Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
I have a craftsmand rider model number 917.276641 and i can't find the fuse.
What is Lil riders phone number
KB901 Lil' Rider FX 3 Wheel Battery Powered Bike ...
? 8:05
https://www.youtube.com/watch?v=fED8N8DTQfU
Oct 21, 2013 - Uploaded by TMKGL
Step by step instructions for quick and easy assembly of your KB901 Lil' Rider FX 3 Wheel Battery Powered ...
Lil' Rider Repair Questions, Solutions and Tips... - Fixya
www.fixya.com > Forum
Dec 14, 2015 | Lil' Rider Black 80-Kb901K Fx Wheel...
I'm looking for all the model numbers of all pants by Riders passion
I think that it will be best if you'll go to their website http://www.ridersbylee.com/
you can see all the models and sizes they have inclusing model numbers
Feb 16, 2014 | Riders Passion by Lee - Womens Core...
Harley Davidson 2006 FXDLI Dyna Low Rider fuse box
Hi Anonymous, on a Dyna all fuses, circuit breakers, relays, and modules will be behind the left side panel cover secured by grommets, four nuts or screws. On later models the electrical panel bracket cover secured by four nuts or screws must also be removed to gain access to electrical components. Good luck and have nice day.
Jun 11, 2012 | 2006 Harley Davidson FXDLI Dyna Low Rider
I have a 2005 dyna low rider and not sure which exact model it is. how do i tell
Here is a site that supposedly you can put your VIN number in and it'll tell you what it is. Or, you can do a search for "Harley Alphabet" or "Harley VIN numbers" to find several sites. Use the number stamped on your frame, not the engine number for identification purposes.
Good Luck
Steve
Sep 03, 2011 | 2000 Harley Davidson FXDL Dyna Low Rider
Have a craftsmand 24" snowthrower
If the motor runs well, the two most common causes of this are the drive belt is worn and/or the shear pins are broke.
If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belts.
Your operator's manual will show you how to remove the cover and check/change the belts.
If you don't have a copy you can get the manual through managemyhome.com
You will need the model number off the snowblower. It is usually located on the bottom right hand corner of the frame (from the handle side)
The model number looks like 247.123456.
The belt closest to the blower assembly drives the auger/blower and the belt closest to the engine drives the transmission. It sounds like you need to inspect the blower belt.
With the engine not running, have someone depress the drive lever and check the belt.
You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced.
On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt) It may be torn and broke completely.
Replace the belt if it is worn, stretched or frayed
The shear pins are located on the auger in the front of the machine. Your newer Craftsman has four. If you don't now about them look in your operator's manual for the location. You need all four for the snowblower to work well. Replace the missing ones.
You can get parts for you Craftsman and most MTD made models through searspartsdirect.com. With other makes you can get parts through jackssmallengines.com
If you are unfamiliar with repairing machines you can get your snow blower repaired by taking it to your local Sears.
They will have a technician troubleshoot and repair the unit.
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Craftsman Garden
Fuse box on 02 low rider
Hi Strange7daze, on a Dyna all fuses, circuit breakers, relays, and modules will be behind the left side panel cover secured by grommets, four nuts or screws. On later models the electrical panel bracket cover secured by four nuts or screws must also be removed to gain access to electrical components. Good luck and have nice day.
Jun 14, 2010 | 2002 Harley Davidson FXDL Dyna Low Rider
I need an instructional manual for Dovetailing Jig by Craftsmand Model D>09 MY>2570
try this site: www.managemyhome.com
or
http://www.searspartsdirect.com
Nov 30, 2009 | Craftsman Saws
Need a wiring diagram for a Murry Rider, Model # 30575X8A.
Go to this web sight and enter your model number of your Murray.
http://www.murray.com/manuals/
Jul 17, 2009 | Mtd Garden
Craftsmand garage door opener
you should be able to go to the manufacturers website and download the manual. good luck! countrycurt0
Aug 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
41 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
