Question about Belkin Computers & Internet
I have a Belkin router and I am unable to find buckeye cable system on the list is there another name for buckeye cable system?
  • James Downing
    James Downing Mar 14, 2011
    Are you trying to hook up a router to your Buckeye cable modem? Or do you have a belkin cable modem you are trying to use with Buckeye's internet service?
  • Edgar De Leon Mar 15, 2011
    Thats because not all the clabe system companies are listen on the router for configuration
    Please send me the router modem to help with the configuration
    Scholar:
  • 97 Answers
Not all ISP's will be supported by default, it kind of depends on the software Belkin supplies. You can of course always do a manual set up of your device...
Posted on Mar 15, 2011
Change my belkin router password want a diffrent password
Connect to the router via a cable.
Open CMD (command) prompt and type:
iconfig
you will see a default gateway listed - write the ip address down.
Open internet explorer and enter the gateway address into the address bar.
Should open a web page to configure the router.
You may have to provide a password.
If you're only interested in wireless password change, select different pages until you get to the wireless stuff.
Try this site:
http://techchannel.radioshack.com/change-security-settings-belkin-wireless-router-1402.html
How to Change Security Settings on Belkin Wireless Router
Feb 11, 2015 | Belkin Computers & Internet
Using the Belkin model f7d4302 for my PC (Processor: AMD Athlon II x215, 2.7 Ghz; 6 gigs of Ram on 64 bit system utilizing the Windows 7 operating system). Unable to connect directly to my modem (Comcast...
Please follow the below steps,
(1) What type of cable you are using between your Belkin Wireless Router. If you are using a cross cable which I suspect then replace it with a straight cable. You can easily get it from Computer hardware stores and sometimes in super markets. If you do not know how to check weather a cable is straight or cross please look at the connectors of both sides of the cable from downside up. If the position of small tiny colorful wires are identical in both connectors than it is straight which we need. If the position is not identical than it is cross cable and we do not need it. It will not work properly for you.
(2) You should set the IP address to automatic in My Network/Network properties.The same for DNS.
(3) You should know the IP of the Belkin Wireless router and you should be able to ping it with the cable on.
This much configuration is required from the PC side.
(1) If you look carefully around the Belkin Wireless router you will find a pin whole. This pin whole is used to reset the settings to default by poking a pointed object like a pin. Make sure the wireless router remains powered on during this.
(2)After this if you still face connectivity problems. Try replacing with another Wireless Router just to check if the connectivity or QoS improves. If it does, you can be sure that the problem is with your Belkin wireless router.
Good Luck!
Sep 25, 2010 | Computers & Internet
F5D7234-4v3 Belkin Router I have the above listed
Press RESET button for 10 seconds it is in back side of router. Then all settings defaults. Then you can configure it with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Sep 22, 2010 | Belkin Computers & Internet
I have a Belkin router N300 do I just plug in the printer Lexmark cable to the router and that is it.
To make my Lexmark e250DN work on the network using my new Belkin N300, I had to do this:
1. Install router as per Belkin instructions. 2. Power off printer, then connect Lexmark printer to the router. Power on printer. 3. In a Browser, go to 192.168.2.1 which is the Router's IP address. 4. Click on DHCP Client List. You will see a list of the "computers" connected to the router, which includes the printer. Your printer will have a very long alphanumeric Host Name (mine began with E00000) Note the IP address (something like 192.168.2.4) That is the printer's IP address. 5. In Control Panel, Printers & Faxes, a) if the printer was previously installed with a different router, edit its settings to use the new IP address; b) if the printer was not previously installed, ADD a Network Printer at address http://192.168.2.x (x being whatever your DHCP client list showed).
That should do it.
Jun 25, 2010 | Belkin (F5D7230-4) Router (587009)
Belkin Wireless Modem Router, model F5D7634-4.
If the reset did not help ,i would suggest you talk to the Belkin Support team and get a replacement. Since its a new router, I assume it has an up to date firmware .
Dec 16, 2009 | Belkin (F5D6230-3) Wireless Router
My Belkin G Wireless Router cant even get passed step 1. My lap top recieves the signal but their is no internet! Help please
Since your unable to access internet through the router(wireless) ,& globe light is flashing--I suggest you to refresh the network list and connect to your network again still if it won't work then you need to Re- configure it. Because your Modem(cable/dsl) is working fine. Check the ip address of your computer. if its invalid then you need to do the "reset" on router (ip address should be 192.168.2... range).
Or else you can call (toll free number) for belkin for reconfiguration
Hope this suggestion helps for you both...
Apr 11, 2009 | Belkin (F5D7230-4) Router (587009)
Problems conneting to Internet through Belkin 54G router
- Assigning of static DNS address on your computer will do to fix the issue.
Mar 15, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
CANNOT GET INTERNET_ROUTER CONNECTED AND WORKING PROPERLY
www.west.net/-jay/modem
www.tweakit.com
www.k56.org
www.itu.ch
www.firewire.org
elaine.teleport.com/%ecurt/modems.html
www.belkin.com
check the networking and sharing folders in the control panal.
the security software in windowsand the anti virus program provider you are using ing on the net.
go to address bar and type in router driver only i got over 200,000 hits without any manufacture names added to the driver list of manufactures name or name list
rod
Feb 06, 2009 | HP Pavilion dv6000z Notebook
When trying to connect device the isp name not given
That is common.
Follow the manual installation instead of the Wizard -
All the information you need and is downloadable from Belkin for this model :
http://www.belkin.com/support/product/?lid=en&pid=F5D7230-4&scid=221
Jun 12, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
85 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
