Question about Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven
Double wall oven Electrolux Model Number PLEB30T8CCB: Problem: Top oven gets warm but does not warm to desired baking temperature. Broiler appears to work correctly. What part do I need to change?
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Double wall oven Model Number
The probe might be out of spec and therefore the control is not getting a correct reading and thinks everything is fine. That probe is also known as a sensorthemobilian_437.jpgthemobilian_438.jpgthemobilian_439.jpgMight just be corrosion in the sensor's connector. Sometimes bypassing it entirely fixes the problem. Now about the steaming issue:
Convection motor not circulating the air properly?
I would check that.
American oven fault codes and manuals HERE
Posted on Dec 14, 2010
Frigidaire double convection wall ovens, model GLEB30T9DSA ... The top oven will not heat, both the bottom element and the broiler.....
I have the Frigidaire PLEB30S8CCA single wall oven. About 3 months ago the baking element appeared to have gone out. We replaced it, but still didn't work. We ended up sending our control board off to a company named Corecentric. They fixed the problem and returned it to us. The oven has worked perfectly ever since. I searched extensively for a new one, but no one sold them anymore. I found Corecentric on Ebay. They were able to confirm over the phone that it was more than likely a control board issue. It cost about $130. My husband was able to do it himself by taking a couple before px and using them when reassembling it.
Apr 04, 2014 | Frigidaire 30 in. Electric Gallery Series...
Thermostat broken
Good Morning a_t_pearson, this is Z. Thank you for your post! I understand that the thermostat is broken on your top Frigidaire oven; therefore I'm assuming that you have a double-wall oven. If so, please help me understand what you are referring to by thermostat? Is your oven not preheating or reaching desire temperature? Are you speaking about the bake and/or broil elements not heating? May I please have your model number? The serial tag, which lists your model number, is typically located on the front of the oven, on the left side, as you open the door. With this information I can better address the issue at hand. Thank you!
Apr 01, 2014 | Electrolux Ovens
Frigidaire oven will not get all the way hot
Good Afternoon Tasha - There could be
a number of any one of several underlying causes in why the oven is
experiencing this particular issue:
Convection
heating element
Thermal cutout
Thermal oven
sensor
EOC
(electronic oven control)
Ignitor
Bake or broil
element
All wired
connections
The parts above will need to be assessed for further
evaluation. Lastly, the oven cavity and insulation should be checked to ensure
there are no gaps or damages that will leak out the heat. At t his time, I
would recommend contacting a professional to assist you further since it is always
a good idea to get the appropriate diagnosis prior to making any unnecessary
part replacements.
Jul 11, 2013 | Frigidaire 30 in. Electric Double...
Pleb30t8ccb
Good Afternoon Friend,
I see that your Frigidaire double oven, model# PLEB30T8CCB, is having trouble with the top oven not heating.
I suggest giving your double oven a hard reset by cutting the power at the circuit breaker for at least 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Turn the oven on to heat up, and if it does not, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
WP
Jan 09, 2012 | Frigidaire 30 in. Electric Gallery Series...
Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Jan 30, 2009 | Thermador Ovens
Oven will not heat - Thermador SMW272 Electric Oven
since you said the broiler does work , take the wires off the broiler element and put on the bake . then when you put on the broiler the bake should work . the light bulb principle, just remember to wrap all loose wire with electrical tape and disconnect from wall while working.
Dec 12, 2008 | Thermador SMW272 Electric Double Oven
Frigidaire double oven has one element not working in each oven
sounds as if perhaps there has been a thermal overload(switch) tha has gone bad, refer to part number 119 on bothe the lower and upper oven for refernce , you should have continuity trough the switches.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995383394.pdf
Nov 24, 2008 | Frigidaire GLEB30T8A Electric Double Oven
GE Model JKP12G0P2BG Wall Oven Bake Element Not Working Properly
The temperature sensor is bad. The broil element will work even if the temp sensor is bad but the bake element will not. If you measure the resistance across the contacts on the sensor, it should be around 20 ohms, if it is much higher (1000+), then it is bad and should be replaced. It is just as easy to replace as the elements and looks like a small pencil sized rod in the inside top of the oven. Let me know how this works out for you.
Benjamin
Nov 19, 2008 | GE JGRP17 Gas Single Oven
Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven Logo
88 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
