Question about Apple Customized 15" MacBook Pro Laptop Computer Notebook
How do you connect a mac to an HDMI device and can you get sound to the tv ?
    Scholar:
  • 89 Answers
HDMI cable can support sound, but DVI cannot. If you are using a DVI-->HDMI adapter, there will be no sound. You will need to run a cable from the audio output (either optical or RCA) to your receiver or the back of your TV, and configure your TV to look for it's audio from that input rather then from the HDMI connection.
Posted on Mar 14, 2011
  • 51 Answers
Hey, you would need a Mini display to HDMI cable and unfortunately the sound cannot be ported through the mini display port.
Testimonial: "Thanks, gonna go grab that cable "
How to fix a hp laptop screen
Posted on Sep 14, 2013
When selecting the source, HDMI 2 will not highlight, Only TV. HDMI cable connected to box and to HDMI2 port on TV
You have to check the HDMI cable. In Samsung tvs the HDMI sources only highlights if the a proper HDMI sources is connected to the corresponding HDMI port of the tv. Also check by connecting any other device which have and HDMI connectivity to the HDMI 2 port.
www.electro-medical.blogspot.com
https://www.facebook.com/electromedservices?fref=nf
Oct 02, 2015 | Samsung UN22F5000AF 22 LED 5000 Series TV...
Have lg 55ls5700 tv trying to connect samsung hw-f450
I suspect that the TV you have does not support the ARC function that the sound bar has. What you may have to do is use the Optical In from the sound bar to the TV and you should be good to go. You may have to change the TV's settings to use the Optical In though. So you should end up with the BluRay Player connected to the TV via an HDMI cable, the sound bar connected to the TV via the Optical In using a fiber optic cable. Hope this helps.
Mar 19, 2014 | LG 55ls5700 55 Edge Led Smart Tv 120hz...
Sharp aquos tv no sound hdmi
What are you connecting to that HDMI input? Some devices do not put the audio on the HDMI cable. For instance: If your laptop has a HDMI out and you connect it to a HDMI input on the TV, you'll get a perfect picture without sound
Jan 02, 2014 | Televison & Video
LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
Jan 29, 2013 | Audio Players & Recorders
Suddenly lost Laptop to Mitsubishi 60c9 connection using HDMI
never plug in hdmi when comp.is on you may burn your hdmi port
Aug 03, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
I'm trying to connect a Samsung HD LCD tv to a Denon AVR1508 receiver using HDMI cable so that the TV sound comes thru the receiver/speakers. which jack do I use (on both the tv and the receiver,
connect the hdmi to the tv (hdmi input 1) and to the receiver (hdmi output) you must make sure that the receiver input settings are assigned correctly. Then hook up all of your devices to the receiver. remember that the 1508 dosent do hdmi upconversion, so if you have any devices that are NOT hdmi, you need to run rca cables from the output of you receiver to the input of your tv. If you have any digital inputs coming out of your devices, i would recommend using them. your 1508 has two inputs that are assignable.
If all of your devices are hooked up to your receiver, and its hooked up to your tv properly, just turn down the sound on your tv, and turn up the volume on your denon!
Dec 04, 2011 | Denon AVR-1508 Receiver
When you connect the HDMI cable from the TV to the receiver, is the receiver to and the TV to work pr is some other connection needed?
You can't connect your receiver to the television to get sound that way unless your television has an hdmi output. Your tv more than likely does not have an hdmi output. Those are hdmi inputs on your television. The way to connect the television to the receiver is to connect the red and white RCA outputs from the tv to the red and white RCA inputs on the receiver to get stereo sound. Now if your television has a digital audio out you might be able to get surround sound with connecting a fiber optic cable between the digital audio out of the tv and the digital audio in on the receiver, but this does not always work for all of the devices you have connected to your television.
The way to go is to connect all of your devices to the television's inputs for video and directly to the receiver for sound. The devices are connected from their audio OUT to your receiver's audio IN.
Feb 05, 2011 | Sony STR-DH510 5.1 Channels Receiver
I have a macbook and want to hook up to my dynex 24 inch tv. I am successful using (mini dvi to dvi to hdmi) connection to the tv receiving great video. My problem is that I have no been able to get audio...
Your mac would have to have a fully hd compliant mini port. To be honest I havent even checked to see if any do. Then you would want to get a mini video port to HDMI adapter. If you don't have one of the newer Intel mac then chances are you cant do sound through that port, which is what your tv is looking for on the hdmi port.
Easiest solution is to hook your headphone port on your laptop to a stereo or some decent computer speakers, which usually sound better than tv speakers anyway.
Jan 08, 2010 | Apple Computers & Internet
Right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
Jan 07, 2009 | Audio Players & Recorders
Model 60PL9200D/37 no sound
What device is connected to TV: cable, sat box, dvd player? What type of cable are you using to connect to the accessory device?
For a red, white, and yellow cable:
I cannot hear sound from the television when connecting to the AV1 input. What do I need to do?
Answer When you connect the accessory device to the AV1 input of the TV using either component video cables (YPbPr) or composite video cable (Yellow), you must connect the audio output from the accessory device to the 'INPUT AV1 AUDIO L R' of the TV using the RCA audio cables (Red and White).
If the connection is good,
Check to ensure that the AV1 audio source from the TV on-screen menu is selected to AV1.
  1. Press the 'MENU' button on the remote control.
  2. Press the cursor up/down to select SETUP and press the cursor right.
  3. Press the cursor up/down to select SOURCE and press the cursor right.
  4. Press the cursor up/down to select ANALOG AUDIO IN and press the cursor right.
  5. Press the cursor up/down to select AV1 and press the 'OK' button.
  6. Press the 'MENU' button to exit the menu.
Make sure that the volume on the TV and on the device is set at an audible level and also that the sound hasn't been muted.
For HDMI,
The picture quality is good but the TV does not produce any sound when connected to an accessory device with an HDMI to HDMI cable.
Answer
  • The TV's behavior is considered to be normal as some accessory devices have an HDMI audio output setting that requires to be turned on when using an HDMI to HDMI connection.
  • Check the on-screen menu of the accessory device to ensure that the HDMI audio output is set to ON.
  • In some cases, you may need to set the digital out audio stream of the accessory device to PCM.
  • For detailed information, please refer to the user manual of the accessory device.
Apr 07, 2008 | Televison & Video
Computers & Internet Logo
1,704 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
