Question about Poulan Garden
My plug is firing and i even tried starting fluid my poulan (craftsman) will not start HELP MOD.358.360180
  • 95 Answers
The first thing you need to look at is the inside of the cylinder.Take the spark out and look down the hole.You will need a flashlight.Look towards the muffler side.If you see scratches.Its blowed up.If thats ok it could have an air leak some where.Or possibly a bad fuel line,or fuel filter.
Posted on Mar 15, 2011
Craftsman snowblower will not start
Dump out the old gas and put in new.Try a spray of starting fluid into the carb. If it will not fire on the starting fluid there is somthing wrong in the ignition system. Pull out the spark plug and clean it with a wire brush. If it still won't fire the points and condensor need to be replaced.
Dec 21, 2013 | Craftsman Tecumseh Snowblower 7hp...
Will not start even withew gas
Try a spray of starting fluid into the carb. If it fires you know you have good spark. If it did not fire replace your spark plug. If it still won't fire point and condensor need to be replaced. If it did fire spray the starting fluid in the carb a few more times to pull the old fuel through the fuel line til the new gas gets through the carb and then it should run. Some machines have a fuel shut off valve make sure it is open.
Dec 13, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Craftsman riding mower turns over but won't start
unplug the connector from the side of the engine and try it if it fires on starting fluid then the problem is one of the safety switches
Apr 22, 2012 | Craftsman Garden
Wont start,wont fire even off starting fluid,has compression,appears to have fire(with plug out and grounded to head)maybe no spark under load? help
Hi, first of all NEVER use starter fluid.........on anything. This stuff (ether) is highly volatile and could destroy your blower and cause you and others around you harm. Starter fluid is meant to start diesel engines when they are cold however, there is the possibility of pre-ignition and that could seriously harm your engine. Make sure your fuel/oil mix is correct. Also try pouring a few drops of mix down the cylinder, after replacing the plug, give the starter a try. With the proper fuel inside the chamber and a confirmed spark from the plug, the motor has no choice but to fire. From this you can determine if your idle is either too lean or too rich. Good luck.
Dec 05, 2010 | Poulan Bp406 45.4cc Backpack Leaf Blower
My Craftsman leaf blower 358.794741 will no start. It won't eveen fire at all! I swapped out the spark plug with identical plug from weed wacker & the wacker started fine - thus the plug is OK. I...
When you say there is no fire, do you mean that you can't get it to act like it wants to start? Or, do you mean that when you pull the plug out and put it against the head, it has no fire? There is a difference. If you have pulled the plug and tested it that way, then it is a bad coil, (the part that connects to your spark plug).
However, if you haven't pulled the plug, then give me a description of how it is reacting.
Thanks,
Jim
Sep 23, 2010 | Garden
Won't start, won't fire after starting fluid is used, checked spark and its blue and very small. Has new plug. Suspect bad magneto, can it be tested? Thanks Don't know model, label on handle says Poulan...
First off you should never use starting fluid on a 2 cycle engine. Serious damage to the piston and combustion chamber could result. Try changing the spark plug and if it's neccessary to prime to start use a squirt bottle with the same fuel/oil mixture as required to run your machine. Try squirting a small amount into the combustion chamber through the spark plug hole. Squirt,replace spark plug,and start. Starting fluid also washes the cylinder of an oil and it could cause a siezure of the piston.
Sep 22, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
New saw - will not start. Have put in premium gas/oil mix. Getting spark from plug when cord pulled. Hasn't even fired once.
It's possible the brake is on. Try pushing the brake forward then pulling it back until you hear it click. Then try cranking it again.
Sep 20, 2010 | Poulan Pro Chain Saw 46cc 20"
I HAVE A POULAN BVM200VS BLOWER...WON'T START I HAVE PULLED THE FLYWHEEL AND KEY IS INTACK...I HAVE A SPARK AT THE PLUG..REMOVED CARB AND CLEANED....REPLACED GAS WITH FRESH GAS..SET GAP ON IGNITION MODULE...
If you have a spark, it's not your ignition or flywheel because they both work together to make the spark.
Give a starter fluid squirt into the sparkplug hole (instead of thru the carb), screw in the sparkplug and give it a try.
Check your muffler to see if it's stopped up. You can just remove it for the initial check when trying to start w/starter fluid.
Oct 07, 2017 | Poulan Garden
Garden Logo
55 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
