Question about Mintek Televison & Video
The key lock indicator is on and we cant find a way to turn it off. Mark
  • 5 more comments
  • marksac Mar 15, 2011
    2110 Model #
    The Model # 2110
  • marksac Mar 17, 2011
    The Preferencesisnt (Highlighted) for me to use as a option? MArk
    The Preferences is not (Highlighted) as a option for me to use it. I scrooled down to it but is just passes it by. MArk
    Its a Mintek 2110 I went to preferences in setup but its not highlighted for me to use as a option? Mark
    2110 It keeps reading no disk . It worked fine till the key symbol came on Mark The Preferences in seetup isnot highlighted for me to use as a option? Mark
    Yes I tried un plugging it, I went to preferences undser setup but the preferences isnot (highlighted) for me to use as a option. Its keeps reading no disk It worked fine till the key symbol came on
    President:
  • 1,961 Answers
Have you tried resetting your unit?
on the remote control, push SETUP.
enter the PREFERENCES menu.
scroll down to the DEFAULTS option.
select the RESET option and push ENTER.
Let me hear from you again.
Posted on Mar 15, 2011
  • 2,098 Answers
Hi mark,
May I know the model no. of your unit?
Jdvillanueva
My led indicators for caps lock num lock etc not workinh in my lenovo G570 laptop
Hi, If you are using a keyboard that is wireless im sure you just have to change the battery on the keyboard.
However if the keyboard is connected to your CPU, then depending on your keyboard model, you may have to turn F LOCK (F Lock Light on) to access system key commands if they are labeled on the front of the keys, such as num lock , scroll lock and print screen.When you click on the Flock, the lights are either supoosed to click on or off.
view the keyboard status lights by using the On Screen Display (OSD) option, Ensure you download the software ,
from your start menu do a search for your keyboard, on th key tabs setting,
its important to make sure that the correct model number is entered,
double click on the light you wish to change, in the Reassign a Key wizard,
clear the Displays (key name) status on the screen check box to disable the on-screen display, or select it so that a check mark is in the box to enable it, and then click Finish.
HOPE THIS HELPS.
Jan 26, 2013 | Computers & Internet
CANT FIND CAPS LOCK KEY ON MY AMILO LAPTOP
With the Amilo laptop, it is just the key beside "A" (left side key). Though it is not marked as "Caps Lock", try pressing that key. Once the key is pressed, observed at the light indicator on your lower left part of your laptop where other light indicators are shown.
Hope this helps. Thank you for using FixYa.
Jan 31, 2011 | Computers & Internet
Just bought an 03 Focus. Cant unlock the child lock. There is no small hole in the door or I cant see a switch to unlock it. Help!!
I don't have this vehicle, but a quick web search indicates one of two ways to accomplish this task. Most sedans, SUVs, and such these days have child safety locks on the rear doors. Almost always, this switch is located on the rear face of door (the area that can't be seen when the door is closed). The general way to lock / unlock is to open the rear door and push a switch to the appropriate icon (either an open or closed padlock). The other way that I found, specific to the Focus, is to use your ignition key instead of a switch. Take your key to the back door, open it, and look for a keyslot that is in the area of the icons. My research indicates that the key vertical is locked and the key turned horizontal is unlocked.
Good luck.
Jan 29, 2011 | 2003 Ford Focus
My dell d600 latitude laptop indicates a lock button in the top icons and cant procede from there
purple function key next to the ctrl key
press that down and hold
press the num lock (toggle)
press the scroll lk (toggle)
press white cap lock only
See if any of these change the lighted lock indicator.
I assume that was what you mentioned in a focus of the request
Aug 19, 2010 | Dell Latitude D600 Notebook
My function key is on and i cant figure out how to turn it off
To use the embedded keypad
After pressing Fn+F8 to activate the numeric keypad, you must press the Lock key
(in the top row of the keyboard) to turn number lock on or off.
When number lock is on:
• Keys change to the numeric or arithmetic designations printed on the right side of the
keys in the numeric keypad area.
• The Num Lock status indicator is lit.
• To turn off the embedded keypad, press Fn+F8 again.
For further reference of usage of Function keys, check the HP manual:
http://h10032.www1.hp.com/ctg/Manual/lpi05379.pdf
Page number: 30/141
Regards,
Nags
Jan 19, 2010 | HP Pavilion N5415 Notebook
2007 Lincoln Mark LT Key Fob
Theres only 1 way to tell if it will work - try it :)
Here is the procedure to marry a new remote to your truck.
1. Close all doors and then open drivers door and press the UNLOCK
button on drivers door panel while door is open and insert key in ignition.
2. Turn ignition from OFF to RUN (not start) 8 times within 10 seconds, with the
8th time ending in RUN. Door locks will cycle to confirm programming
mode.
3. Within 20 seconds press any button on first keyless remote.
Door locks will cycle to confirm programming.
4. Within 20 seconds, press any button on second keyless remote.
Door locks will cycle again to confirm programming.
5. Turn ignition to OFF.
Locks will again cycle to indicate end of programming mode.
Both the Escape and LT program the same - the transponder should have the same resistance.
Try it out!!
Thanks for using FixYa - a Very Helpful Rating is appreciated for answering your FREE question.
Aug 04, 2009 | 2007 Lincoln Mark LT 4x2 5.5
My car remote control doesnt work . i changed my key batary .i need get new code but i cant .. my car 1994 model BMW 530 i .. best regart .
Hi , you can initialise the key yourself. Ensure you get into the car and close all doors, Insert the ignition key and turn on the ignition lights , do not start the engine, while the key is still in the ignition press and hold the lock button and remove the key from the ignition , while still holding down the lock button press the unlock button 3 times and release the lock button, the central locking should now lock and unlock, to initiate other keys just hold the lock button and press the unlock 3 times , you do not have to insert the other key into the ignition , you may need to practise this a few times , hope this helps, regards mark .
Jul 18, 2009 | 1994 BMW 7 Series
Cap Lock Indicator missing
The best way is to open up a notepad document, and see if the letters you type in are in capital letters. You could also, however, download this free software that will indicate when your num lock, caps lock, and/or scroll lock are on. (this is, if you are running windows)
Jan 09, 2009 | Logitech EX100 967499-0403 Keyboard
Mark 4 golf, heated seats and central locking
basic but have you checked the fuse.
Sep 17, 2008 | 2001 Volkswagen Golf
Televison & Video Logo
52 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
