Question about Whirlpool Washing Machines
Whirlpool Frontloading duet HT retaining water in the tub
    Novelist:
  • 184 Answers
THE ONLY THING BETWEEN THE TUB AND THE DRAIN IS A
PUMP/MOTOR AND CONNECTING HOSES. THERE IS ALSO A CLEANOUT BEHIND THE FRONT LOWER PANEL. REMOVE THE PANEL BY REMOVING THE THREE SCREWS ALONG THE BOTTOM EDGE. PULL DOWN ON THE PANEL TO REMOVE IT. A LARGE CAP ON THE FRONT OF THE CLEANOUT CAN BE UNSCREWED TO REMOVE A FILTER.
CLEAN IT OUT AND INSPECT THE ENTRANCE INTO THE PUMP HOUSING. MAKE SURE IT IS CLEAR. REASSEMBLE AND CHECK OPERATIONS OF THE WASHER.
Posted on Aug 01, 2008
I have a whirlpool duet sport washer that is leaking from the back. we just replaces a screw that hold sthe drive motor up bc it broke. it looks ike the water is dripping by there.
Possible that the tub is cracked or there is a dent which must be checked. if the leak, is visible and comes from the tub you can use some good sealer with glue to stop the leak. this can be polished off. You also try with silicon sealing which comes in small tubes and can fix this leak.
Jun 05, 2012 | Whirlpool Duet Sport HT WFW8400TE Washer
We have a Whirlpool Duet HT washer. Due to the freeze, and burst pipes, we haven't used it for a few days, but got the cold water line fixed. However, when we started the washer, it came up with an F20...
"F20" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed.This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you do not have the hot water line fixed, then that is where your problem is. The washer looks for water supply on both lines. It will still work, but you will get this error.
Feb 06, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Hello. It looks like the rim of the tub is
sounds like the rubber boot from door to drum is worn.  can be replaced but suggest a pro do it..
Jul 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet Sport HT WFW8400TE Washer: Whirlpool Duet Sport HT front loader is stopping b...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 14, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
F33 displayed in whirlpool duetsport frontloading washer
F33 Leak. If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed. Check your inlet valves for block, where the water comes to machine OR
If the control has turned the water valves on, and after 8 minutes, the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off, and the error code will flash.
Press ‘pause’ and ‘cancel’ twice to clear the display. Mains off the wall.
1. Check for crack or holes in the washer tub and pressure switch hose, which runs from the
bottom to the pressure switch.
2. Replace components if necessary.
Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
An open coat hanger went through a hole in the drum
aways unplug unit first...get another coat hanger,,and tape amagnet to it,,if magnet to big smash it,,pretty quick,,if that dont work ,,reply back and i will talk you through taking the tub to pump hose off.and pushing it out,,but do not flush water through,,because if it gets in pump impeller,,we are going to have a new years mess,,,happy new year
Dec 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT Front loader
actually the code is probably fh which indicates no water in tub ..possible causes would be water siphoning out due to low drain or tight fit in stand pipe ..if these are ok suspect flow meter ..the small round object on left with 2 small hoses attached 1 from fill valve other to dispenser...also possible pressure swith on right side ..suspect flowmeter 1st if it has one
Nov 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet ht wouldn't start
remove the lower front panel,3 screws,side up and off,there is a tech sheet inside on the panel that should help you ,let me know what you find-mike
Oct 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
100 people viewed this question
Dan Webster
Dan Webster
Sal De
