OKI C5450 020 fatal error reset - Office Equipment & Supplies
Soulvisitor
  • 1113 Answers
SOURCE: oki c5200 "Fatal Error 106"
from your service manual....main board issue
Posted on Jan 16, 2008
  • 97 Answers
SOURCE: 980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Posted on Apr 07, 2008
SOURCE: does anyone know what is
If you look on top of the fuser roller(upper orange roller), there is a thermistor (orange rectangle plastic that rides on the roller) you will see four wires going into that housing. Two are for the thermistor and the other two is for the fuse that is built into the housing. You would have to use a soldering iron to melt the plastic that the fuse is sitting in. You would have to figure out what to use as a fast blow fuse.
Okidata makes it difficult to take out the thermistor because the nut is locktite on the screw. Try using the soldering iron to melt it. Just make sure you dont damage the thermistor.
Posted on Jul 03, 2009
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Posted on Feb 25, 2010
SOURCE: OKi C5800ldn 231: fatal error 03
I have the Oki 5650 which had been great for about 18 months. Then found that the C cartridge was showing error as 'not installed'. After much fiddling about with it and checking on the internet I can now rectify this by either pushing down on the top of the printer while it boots up, or removing the small chip on the left top of the toner (make sure you have 'earthed' yourself to prevent any static damaging the chip when you handle it!) and taping securly onto the top of the cartridge above the chips proper slot. This now has been working OK for 6 months. Strange how this only affects the C cartridge (which has also been replaced and had the same problem). I suspect that the printers RFID chip reader for the C cartridge is having problems reading the chip and moving the chip closer to the reader by either taping to the cartridge top of puching on the top cover while printer boots up resolves the problem (for now anyway!) This can also trigger the 'service call 231 fatal error 03' message which also disappears if you follow the above procedure.
Hope this helps you.
Posted on Jul 27, 2010
Oki c7300 Fatal Error
all oki errors are fatal errors, there will be a 3 digit number that will tell what the error actualy is
Jun 02, 2014 | OKI C7300 Led Printer
How do I reset fatal error code 980 on a oki c5650
Oki is forcing you to buy a new fuser. If fuser roller, film and thremistors are still in perfect shape, reset is possible with new OEM FB fuse
Jun 18, 2011 | OKI C5650n LED Laser Printer
Reset 051 fatal error OKI C9600n led printer
Service Error 051: Error
CU fan Error CPU cooling fan of CPU PCB is abnormal.
- Is the connection of the CU PCB Normal?
No - Normally Connect
Yes Replace fan
- Replace and restore fan?
No Replace CU PCB (Must Replace EEPROM)
Jan 25, 2011 | OKI C9600n Led Printer
Oki c5650, fatal error
tengo una impresora oki y me muestra error fatal en la pantalla que debo hacer para quitarle ese error de mi impresora
Apr 26, 2010 | OKI C5650n LED Laser Printer
Oki c 5600 980 fatal error
The error means that the media is wrapped around the heat roller of the fuser. The only way to reset this error is to replace the fuser unit.
Jul 20, 2009 | OKI C5500n Laser Printer
Oki c5200 fatal error 121
We had a similar problem with an Oki C7300. It was reading "Fatal Error 121" on the display.
We fixed it by simply unplugging the printer from a surge strip and plugging it into the wall directly. After that, the error went away and has not come back.
Apr 16, 2009 | OKI C5200n Laser Printer
Fatal error 980 OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Fatal error 172
From OKI error list:
Error 172 - Upper Heater Temp State: High
Heat Roller Thermistor indicates high temp
Solution:
Turn off printer, let cool down.
If problem still exists seek service
Mar 07, 2008 | OKI C5300n Led Printer
Oki 9800 fatal error 230
No reset need to fix fault then clears...
Replace Toner Cartridges with Gen OKI new ones... are you using non oki product? Cause Toner carts, thats where I would start looking cause the error is the machine not receiving correct information from a little chip built into the toner cartridges to allow operation to begin.
Dec 07, 2007 | OKI 9800hdn Laser Printer
Oki 9800 230 fatal error
No reset need to fix fault then clears...check toner carts are secure on drums, all their contacts are clean,
201 people viewed this question
jasbo
jasbo
