Question about LG LRFC25750 Refrigerator French Door
I need to get my lg refrigorator door to stop sooner?
  • pecesq Mar 15, 2011
    I contacted LG and they said it does not have any other setting. I was woundering if I could get a different hing from another source? If I can not trun it around do you have any other ideas? Thank You Paul
    President:
  • 1,654 Answers
Is the door slamming is this the issue? What condition are the door closeing cams in? The plastic inserts around the pin on the bottom of the door. These close the door for you automatially. If the door is slamming then you need to level the fridge, it is tilting too much towards the back. Adjust the feet in back or use some furniture coasters or other shim on the back feet to lean it more forwards.
Posted on Mar 15, 2011
  • Dcramer531
    Dcramer531 Mar 15, 2011
    If your talking about how far they open, that is in the spec sheet, as far as how much clearance is reguired to use these type of doors. You might be able to make a stop that will go on your hinge pin that stops it where you want it, but there is nothing in the parts lists on these. These doors are designed and made to open as far as they do.
  • 4,070 Answers
There should be a door stop on the bottom hinge of each door. You have to remove it and turn it around change where it stops. You may need to swap the door stop with the other door to get the position you need.
Posted on Mar 14, 2011
How do i get squeaking door to stop kenmore
Can you be more specific with the description? Where? Top? Bottom?The best solution is to identify if the alignment is correct. If the alignment is good, look at the hinges for excess wear. If there is no sign of the hinges being worn, needing replaced; apply some light oil, "Three in One Household Oil". This will only take 1 or 2 drops in the pivot point of the hinge. If the alignment needs adjusted the hinges will need moved. You will need the tool (whatever is used by the manufacturer) and something to block the door. Purchase new hinges if they show wear. Loosen or replace the hinges, position the door in the desired position, tighten the hinges securely, careful not to strip out the threads. Check the door function and alignment make adjustments as needed.
Mar 16, 2013 | managemylife.com
My washing machine stops working, it shows 'dE' everytime i try to start a cycle, and i dont seem to be able to find out what it is... please help
DE MEAN'S DOOR ERROR,There is a little magnet that detects if the lid is open or closed & this magnet always falls off into the machine then pumped away. (If it gets past the pump with out jamming it).you can't just buy the magnet you have to buy a whole new top & most of the time this cause's the computer to fail as well,So it could end up costing a fortune even up to the amount you could have bought a new one my advice get rid of the samsung & buy a new lg the sooner you do that the sooner you start saving money in washing machine repairs.
Feb 25, 2011 | Samsung SW62ASP Top Load Washer
Hello, I need to buy a replacement part for the door of my LG washing machine. The part has the number 3650EN3005 on it. Can you help?
I need the same part! I looked at the LG web site and Statewide do all their parts. https://www.statewideapp.com.au/shop/ I have ordered that part number (it has an A on the end but the picture looks the same) - $12.95 plus freight ($10 to Australian addresses). Hope it works!
BTW such a badly made machine - a little plastic strip opens the door, it's a surprise it didn't break sooner!
Dec 07, 2010 | LG Washing Machines
I bought my side by side refrigorator years ago and the front door panels are showng spots of rust.I customed ordered this refrigerator and paid 1800.00 Is their anything that can be done about this.
search ebay for "SUB ZERO STAINLESS STEEL REFRIGERATOR PANELS". I sumbled upon these guys one day, and looks like they can make panels for most fridges.
Jan 22, 2010 | Refrigerators
Frig sweats inside
Bad door seals. Air is getting in.
Sep 08, 2009 | Kenmore 65802
LG Chocolate screen messed up
It was probably stepped on.  You will require a new screen sooner or later.  Better off using the insurance to replace it.
Apr 21, 2009 | LG CHOCOLATE VX8500 Cellular Phone
I have a LRFC 22750 SW   LG bottom freezer with french doors.   I have been getting an error message on the digital read out ER on the refrigerator side and I think DH on the freezer side.   I  unplug...
You will get this error code if a sensor does not reach a certain temperature (+8 C, to be precise)within 2 hours of going into a defrost cycle. Increased frequency probably means the defrost build up is causing your refrigerator to run more, which will bring on the defrost cycle sooner, and the error code to repeat sooner. So, it really looks like your refrigerator is not defrosting. Soon, you will have inadequate cooling. A temporary fix to the poor cooling problem would be to unplug the refrig and open the freezer for a day or so to let it defrost on it's own, but the frost will then begin to build up again, resulting in poor cooling, depending on climate and door openings, possible in less than two weeks. Better look for service soon. If you are in the US, you can try http://us.lgservice.com/index_b2c.jsp to find service using your zip code, or call LG at 800-243-0000.
Feb 01, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
LG INTELLOWASHER DD 7KG DOOR LOCK STAYS ON WAY TO LONG
Never heard of that; I would try a new door latch as I have never had a bad control issue with the operation of the door latch. There is no real way to test it. I can getb you the latch if interested. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 29, 2008 | LG WM1814CW Front Load Washer
LG LRFC25750 Refrigerator French Door Logo
74 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
