Question about Spectroniq PLTV3250 32 in. LCD TV
Have my tv connectd to a satalite and now it says that there is no signal to the reciever thru hdmi nor componets. Tried to reset but nothing is still happening
    Master:
  • 691 Answers
First check with another set to see if that receiver is working, and if ok then try different cables, even try another device like dvd or vcr to see if works. If nothing after this then video board is damaged and needs repair or replacing.
Posted on Mar 15, 2011
Cant get ps4 to pass signal thru avr to projector.
Possible PS4 HDMI Handshake Output Problem - AVS Forum ' Home ...
www.avsforum.com/.../1508885-possible-ps4-hdmi-handshake-output-p...
Dec 31, 2013 - 20 posts - ‎15 authors
Nothing seems to make the PS4 pass a signal through the AVR. .... can output videothrough the Integra, why can't Sony get the HDMI working? PS4 - 3D Playback Not Working :-(
Aug 12, 2014
Run HDMI Directly to TV or A/V Receiver?
Dec 19, 2013
AV receiver problem with Xbox One
Nov 23, 2013
Solution to HDMI @ 1080p receiver/display HDCP ...
Dec 14, 2008
More results from www.avsforum.com
My Denon AVR-X4000 won't output video signal from attached HDMI ...
forum.blu-ray.com > Audio > Receivers
Dec 21, 2015 | Denon AVR-3311CI 7.2 Channel Networking...
How do I hook up a HDTV to an old satalite reciever ?
Composite to HDMI converter/upscaler
https://www.youtube.com/watch?v=Qre-GJ8oYAc
Aug 15, 2014 | Audio Players & Recorders
The hdmi wont work the av works I have tried all three hdmi plugs on the the tv and it says no signal could you please help everything I have is setup for hdmi
Tries tv and those cables or satalites boxes unplug,replug it back like about an hour later for those pay boxes to reboot and upgraded it softwares.Tv to do a whole resetting itself back to the factory setting.Than go into the tv Menu.Go into Video Setting,go down and do a resetting back to factory setting.By doing this steps for every components devices that hook to the tv HDMI hubs ports on the tv Tuner signal board to reboot and resetting too.Have very good chances all the HDMI hubs ports on the tv to work again.
Jun 26, 2011 | LG 42LC2D 42 in. LCD HDTV
TV was working fine. Plays DVD's fine. Can't find HDMI from the cable, hence to TV reception. TV set works fine however on DVD's so it is not the set itself. Can't find the HDMI 1 hook up only the HDMI...
Tries tv and cable or satalite boxes unplug,replug it back for like about an hour later.By letting tv resetting itself back to the factory setting and those pay boxes upgrading it softwares.The tv HDMI signal for the tv incomming broadcasting signal should be back,if not, tv might have a dead HDMI cable or that the HDMI 1 hub it plug in is shorted and dead.
Feb 12, 2011 | Mitsubishi WD-57733 57" HDTV
HDMI signal cuts out for a few seconds constantly from receiver to television. It does it when switched to cable box and the roku box. Onkyo TX-SR606 Scientific Atlanta Cable box thru HDMI Roku Box...
Mine did the same thing where the screen would go black for a few seconds and then the picture and sound came back. I would try (1) switch HDMI cables, (2) try a different HDMI input in the back of the receiver, (3) try different input in the back of the TV. None of these seemed to work with mine. I finally ended up running the cable box direct to the TV and only run the audio through the reciever via coax or digital. No more problems. I think the HDMI inputs in the back of the reciever have a problem continuously carrying the signal if it is the leaset bit weak.
Sep 08, 2010 | Onkyo TX-SR606 Receiver
HDMI ports will not work
Unplug the tv,satalite box and playstation 3,replug all the devices about an hour later.Go in ur tv menu,goto PICTURE,go down to reset the Tv Tuner board,will reset the tv Tuner board will reset it back to factory setting.Than still have the same problems.The tv Tuner board it dead,require the Tv tuner replacement.
Jun 28, 2010 | Olevia LT42HVi 42 in. LCD Television
We finished watching a dvd movie with the sony surond sound dvd player and tried to go back to satalite and all i could get was no sig changed to all inputs and still nothing . I finally changed the cable...
Unplug,replug the tv about an hour later let the tv reset itself.Go into the tv menu,go to PICTURE go down to reset,this to reset ur tv Tuner signal board back to the factory setting.Those HDMI ports 1 and 2 should work again.Not than,ur Tuner signal board is defective,or the HDMI port 1 is shorted and dead.
May 31, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
How do i hook my tv to the reciever
depending on the tv input configuration and what your signle source is it would go like this:
TV signal source (Satalite, cable) would go to video in on the reciever and the reciever should have a a moniter out connection to which te tv would connect either by hdmi, component or s connectors
Mar 11, 2010 | Sherwood RX-4109
Xbox 360 working thru HDMI working fine. Now no sound & weird pic
it is prolly an internal problem. have to tried connecting the componet cables?
Mar 03, 2010 | Microsoft Xbox 360 Console
No audio from pc connected using hdmi
Are you not getting audio to the television speakers and the onkyo reciever speakers when connected HDMI thru the reciever or just the television. If it is just thru the television then it is because the reciever is grabbing the HDMI audio signal and converting it so it does not reach the TV. If it is both then try changing the HDMI signal output from PCM to DOLBY DIGITAL on the computer. Your reciever may not be able to process the PCM signal of the computer. Does the reciever show a PCM or DOBLY DIGITAL display when HDMI is hooked up to it?
Oct 03, 2009 | Onkyo TX-SR606 Receiver
Spectroniq PLTV3250 32 in. LCD TV Logo
Top Spectroniq Televison & Video Experts
Frank Zabroski
Frank Zabroski
Jayesh Panchal
Jayesh Panchal
Are you a Spectroniq Televison and Video Expert? Answer questions, earn points and help others
