Question about Dryers
My dryer is working and heating but it's taking more time than usual to drye the clothe
  • 10,865 Answers
Hello vic.... when it takes longer to dry the clothes check the vent pipe and the outdoor vent for lint buildup! Joe
Posted on Mar 14, 2011
How I cant start my gas dryer
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Feb 02, 2015 | Kenmore Dryers
Whirlpol dryer intermittently dryes clothes. dryer p/n LGR8620PWO I do see the glow plug glowing put no flame.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 17, 2011 | Whirlpool Dryers
It takes longer to dry your clothes you have to restart the drye
first clean the pip from the unit to the outsde vent.
then inside your unit there are 2 felts that need to be cahnge, over time they go bad and the heat run out the drum and you can feel the hood is hot but it still not to good . it will save you electric bill when you fix it. :)
Dec 31, 2009 | Whirlpool LER4634J Electric Dryer
Dryer heat cuts out after 10 min. please help tested thermostats and element. cleaned out lint where eve i could. what else could it be
Pull the dryer out , and remove the vent hose from the dryer . Dry a load of clothes , and see it it dryes in a suitable time . If so , then a vent problem , either kinked hose , outside vent blockage , or if an up vent thru the attic , then possibly blocked . A dryer either heats or doesn't , and excessive time , indicates a venting problem .
Nov 20, 2009 | Whirlpool Dryers
Whirlpool dryer doesnt dry clothes
If the dryer heats , dry a load without the duct on . If it dryes fine , then problem still with vent somewhere .
Jul 19, 2009 | Whirlpool LER4634J Electric Dryer
Dryer not heating up to max
99 out of 100 services calls i did with your complanit its the venting.to elimanate that as a possiable you dry a load with out venting[it wont hurt a thing]if dryes then,venting.if not ither your washer is not spining enough water out of clothes or the air passage ways in your dryer are restricted.ther is only one element if it heats ,its fine.could be electronic but most of time no.check it out.God bless,tom
Jan 03, 2009 | Whirlpool Dryers
Dryer heats up but does not dry clothes
first take the venting off the back of the dryer and dry a load if dryes normal replace venting if takes a long time to dry have a repair man clean the dryer
Jun 12, 2008 | Kenmore 74602 Gas Dryer
CLOTHES DRYER (ELECTRIC) HAS HEAT AND TUMBLES BUT CLOTHES ARE NOT GETTING DRY.
DISCONNECT THE EXHAUST FROM THE BACK OF THE DRYER. RUN ONE LOAD OF LAUNDRY. IF THE LOAD DRIES O.K., THE EXHAUST DUCT IS RESTRICTED. CLEAN OUT THE DUCT WORK. IF IT IS FLEXIBLE MATERIAL, REPLACE WITH RIGID METAL DUCT WORK.
Apr 22, 2008 | Dryers
Dryers Logo
57 people viewed this question
Top Dryers Experts
