Question about Kenmore Ovens
I have a Kenmore C968-59573-1 electric oven and need a manual, or at least ideas on how to set the clock and use the self-cleaning feature... help please.
5 Suggested Answers
SOURCE: Self-Cleaning Whirlpool Oven
Hello, I am cleaning my oven today. I went to the whirlpool.com website and clicked on customer support and typed in my model number which is located on the front inside panel of my oven. They will provide you the manual with the self cleaning instructions. I hope this helps.
Posted on Jul 17, 2008
SOURCE: self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Posted on Dec 09, 2008
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Ultral Bake Self Cleaning Super Capacity electric oven
F2-E1 - Touch Pad (Keypad) Cable Unplugged -
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
It appears your timer/clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
SOURCE: Whirlpool Oven will not heat
My Whirlpool oven quit after 6 years. I took a shot in the dark and unplugged it, waited a minute, and plugged it back in and it worked!
Pat
Posted on Oct 18, 2010
Stopped f1 flashing and beeping by adjusting the lock feature to 12 o clock not oven and self cleaning not working at all
You have disabled the oven feature if you did adjust the door lock assembly. Interesting that the F1 stopped. notsure why myself.\
Usually the F1 feature does not go away unless you replace the electronic/control board.
I wonder what would happen if you set the door lock assembly to where it was before?
Oct 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
I have a kenmore self cleaning oven.... How do I use that feature
DONT!
More problems will ensue.
It causes more problems than solving problems!!
Head over to the manufacture's website.
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
May 19, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
My oven is less than a year old. I ran a self cleaning cycle on it and now it will not heat up. There is power to it because the light comes on inside. Do you have any ideas about what might be wrong with...
Self cleaning features on all ovens tend to blow fuses.
It is best to use a oven cleaner rather than the self clean feature.
Your oven has a fuse on the rear of the oven that must be replaced.
You must unplug the range and remove the rear panel to access the fuse.
Use a volt/ohm meter to check the fuse.
No reading on continuity is a bad fuse.
Mar 03, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I cant get my self cleaning oven to unlock... what do I do, I cant find my manual
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Oct 10, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
My step daughter has pushed some buttons on the oven, and now it is locked.....it is a self cleaning Kenmore convection oven......how do I unlock it?
DON'T KNOW YOUR STOVE BE HERE IS AN SIMPLE FIX THAT MIGHT WORK ADVANCE THE TIME ON THE CLOCK 8 HOURS AND SET SEE IF HELPS IF NOT TELL ME MORE
Dec 20, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric stove
Hello d_i_a_n_a18,
In order to put most ovens into the self-clean mode, there are a series of steps that must be initiated in a specific order. On most units the oven control needs to be set to bake or clean and the temp. control needs to be set to clean and the door lock mechanism must be engaged for everything to work. I would suggest that you consult the user's manual for directions for your specific model. If your manual is not available, check on line at the kenmore parts web-site and you can usually get a PDF version of your manual. Good luck.
Nov 18, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Self cleaning oven directions
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
131 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
