Question about LG LFC23760ST Side by Side Bottom Freezer French Door Refrigerator
ICEMAKER NOT RUNNING - LG LFC23760ST Side by Side Bottom Freezer French Door Refrigerator
  • LG Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Mar 19, 2011
Water would not stop running into icemaker, now
The water inlet valve(where the water supply connects to the back) may have been staying open and now has burned so it don't work at all. . You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it.
Mar 25, 2010 | Refrigerators
Ice tray dont empty and water keeps running out
Something caught inside the water valve (replace water valve ) such as dirt , sand . Or , the icemaker died in the fill position . Disconnect the icemaker plug inside the freezer , and see if water still runs from the icemaker fill tube . Also make sure the icemaker fill cup on the icemaker , is not clogged with ice .
Sep 07, 2009 | Whirlpool GS6NBEXR Side by Side...
Our old RV U-Line Icemaker, model 45A has stopped making ice and does not get cold. What does it need?
You need to check to see if the compressor is running and the fan is running. If both are then you need a new unit. The 45A has the r12 refrigerant in it and you wont be able to get parts for a r12 system. U-line makes a BI95 to replace that model. If the fan isnt running then I would replace the fan. If nothing is running then it could be a bad thermostat but first make sure the ejector blade on the icemaker is at the 12 oclock position.
Jul 17, 2009 | U-Line Icemaker
My u line icemaker was freezing water but my iemaker was not working. I just installed a used icemaker, now the compressor and fan work, but no cool. compresor conections dont show leaks, compressor gets...
If the compressor and fan are both running and no cool then you have a sealed system issue. If you just replaced the icemaker assembly and it freezes but doesnt dump then you might have the wrong icemaker or a bad thermostat.
Jul 15, 2009 | U-Line Icemaker
U line ice maker on boat
If this is a stand alone icemaker. Is the unit running? If not check the icemaker ejector blades to make sure that its pointing at 12 oclock. If not then you need to take the cover off the icemaker and turn the smaller gear counter clockwise.(remove cover by gently prying on the inside corners and pull at the same time) Turning it counter clockwise will turn the ejector blade. Once you get it to 12 the plug the unit in and turn on. Compressor and fan should come on. If the unit is running then make sure the fan is operating. Yes then is the compressor on? Yes > then you have a sealed system problem. Let me know if you need further assistance.
Jun 17, 2009 | U-Line Icemaker
My icemaker is not making ice
Check your line running to the icemaker, it may be clogged.
disconnect both ends and blow through it. Should help.
Feb 15, 2009 | Whirlpool GS6NBEXR Side by Side...
Water over flow
Depends on the model. It could be a water switch that is sticking or a motor in the icemaker running to slow. My advise is to replace the faceplate of the icemaker. Part #150
Jan 16, 2009 | U-Line Icemaker
Kenmore koldspot model 106.56532400
Oviously you need water first. You'll have to check that the fill valve is opening and that the water is making it to the icemaker. Make sure the fill tube that feeds the water from the back of the frige to the icemaker is not frozen. Be aware, just because you get water at the dispenser doesn't mean the valve to the icemaker is ok. If you are getting water, you need to check that the icemaker is not jammed, sometimes ice can fall back into the icemaker, or get caught in the ejector. You may need to remove the icemaker and run the mold under hot water to melt the ice. If it was jammed, you'll need to check that the fill level is correct to prevent it from happening again, both too much water and too little water can cause problems. There is a heater that helps loosen the ice from the mold, because of that there is a thermal fuse to prevent it from over heating. It will be molded into the wiring harness supplying power to the icemaker. If you have continuity through the fuse it's ok. If you don't the heater shorted and you will need both a new icemaker and that wiring harness.
Jul 19, 2008 | Kenmore 53642 / 53644 Side by Side...
The water going to the ice maker wont shut off
replace the icemaker without your model number can only guess for the part number im6
Apr 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
U-line icemaker BI98
Need HELP.....my BI98 failed off recently I went to get some ice out for a soda this afternoon and noticeds its all thawed out....began soaking up the dripping water with towels and took the front grill off and noticed it was not running at all so turned the power switch off pulled the unit out to make sure it was not just a lost of power from my outlet...sadly it was not a loss of power the icemaker was not running...any suggestions on what I should check first...I have had this machine from new since 1999 with not a problem until now. Larry louge1@aol.com
Dec 28, 2007 | U-Line Icemaker
LG LFC23760ST Side by Side Bottom Freezer French Door Refrigerator Logo
51 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
