Question about HP Computers & Internet
PC was booting to HP screen with constant beep. Keyboard nonfunctional. Tried different keyboard / mouse and no keyboard mouse with same problem. Pulled battery to reset cmos, now system powers up for 1 sec. and shuts down. HP Pavilion a210n. Have already reseated all components, tested with bare board, and ps shows okay with tester.
    Scholar:
  • 82 Answers
If the computer is not reaching the BIOS screen one of the components is most likely faulty. I strongly suspect that it is either the Motherboard or the CPU. If you have made sure the CPU is seated correctly you may need to try alternate motherboards or try the CPU in an alternate computer/Visa-Versa. Hope this helps you troubleshoot and good luck.
Posted on Mar 14, 2011
Dear Fixya, my GA 6bx7 (Intel bx440) , GA GF400mx,JNC 235 W Power,Cel 900Mhz start clicking just seconds after (or during) Post (no Hdd ). In Bios signal sound more loudly. There is second or more...
your hard drive is dying or dead,mouse and keyboard ps2 will normally work with operating sys,try with another h/drive should work clicking are heads crashing good luck!
Jan 08, 2011 | Intel Motherboard
I took a hardrive from an HP Pavilion 743c tower and put it in an HP Pavilion a1648x, computer turns on and loads, my problem is that the mouse and keyboard don't work. not sure if they are not being...
I think you really need to boot from a boot disk (windows xp - vista - 7) for your operating system - and attempt a repair from there. Your computers have different motherboards and parts.. windows installed drivers for them are not close enough.
I have had success in xp by doing this: before removing drive from old computer - you go into device manager and remove everything - drives, video card, mother board last and leave keyboard and mouse .. so you can shut it down .. then install into new machine and it finds most everything and then you install your drivers there.
Good luck,
Bill
Nov 29, 2010 | Computers & Internet
I was not thinking as i hoovered out fan vent on my hp pavillion there was no problem as it was connected to my lcd tv when i tried to boot it up the next day all the leds light but screen is black no...
Did you remove the top panel and keyboard?
If so, remove them again and check the video cable from the LCD screen and connect it back to the motherboard, also check the cable from the keyboard to the motherboard. Make sure these cables/connectors are seated properlt.
Aug 19, 2010 | Computers & Internet
I have a Presario SR1950NX that is not booting. After turning on power, the fans come on and the DVD drive flickers, then nothing else happens. The keyboard and maonitor stay dormant. Normally, a loud fan...
It may be the clogged fan that caused this problem then resulted to overheat. possibly you need to replace the motherboard. or first, try using a bootable cd to boot your pc up. it may also be an issue with your hard drive not booting up.
Mar 29, 2010 | HP Compaq Presario SR1950NX PC Desktop
Problem with compaq presario r4000 constant beeping no keyboard
Need to know the number of beeps. They're called beep codes. This page lists some of the Compaq beep codes and what they mean.
http://www.bioscentral.com/beepcodes/compaqbeep.htm
Nov 06, 2009 | HP Compaq Presario R4000 Notebook
Zonet kvm 3002: pc starts while posting says keyboard error, continues to start,mouse okay to use, press 1 keyboard button,both mouse and keyboard freeze. Flip the kvm button to other pc fine.....tried...
Only seen this once before and it turned out to be a legacy setting in BIOS of all places. On I had set the bios to be able to use usb devices in boot up (not same as boot from usb !) Then everything was fine.
Maybe take a look at that and report back
Aug 15, 2009 | Computers & Internet
Keyboard not responding
Have you tried a USB keyboard and mouse wired.try also to hook up the normal keyboard and Mouse with out any usb devices hooked on the computer
May 05, 2009 | Logitech 967461-0403-PK Keyboard/Mouse
Dell Dimension 3100 e10 ...usb won't work
Does the system respond to boot keys (F2, F12) when the DELL logo appears? If so the problem is with Windows drivers and probably can be resolved by reinstalling or rolling back the drivers, but how? Do you have access to another keyboard? Does the system have PS/2 ports? Do you have access to a PS/2 keyboard or adapter? If boot keys work, you could also choose F8 for Last Known Good Config (XP) or System Restore (Vista).
Have you tried different ports (front if using back or visa-versa)?
Try using just keyboard or mouse to see if one has somehow shorted. Also check the ports for any sign of damage.
Jan 10, 2009 | Dell Dimension 3100 PC Desktop
On boot with battery or on power same result. The computer boots to window sign on screen but mouse and keyboard do not work. On reboot tried F2 for setup screen which does work but then once at setup...
i would have told you to go into the bios but seen as you say that F2 key does not work on boot indicates that the keyboard has failed, to check this try another keyboard and see if you get the same result, or if the keyboard is USB try it in a different USB port
hope this helps
kind regards
Nov 18, 2008 | Acer Computers & Internet
Computers & Internet Logo
254 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
