Question about Kenmore 24 in. 16039 Built-in Dishwasher
Dishwasher runs, but no water - Kenmore 24 in. 16039 Built-in Dishwasher
    Sniper:
  • 88 Answers
Hi. I will assume that by "running" you are referring to the pump motor turning on, but there is no water entering the unit. If you are really lucky, you may just have a stuck float switch actuator. Look for a mushroom style float in the tub basin, lift up gently and release it, you should hear a very light, but distinct clicking sound as the switch is released. If that sounds alright, move on.
I would check things out in this order.
1: Shut off water supply to the dishwasher and remove the bottom panel.
2: Disconnect water supply from inlet valve
3: Using a basin for the water, slowly turn the supply on and verify that you have a good water supply from the house plumbing. If so, continue.
4: Make sure the unit is off, or just have the door popped open, and disconnect the electrical supply from the inlet valve. With a meter set on VAC, turn the dishwasher on, and check for 120VAC between the two wires going to the inlet valve. Make sure to give it a minute, the control may not power the valve immediately. If 120 Volts are present, replace the fill valve. If not, you will want to verify good wire connections back to the control board, and to be sure, test the float switch for continuity. If that also checks out, replace the control board. Let me know what you find if you get a chance.
Posted on Mar 15, 2011
Dishwasher not working.... when i close the dishwasher and turn it on i can not hear any water running and there is a pool of water at the bottom that will not drain
Hello, How long has your dishwasher been do this? Have you washed dish's in it? Also, these German made dishwasher run on less than 2 1/2 gallons of water. These German manufactured dishwasher machines run really quite. Because of the German water conservancies laws. They limit the amount of water dishwasher and washing machine can use. Also, there is no storage hot water system in there homes, it on demand hot water. You can't hear the motor running and about the only thing one can hear is maybe the water washing the dishes.
Now, the water at the bottom of the dishwasher, if the drain isn't connected up under is the sink drain and trap area or the garbage disposable in the sink. but some place lower on the drain pipe. You will not have a spiffing effect on the the bottom of the dishwasher, it the same with washing machines. One the discharge pump starts sucking air, it will not drain the dishwasher. The siffen effect works if the water is below the outlet for the drain. Example: Home owner have the new washing running and continue fill with water. Why, because the drain pipe end is below the the bottom of the washing machine tub. It fill up with water and siffen action continues emptying the tube will it still filling. One heck of a water bill.
GB...stewbison
Aug 25, 2011 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Is the feed pipe a hot or cold feed?
Connect the dishwasher to the HOT water side. Although most dishwashers have a heating element to heat the water, they are normally installed this way to reduce the amount of time the heating element is on. This not only extends the life of the heating element, but also reduces the amount of electricity required to heat the water. Another helpful hint: Before you run the dishwasher, run the hot water tap until the water runs hot. This will fill the dishwasher with water that is already hot instead of the cold water that normally sits in the line after the hot water has not been run for a while. If you have questions, please let me know. I hope this helps you.
May 05, 2010 | Hotpoint 24 in. FDW60 Free-standing...
My dishwasher is not heating the water up just running cold
Try turning on the faucet by the dishwasher and let the water run until it gets hot. Once this is done turn on the dishwasher and see if the water is warm or hot. Most dishwashers do not heat the water (residential dishwasher) they take the hot water from the hot water side of the sink. If the water heater is located a distance from the dishwasher then the cold water fills the dishwasher before the hot water can make it to the unit. This should cure your problem.
Hope this helped
Dave
Jan 15, 2010 | Dishwashers
Dishwasher runs through cycle but no water.
make sure water is on ,if water is on and still no water in d/w then check water control valve
Nov 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
Asko dishwasher d3530. The water in the dishwasher is not hot.
Generally speaking, dishwashers don't heat cold water on their own. Be sure the dishwasher is connected to a hot water supply and that hot water is available to the dishwasher at the START of the cycle.
Often it takes hot water several seconds for house plumbing to deliver hot water to an outlet. If the dishwasher is connected to the kitchen hot water supply, run the water in the sink until the water runs hot before you start the dishwasher.
Dishwashers often have heaters to heat the water even hotter than most home water heaters, but they are not intended to heat cool or cold water. You MUST furnish hot water to the dishwasher from the time the cycle is started.
I've seen houses that take so long for hot water to reach a faucet, the dishwasher is already full (of cold water) before the first drop of hot water reaches it.
Good luck. Hope this helps.
Sep 11, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
New dishwasher no water
make sure water supply on if ok check water solenoid
Dec 23, 2017 | Zanussi 24 in. DE6965 Built-in Dishwasher
Water doesn't run in to clean dishes
if the water line not blocked or pinched... then I would your fill valve.. it may not open all the way...before replaceing the water valve...check that the water is come into the dishwasher but maybe going out the drain..If the drain hose is too low water will run out before the dishwasher can run a cycle... to check it it must raise above the bottom of the sink ... this keeps water from running out and sink water from going into the dishwasher... let me know if it helps
Jan 29, 2009 | GE 24 in. PDW7880JSS Built-in Dishwasher
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwasher runs for a long time
If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Yourdishwasher may pre-heat the water. If so, and if the water entering thedishwasher is cool, the heater may take up to half an hour to heat thewater.
To avoid the wait, increase the incoming watertemperature before turning on the dishwasher. Do that by running thekitchen sink faucet until the water runs hot. Or increase thetemperature of the hot water to the entire house at the hot waterheater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Nov 12, 2008 | Kenmore 24 in. 17362 / 17364 / 17369...
Asko diswasher
Remove the backpanel of the machine, and look if there is water at the bottom of the machine. If so, use a towel or so to dry up the water. This should solve the prob.
Nov 23, 2007 | Asko D1776 Stainless Steel Built-in...
Kenmore 24 in. 16039 Built-in Dishwasher Logo
946 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
