Question about HP Compaq Presario V6000T Notebook
NOT WORKING My laptop are not working, when i swith-on power running for only one second and then she stop, i buy this laptop last year in USA , i never drop or banging, the computer mention the star-up, and the computer scanning to fix,and the computer said she cannot fix the star-up,in that day i used for 5days then that it!
    Problem Solver:
  • 17 Answers
Reload the machine with the XP cd, just wipe the former operating system...none of the old users files matter anyway.
Posted on Aug 01, 2008
Getting no power to fuel pump fuse no power to ignition fuse
no engine stated.!
fuses good,? 12vdc on both sides key on?
spark good on all cylinders.??????????
this is first. not fuel, fuel is dead last.
if above is ok the engine runs on test fuel.
if the engine runs for say 3 seconds on test fuel, and SOUNDS
great, that means the spark and engine are ok, leaving>?
FUELING only.
easy , right?
if true all that, then the scan tool is next.
wont buy one,? like most here? (you cant fix cars with no scan tool)
make up or buy a NOID lamp. (a small 12vdc lamp)
see if the injectors are all firing.
if not, the PCM is cutting fuel.
if the injectors fire (electric pulse) then it may be fuel relay not closing.
did you check for 12vdc (11vdc min) at the pump? cranking
you must crank it and check,
there are 3 kinds of cars. (we assume last)
1: pump runs keyon, full time, (illegal now)
2: pump runs for 3 seconds, and stops keyon, (for priming only)
3: runs only cranked, (most cars) and runs running engine.
see that logic there?
some cars cut pump and injection with no spark. ( to cut fires)
this logic is inside the PCM brain, called firmware.
just assume the car is smarter and use #3 above. on all cars
and I win..
the scan tool will show errors cranked for 5 seconds.
does it?
now why i cant leave generic help and answer specifcially
no engine stated.
to fix them you need to know whats there, first.
the line up
1.4 L E-TEC I4 (petrol)
1.6 L E-TEC I4 (petrol)
1.8 L Family II I4 (petrol)
2.0 L Family II I4 (petrol)
2.0 L RA 420 I4 (diesel)
next time post the engine in your car.
open hood , look up see EPA sticker there and engine type?
USA answers... all. of mine, as this is a USA forum../
try to add to one post for one problem not make many unique posts. stay on NO START. please.
Apr 04, 2015 | 2006 Suzuki Forenza
Why would my Suzuki Swift stall @ stop sign & not start again after replacing thermostat?
overheated it? 98 swift, (which of 7 engines is it)
how can temp run perfect on a no start engine?
ok you meant before the stall. got it.
seems to me it cranks robustly , right.
so spark is next, got spark to all cylinders>.?
(we are USA and all USA cars this year scan with any scan tool made) so scan it.
scan before cranking then crank and scan. for 5 seconds cranking
the scan tool will tell you why it is not making spark or fuel.
if you have spark test fuel testing works, if that works , that means.
you have fueling loss or flooding, did you check for flooding
or crank wide open throttle to clear flood >?
test fuel will run any good engine for 3 seconds. per test.
100 years we do that.
test fuen in can, or put gas in spray bottle.
seems wire was disconnected at the service of thermostat
so look for loose wires. and connectors at engine
watch scotty
https://www.youtube.com/watch?v=064Ilsz8Fzg&NR=1&feature=fvwp
Jun 17, 2014 | 1998 Suzuki Swift
10 year old Seiko Kinetic (model5M62-0B00) blue face. Last week stopped and after some shaking started again but seconds moved in 2 sec intervals for a few hours. Went OK for a week and again last night...
After 10 years it will be likely that the Kinetic capacitor will need upgrading. Your watch is designed to tick in two second intervals to tell you the power is very low. The power button will work again when it has some power to show. Yorkshire Watches www,yorkshirewatches.co.uk can do the upgrade for you if your in the UK. Give them a ring.
May 23, 2011 | Seiko Kinetic watch
My dell 1525 no power at all
Good luck with this colossal piece of junk from Dell. I had the same problem. Second Inspiron to do this. I ordered a new battery. The Dell techie was SO impressed that the battery lasted more than a year. It lasted a year and a half. Anyhow, new battery arrives, and it won't charge. They tell me it is probably the plug in and the motherboard. Nothing like spending over 500 to fix a computer that I paid 600 for that did not even live to see two years old. Did I mention that I will NEVER buy another Dell.
May 26, 2010 | Dell Inspiron 1525 Laptop
My machine is 3 years old and used on average four times a week. It not worked hard as we work in offices, so no heavy overalls. Last saturday it stoped half way thru a washer cycle. The door remained...
Easy, scrapped it and purchased an Indesit. The cost to repair AEG was more than buying a new machine. I would suggest to anyone reading this never invest buying AEG unless you have a live in washing machine engineer.
Jan 26, 2010 | AEG Washing Machines
My laptop's screen is not working properly. Sometimes it stops working for a second, it stays grey, like a bad TV conection. I don't know what to do. It's a HP pavilion dv5-1251nr. Usualy it happens for...
Try hooking it to LCD or external monitor if working then,buy a new LCD with removal instructions on Ebay.
www.ebay.com
If the external doesn't work buy a motherboard on ebay
Oct 03, 2009 | HP Pavilion dv5-1251nr Notebook
My Hp Pavilion Laptop says: 0% available (plugged in, charging)
Unfortunatelly, not much you can do!
Most likely it is up to the battery.
Such things are not unusual. My friends laptop battery died at once (just like yours) in about two weeks after he bought it. Fortunately, it was under warranty and battery was replaced with a new one..
Normally it takes time the batteries come weaker, but even then, they can keep laptop running for some short time (seconds to minutes).
The laptop battery is made of a group of batteries, (maybe six or nine) and it is possible that only one of them is completelly dead. That makes a break in the battery circuit, means no other battery can be loaded with power, and that's why you don't have a second of battery power.
You may try two things:
First unplug the power and unplug the battery. Check if some dirt, dust or corrosion is on the contacts of the battery or contacts on the laptop.
If so, carefully try to clean it, and then try to charge.
Other thing you can try is to go to the shop you bought your laptop (or any other shop) and ask them if they have one on stock, to check if your laptop will work (even for seconds).
If so, than you have to buy a new battery.
At the end, please DO NOT OPEN your battery. Nothing you will find inside. Replacement of the batteries inside will NOT WORK !
Regards.
Mar 25, 2009 | HP Pavilion dv6000z Notebook
Acer 3000 speaker problems
it sounds like the speakers have burned out, so the only place I can think of is Comp U.S.A., or Circuit City they have some pretty good techs there, and if they cant do it, you might need a new laptop, but don't worry, the people at both of these places can transfer everything from your old laptop to the new one with no problems
Jan 09, 2008 | Acer Aspire 3000 Notebook
Toshiba Satelite A105S2617 Power Problem
Hey buy dell laptop. they have some gud warrenty options. They replace hardware for free upto 4 years max if they are faulty.
Dec 20, 2007 | Toshiba Satellite A105 Notebook
HP Compaq Presario V6000T Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
