Question about AO Smith SQ1152 Pool Pump Motor
AOS SQ1152 pool pump. Pool pump does not run. When powered makes a hum noise like a garbage disposal that needs to be reset. Pump is 3 years old. The implellor moves freely by hand. Could not find a pump reset button on the pump. Removed the top mounted capacitor and tried to power the pump which made the same sound. ALso ispected the rear wiring housing and the contacts appeared fine with no corosion. Am thinking it's the start capacitor
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,508 Answers
It might be the capacitor, and have another look for the reset button, if that doesent help its off to the electrical rewinders
Posted on Mar 18, 2011
I have a Speck Pump, model E71, only a year old. It suddenly stopped working - it was fine at the start of the season. The problem is that it just hums when turned on.
Since it hums it has power. I believe there is a start capacitor on it, that or the start switch may have failed.
Speck Pumps Pool Pump Parts
usa speck pumps com
have Speck Pump model E71 only year old It suddenly stopped working it was...
Speck Pumps Pool Products Inc
Jul 02, 2016 | Speck Pumps Pool & Spa
Ive got power, hot and cold to my existing pump and shower, but the pump doesn't start, just makes a whirring noise.
Above Ground Pool Pump Won't Start or is Humming & How ...
? 6:16
https://www.youtube.com/watch?v=RH78q36liks
Apr 15, 2014 - Uploaded by Above Ground Pros
Above Ground Pool Pump Won't Start or is Humming & How to Fix It ... Pool Motor - Humming-Loud Noise ...
How to fix your pool pump from humming - YouTube
? 2:43
https://www.youtube.com/watch?v=3v2v6aDDq9A
Mar 25, 2013 - Uploaded by James Hayward
Do you have a pool pump not priming (pumping water) andmaking a humming noise ... not only give a ...
pool pump makes humming noise and does not pump - Trouble F
Dec 08, 2015 | Home
Pool pump makes a loud noise
bad bearings change pump and motor
May 14, 2014 | Waterway Impeller Pump 2HP SD WW
Pinnacle high performance one hp have a reset button
if humming and not running bad start up capacitor or bad motor replace pump be safe
Apr 20, 2012 | Pentair 1HP Pinnacle High Performance...
Pump has power at back of motor and I can turn shaft at the back of pump. It is not running.
this motor has a run capacitor, have it tested. search your area for your local pool pump motor repair guy with free testing.. ask him how to remove it, caps can hold a charge and make for a nasty surprise.. THIS IS IF THE MOTOR HUMS OR MAKES A BUZZ NOISE if not, you will need to check the power at THE BACK OF THE MOTOR. no power check, timer, breaker, main breaker ..
Jun 06, 2011 | Jandy Stealth 1.5 HP UR Pool Pump SHPM1.5...
We have a 3 yr old 2hp waterway pool pump that is making a very loud noise. It is still working but the noise is constant.
I have a 3 year old pool pump, waterway. I can hear the motor humming but the fan wont kick on. I pulled all hosed to make sure they were cleaned out. Any ideas why it would be froze up?
May 08, 2011 | Sport & Outdoor - Others
I have a 1HP OC Smith Pool Pump motor, it is about 15 years old. The shaft was stuck so I took it apart and freed it up. It ran fine for a day then the impleller cracked, I replaced that and it ran Ok for...
Thank you for posting your question here on Fixya.com.
A typical pool pump motor is going to last about 10 – 12 years. A corroded frame and tripping breakers suggests it is at the end of its service life.
It short, it needs to be replaced...for a replacement motor quote, please get as much info off the nameplate as you can and also note what brand the pump it attaches to is and contact us thru www.arrowmotor.net or www.arrowpools.net at your convenience.
Based on what you’ve posted I’d guess it is either an AOS-USQ1102 or AOS-UST1102. Costs for those would be $177.10 OR $172.00 respectively. Your message using the contact feature on our site will confirm which is the correct one.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Mar 26, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
Pump runs for about 15 secs then cuts off.
try testing the starting capacitor by first disconnecting the power, opening the cover on the end of the motor, and test the resistance of the capacitor
Jan 24, 2010 | AO Smith SQ1152 Pool Pump Motor
Pump makes clicking noise when powered up ?
Clicking?... not knowing which clicking noise you are hearing, I will run down the most likely on a new pump.
1. When wiring the motor you may have left a wire in close proximity to the centrifical start capacitor switch. It spins at high RPMs and can be hitting a wire not properly tucked in
2. Most pool pumps are dual voltage. If you wired motor for wrong voltage than that being delivered, the motors can sometimes make noises. Clicking isn't most common, but the vibrating hum of incorrect voltage might be interpreted as a clicking noise.
3.check to make sure no wire ties, or plastic stringy tag holding devices were left in the pump intake basket.
Aug 23, 2009 | Hayward 1 Hp Max - Flo Swimming Pool Pump
AO Smith SQ1152 Pool Pump Motor Logo
506 people viewed this question
Top AO Smith Plumbing Experts
Lawrence Oravetz
Boyet Soriano
Boyet Soriano
Gil Shultz
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
