draws less power such as a electric drill and see how the generator behaves. Also make sure the engine runs smooth while not under any load. Check the voltage from the outlet to make sure it is putting out 132 volts not under load.
Posted on Mar 15, 2011
Have a coleman powermate 6750 generator that has quit producing power.
If the engine is running with the alternator not outputting then you must check with the LOAD TRIP switch.
if not remove the load and check if there is output. If not there is fault in tha alternator which might need some consensus.
Nov 05, 2011 | Coleman Powermate Powermate 5000W...
Coleman electric 4 hp compressor was running and stopped will no
ok maybe a fuse blown or an overload switch tripped somewhere on the motor casing will be the overload have a look buddy get back to me with results
Oct 09, 2009 | Coleman Air Tools & Compressors
NO AC OUT
hello sir/mam
please visit the manufacturers website there you will get it.
Oct 08, 2009 | Coleman Powermate Powermate 5000W...
We have a rooftop coleman air conditioner on our RV. When it runs it trips water on the counter top instead of draining on the roof. I don't know how to fix it
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Apr 20, 2009 | Coleman Heating & Cooling
Coleman Powermate only puts out 110V
If you haven't seen it yet, here is a page that may help with a manual or parts list.
This problem sounds kind of bad, generators don't do well when the engine stops under load.
Start by checking the circuit breakers in the distribution box (outlet panel) - you need ot do this with an ohm meter. After that check the power windings of the stator with the ohm meter, be sure to check between the 2 windings (should be open), and from each one to ground with the winding isolated.
Whining, a burning varnish smell, and breakers that trip all the time are indicators of long term overload problems. This could happen if you had most of the load on one winding for a significant amount of time, or if the one winding mostly powered motor-like loads with high startup currents.
You may want to look at this answer I posted some time ago.
Regards,
Carl
Jan 06, 2009 | Coleman Powermate Powermate 5000W...
Replacing eletric portion of Coleman PMA525500
my voltage meter shows 300volts instead of 230-240 and continues to trip generator breaker. What is my problem?
Sep 06, 2008 | Coleman Powermate Powermate 5000W...
Coleman airconditioner
Try testing the capacitor (there may be 2 ) If the start windings can't kick out it will blow the breaker.
Jun 23, 2008 | Coleman Mach 15 Air Conditioner
Coleman Powermate Proforce 6,000 Watt 12 Hp Portable Generator #PM0106000 Logo
161 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
