Question about Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
I have a Kenmore glasstop.....everything was working then I shut off one burner and turned on another......everything seems fine except nothing gets hot.....not even the oven.
  • 2 more comments
  • Larry Trisch
    Larry Trisch Mar 15, 2011
    Would that keep the top burners from heating?
  • Larry Trisch
    I found PLT083-2 on the oven door
  • Larry Trisch
    Serial is 4Z170449Q
    Model is 911.9534190
  • Larry Trisch
    Larry Trisch Mar 17, 2011
    Was a bad connection between the cord and the supply box
  • 4,323 Answers
Hi
This means a loose/broken wire on the oven temp sensor or the sensor is bad and should be replaced. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then that then check the control and door switch and replace the part that is bad. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 14, 2011
  • 2 more comments
  • Daniel Scott
    Daniel Scott Mar 15, 2011
    Please post back with its model no
  • Daniel Scott
    Thats the serial no
  • Daniel Scott
    Thanks for the model no....after checking its parts in these diagrams...it can either be the thermostat (located inside the control), the sensor or the door lock assembly. You can test the thermostat first for continuity and then the sensor and then door switch. The part that is bad should be replaced
  • Daniel Scott
    Daniel Scott Mar 17, 2011
    Alright...good its resolved
Our glass top range quit last night. The breaker threw and when reset, it snaps. All 4 burners, lights, etc not working.
any electrician knows that besides a short activating a breaker , items such as leaking insulation , moisture , or control unit problems will trip a breaker
so get in an electrician to test everything
Jul 05, 2017 | Dryers
Kenmore glasstop Model C970-46400-2 both rear burners will not heat and pilot lights do not come on? How can I fix it? ??
This link automatically downloads a PDF that might provide a solution for your issue:
Kenmore® Electric Range c.shld.net/assets/docs/spin_prod_892089512.pdf
Aug 01, 2016 | Kenmore Kitchen Ranges
Black spot on glasstop Kenmore stove
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Jul 23, 2009 | Cooktops
Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
How do you replace a burner switch on a Frigedaire Glasstop Stove
The repair on this stove will be relatively easy then. All you are going to have to do is pull out the stove from the wall and remove the upper part of the back panel where the burner switches are.
Remove the knob and take out the screws that hold the switch to that front panel. Then from there just match up the wires to the new switch off the old one.
This repair will turn out to be pretty cut and dry for you. If you have anymore questions please ask.
Thanks Again,
Bill
Jan 10, 2009 | Frigidaire FEF366DC Electric Kitchen Range
Glasstop stove chiped
Keep using the range if the glass is cracked all the way through it will appear quickly. Then the glass top will have to be replaced . There is no fix for the glass top. You might get lucky and nothing will happen.
Jan 05, 2009 | Whirlpool ED2FHEXN Side by Side...
Main burner will not turn off!
Burner control feel loose? Wheter it is or isnt that is probaly where your problem is..
Jan 20, 2008 | Kenmore 30 in. 42701 / 42702 / 42709...
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
95 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
