Question about Maytag Ovens
What does sag mean on display of maytag oven?
Maytag cwe4800acb oven shuts off and display goes blank during heating
Display on maytag oven 8114p471-60 went blank - Fixya
www.fixya.com/.../t16018814-display_maytag_oven_8114p471_60_we...
Jan 20, 2013 - Stove top electric ignition still works fine, so there is power going to the .... maytag cwe4800acb oven shuts off and display goes blank during .
Oct 10, 2015 | Maytag CWE4800ACB 2.6 cu. ft. 24" Single...
How do I fix my Maytag Performa oven displaying an F3 code?
Free Online Oven Repair Manuals
Appears the the oven temperature sensor is bad and needs to be replaced.
Aug 03, 2014 | Maytag Ovens
White maytag gas and broiler wall oven is flashing F 7, what does it mean?
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Mar 12, 2011 | Maytag 24" Built-In Single Gas Wall Oven -...
Oven beeps and display read "F3". what does this mean?
Hi dpaulthomas,
The F3 fault code description is a shorted or open oven temperature sensor. The easiest way to resolve this error is to check the sensor harness and harness connection between oven sensor and oven control. If you noticed that the wiring is all ok, replace the oven temperature sensor (RTD).
Hope it helps.
Thank you for using FixYa.
Aug 31, 2010 | Maytag 24" Built-In Single Gas Wall Oven -...
LCD displays trouble code F1 alternating with F7. Serial # is MEW6627BAB
Hi
Thanks for using FixYa. Error F1 in your Maytag Electric Double oven means that the control panel has gone bad and to resolve this issue it should be replaced. Unfortunately there is no other way it can be resolved. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 25, 2010 | Maytag MEW6627B Electric Double Oven
RECEIVING A F2 ERROR CODE ON DISPLAY SCREEN. CAN ANYONE TELL ME WHAT THE CODE MEANS AND HOW TO FIX THE PROBLEM?
the oven has had a high temp the temp sensor will need to be replaced , cost about $75 but if you look around you can find it for much less
Apr 25, 2010 | Maytag CWE4800A Electric Single Oven
Oven shuts off after being on for short period of time and f3 or f2 code appears. also the display sometimes goes off and on model # che9830bcb ser # 24430972qw
F3 error code usually means a faulty oven temperature sensor, a fairly easy part to replace.
However, with an intermittent display problem as well this could mean a bad connection or relay in the oven control unit, which a bit more complicated.
Jan 19, 2010 | Maytag Ovens
Maytag double oven is locked and won't open
Hi. Has a fault code been displayed and a continuous beeps? press and hold the cancel & cook & hold buttons together for about 3seconds then door should open.
Hope this helps.
David
Sep 13, 2017 | Maytag MEW6630D Stainless Steel Electric...
F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
thank u
rate me!!!
Aug 14, 2009 | Maytag Ovens
Readout is stuck on 5Ab. Can't do anything with it
Hi.
I am publishing this tip because of the many users asking me about the code 5AB on Amana, Maytag and other ovens.
Error 5AB in fact does not exist , and what you see written on display isnot 5AB.
The beeping sound is a warning because the oven is in lock condition. The oven is not faulty, and the code is not 5AB, but SAB.
SAB means that the oven is in Sabbath mode, and the control board will be locked for 72 hours with SAB on display.
If power is disconnected a new 72 hours cycle will start.
Depending on the model, there may also be a beeping sound when you try to operate the oven.
Push and hold the Clock button for about 10 seconds, until the display clears, that will reset SAB mode.
If that does not work leave the oven connected and off for 72 hours. If the oven does not unlock after three days, then the electronic control may be stuck in SAB mode because it is faulty, in that case contact the manufacturer at the number listed on the owners manual.
Regards.
Jul 09, 2009 | Maytag MEW6530D Electric Single Oven
Ovens Logo
Top Maytag Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
