Question about Fusion Beauty Glowfusion Air Glow Gun + Tan Mist Set
My spray gun gets clogged & the solution bubbles in the cartillage instead of spraying through the tube.
2 Suggested Answers
archiearchh
  • 18 Answers
SOURCE: Can i Use other airbrush spray foundations with my
Yes you can use it, however do make sure the consistency of that foundation is the same as the glow fusion has I mean it should not be too thick , too powdery or too liquid, as the air gun pressure is designed in that way only. Else you will not get the good result like you are getting with their product
Posted on Apr 17, 2011
Spray gun problems
did the canister tube fall out? dump the paint out into a saveable container and put straight (enamel reducer) in it and try to clean/clear the unit..adjust the knob on the back of the spray gun it controls the paint flow..
Aug 03, 2014 | Wagner Air Tools & Compressors
Tip
How to clean your air brush to keep it like new
Taking care of your tools and supplies is an essential in their upkeep and increasing the life of your tools. When you neglect to take care of your tools they will get clogged or ruined and eventually will stop working. This same principle applies to your air brush gun, if you don't take care of it and clean in properly after each use it will get clogged and will stop working.
After each use you want to make sure that you get all the paint out, to do this you should add a little bit of warm water to the cup (where the paint goes in) and then pour it out into the trash. You must be sure NOT to use hot water because it could melt or warp small plastic pieces inside the gun.
Fill a bowl or tub with clean warm water, connect the air brush to the tube, plug it in and turn it on. Placing the needle and the cup under the water and pull the trigger. Run water through it for a few minutes to make sure that no color comes out of it. If paint does come out of the gun you will need to change the water.
When the water runs clear through the gun take it out of the water and fill the cup with clean water. While placing your finger over the needle cap pull the trigger. This will make the air flow backwards through the gun causing bubbles to form in the cup. If there is paint stuck in the gun it will come up in the bubbles in this step. Pour the water out and place the needle and cup in water again and pull the trigger.
When you feel that it is clean, take the gun out of the water and spray your gun on a white napkin or paper towel to make sure there is no color in the spray. If no color comes out you are all clean and ready to use your airbrush gun again.
on Feb 06, 2014 | Air Tools & Compressors
Rolson spray gun 70809 not spraying
the paint may be to thick for the gun. or it could be clogged. try spaying plain water through it if it sprays you have your paint to thick
Jul 14, 2012 | Air Tools & Compressors
Air bubbling up in cup when air trigger is pulled this is a gravity fed hvlp spray gun
it means the air holes in the nozzle are blocked the air couldn't get out in the front so instead it went back to the cup makes it bubble
Aug 20, 2011 | Campbell Hausfeld Husky Gravity Feed HVLP...
In trying to spray oil base paint, I get very low fluid flow (if any) from the cup to the gun. I've cleaned the gun and insured the hoses weren't clogged. Changing the adjustment valves...
How does it spray if you dump the paint out and put paint thinner in the cup? If it sprays paint thinnner, but not the paint, your paint is too thick. Thin it down by 25% and try a little. Keep adding thinner until the paint sprays out of the gun in an acceptable manner. Your gun probably has a 1.1,or 1.4 fluid tip. this is for spraying lacquers or automotive paints that are very thin. to spray oil based paint, your would need a 2.0 or 2.5 or bigger. not really what this gun was made to spray.
Jul 20, 2011 | Binks Hvlp Spray Gravity Gun With 1 Liter...
I am using DeVILBISS JGA_510 cinventional spray gun. The pressure pot system is showing constant pressure , but the gun is sputtering and not getting an even paint flow. I have changed paint lines, put on...
First start with the basics, whats the paint VISCOCITY ON A FORD 4 CUP ??
Or Does it run nicely off the stick you stirred it with??
If its thin enough to go up the tube and lines, whats the fluid tip and air cap combo your using?? maybe start with a EX fluid tip (1.8mm) and 30b air cap (cos that sprays everything!!) and reduce from there.
Whats the pot pressure?? Is it a KBII pot? cos they suffered with the air inlet blocking, so IT SHOWS GOOD PRESSURE, but doesnt have it in the pot!
Does it spray anything?? thinners?
Mar 07, 2011 | Air Tools & Compressors
My paint gun is pulsating instead of spraying evenly
It looks like you have a Devilbiss SRI.
Probaby the hole in the lid is blocked, The gun sprays, paint gets sucked out, no air can get back in through the little hole in the lid to replace so it stops spraying, pressures even up it sprays abit more, and so on.
Either that or you have a damaged fluid tip.
regards
Sep 18, 2010 | HVLP New PROFESSIONAL AUTOMOTIVE AIR...
No suction
This model comes in either suction feed or pressure feed. For example a 6211-4307-9 is a suction model. There are different air caps and needles depending on feed style. I assume your'e using either a 82-545 or a 82-555 suction cup attached to the gun. Make sure the tubing is tight, and that the vent hole in top of the cup isn't clogged. See Binks.com for detailed tip combinations.
Jun 30, 2010 | Binks Model 7 Conventional Suction Feed...
Gravity feed gun has bubbles in the cup
I was in desperate need of getting on with lacquering a guitar and it seemed everywhere I looked on the net just gave actual spray pattern issues.
There was a small article that suggested tightening the nozzle up. I had only finger-tightened it.
Problem now solved!!!
Dec 07, 2009 | Air Tools & Compressors
Fusion Beauty Glowfusion Air Glow Gun + Tan Mist Set Logo
75 people viewed this question
Top Fusion Beauty Health & Beauty Experts
John Torgerson
John Torgerson
Are you a Fusion Beauty Health and Beauty Expert? Answer questions, earn points and help others
