Question about Samsung ML 1510 Laser Printer
RE: samsung laser printer ML1510 the online/ error light is continually red , no paper jam but no printing
SOURCE: Re: paper jam in brother laser printer hl 2040 : paper red ligh continue to flash
Besides your helpful
there are extra doing steps to make my printer back to normal:
- Remove completely the unit toner cartridge, check paper jammed in that unit
- open the basck lid of the printer , remove all paper jammed in that arrea
- Blow out the container inside of the printer, to blow away all paper depris and dust.
- re-install unnit toner, close back lid\re-strat printer like your suggestion
Many thanks
Have a Nice Day
FP
714-715-6412
Posted on Feb 13, 2008
SOURCE: Paper jam with Brother HL-2030 laser printer
Being a retired electronics technician, I located and downloaded a copy of the service manual. Then proceeded to hunt for the reason why the Paper LED was staying on. I put the printer into the Production diagnoses mode, then by process of alimination opened and closed each panel and cheack each sensor switch one at a time. At which time it was apparent the problem was the rear door sensor. So I started to disassemble the printer getting instructions from the Service manaul, as most electronic equipement there is a sequence process to accompliah this. and once I found that the method of the rear door sensor operated I found the bracket was not in the right position. I put the sensor bar back into it's proper position and put the printer back to normal opperateing mode, I found my problem was solved. So I reassembled the unit and plugged it back into the compter ran a couple of test sheets and cleaned and aligned the printer head(s) made a few adjustment and everything was back to normal.
I must say that locating the Service Manual was a feat, but worth every cent I paid for it which was $9 USD. Personally i think all service manuals should be available for all Brother products for a fee, then a large number of problems can be fixed by the owners without much bother to Brother.
I ahve two of these printers and would still purchase a Brother colour printers, my next purchase is going to be a Brother color laser printer. Out of all the printers i've used on my computers I like the brother the best.
Posted on Mar 22, 2008
SOURCE: Samsung CLP-300 Printer has red light on, won't print, don't see any paper jam
  1. Close all the covers.
  2. Check in the paper tray for paper.
  3. Check for the toner cartridge.
  4. Remove paper tray, toner cartridge and open the back cover for any paper jam.
  5. Please make sure that only supported paper type and size is loaded.
  6. If printer prints after opening and closing the door, try to load different type of paper.
  7. Disconnect the pritner from the computer, and restart the printer.
  8. If Red Light lits up right away, there's a possible paper sensor problem.
  9. If you see a Green Light, press and hold down "Cancel" button for 4 seconds and then let it go.
  10. If it prints the demo page fine, connect the printer cable to a different port or replace the printer cable.
  11. If it goes back to Red Light, pick-up roller inside the printer is defective.
Posted on Aug 23, 2008
SOURCE: ML1610 SAMSUNG PRINTER PROBLEM
The online/error light is always red, and I can't print. I turn the printer off, change the toner and the light is still red, what can I do
Posted on Feb 05, 2009
ghassun
  • 499 Answers
SOURCE: Samsung ML 1510 LAser Printer
check the spring if it push the roller well or it's weak also check ur paper if its high quality to be rolled
Posted on Jun 12, 2009
SHOWS RED LIGHT WONT PRINT
Probably some type of error. Did anything like a paper jam happen just before you started getting the error? If yes, then check the printer to make sure that there is not still some paper jammed somewhere.
Jan 04, 2015 | Samsung ML3312ND Laser Printer
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
The online light stays red and I can not print anything. what should I do?
check the toner cartridge. red light means there is an error in the printer. check for any paper jams. check paper tray settings.
Oct 01, 2010 | Samsung ML 2010 Laser Printer
The online error light is red on my ML-1610 Mono Laser Printer any ideas how to fix this?
It probably has a jam somewhere. Open each flap, remove the toner cartridge and check the paper path is clear.
Jul 16, 2010 | Samsung ML 1610 Laser Printer
Have you found a solution to the Samsung ml-2510 printer red error light staying problem?
There are a couple of reasons why this happen. A paper jam could have occurred. The cover might be open, try closing the
cover. There might be no paper in the tray, load paper in the tray. The toner cartridge is not installed. The printer has stopped printing due to a major error (you need to contact your manufacture for this).
Nov 11, 2009 | Samsung ML-2510 Laser Printer
I try to print and the printer just prints the first of several pages and the online/error red led comes on.
Try to pull the paper tray out and clean the feed roller inside with alcohol or water.Usually,paper dust on the feed roller causing it to slip during paper feed and printer jams.
Oct 08, 2009 | Samsung ML1740 Laser Printer
Online/error light is red
When you pull the paper out, that affect paper loading switch inside(or paper status monitering switch)
pull all the paper out, check switch inside near Loding roller
put you paper back and Put the tonner cartridge back, close the door and try agian ( i solved my problem this way)
Mar 25, 2009 | Samsung ML 2010 Laser Printer
When the ML1510 is switched on it shows a green light and then qu
Open the top cover, gently touch the fuser unit, it will probably be warm to the touch. This is your problem, the fuser unit has gone. All the cheap Samsungs I bought die from this problem.
Your Samsung software diagnostics may report a LSU error, which means you have to call Samsung service.
Nov 26, 2008 | Samsung ML 1510 Laser Printer
Sep 13, 2008 | Samsung ML 1610 Laser Printer
Brother HL-2040 laser printer
Make sure to clean all the rollers you can see and make sure to check the paper sensor, and clean all rollers and paper paths with some Isopropyl Alcohol (AKA rubbing alcohol)
Sep 04, 2008 | Brother HL-2040 Laser Printer
Samsung ML 1510 Laser Printer Logo
440 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
