Question about Coleman Heating & Cooling
I have a coleman evcon modal #dgato75bdd im getting power to it and i see the green light when it kick it just humms the fan motor is free
  • Robert Mar 14, 2011
    Which motor hums? The inducer or blower motor?
SOURCE: Green light stays on, red light blinks along with a buzzing noise
colman uses the furnace to power the attic vent fan . Cheaper that way I guess. It just supplies your attic fan with power so it will vent thus keeping your home a little cooler in the summer.
not a big deal. you can shut the alarm with a switch ot cut power to the alarm.
Posted on May 10, 2009
  • 221 Answers
SOURCE: Coleman Evcon (DGAT070BDD) fan kicks on but only
Your unit definitely is on a recall list. Go to http://www.dgatprogram.com/
Posted on Dec 31, 2009
  • 221 Answers
SOURCE: Coleman Evcon..... Inducer Adjustment
Just wanted to make sure you knew this model is on a recall list:
Posted on Jan 02, 2010
  • 2522 Answers
SOURCE: coleman evcon furnace
is the air filter clean afc could be dirty
Posted on Jan 22, 2010
  • 2522 Answers
SOURCE: I have a coleman evcon model dgat070bdf furnace.
Hi check the flame sensor is clean also check out the pressure switch , and check air filter is clean
Posted on Feb 05, 2010
When the furnace shuts down, blower kicks on and off
Probably residual heat kicking the fan limit control on and off. Readjust the settings on the fan limit control.
Nov 15, 2012 | Coleman Evcon Furnace Control Circuit...
Have a Evcon Coleman Furnace shows three green blinking lights but will not ignight what could be wrong
I have had the same problem with mine for the last 2 years. Remove the motor on the side of the furnace(usually held on by 3 screws) and turn the fan blades inside by hand. after sitting all summer it seems to get stuck. If it moves freely, replace the motor and try to start it again. This fixed mine the last 2 years! Hope this helped.
Sep 29, 2010 | Coleman Propane Forced Air Heater...
I have a coleman evcon system model BRHQ0301BC. The fan on the outside unit will not always kick on. When the fan does not kick on the AC does work. Need a manual for unit and help repairing the proiblem.
I don't have a manual but you need to check the fan capacitor and the fan motor windings with a multimeter. If the capacitor looks swollen then it is probably bad. Replace it with one of the same rating.
Jun 07, 2010 | Coleman Heating & Cooling
My Coleman Evcon heating and air unit will not blow air
bad blower motor. recommend a new blower motor and capacitor.
May 28, 2010 | Coleman Heating & Cooling
My goodman gas furnace is not kicking on. the light on the unit is saying that it should be working but it is not. there is no pilot light, the fan is working the heat is not
If you are not getting any codes from the board, then the furnace is not getting a call for heat from the thermostat. A wire may have come off, the thermostat not properly wired, or a break in the stat wire. On a call for heat, you should have 24vac between W and C on the circuit board. This will let you know if you are getting a call for heat all the way back to the furnace.
Oct 01, 2009 | Goodman GMS90703BXA Heater
Apr 19, 2009 | Coleman Propane Forced Air Heater...
I have a coleman/evcon heat pump. When the thermostat kicks on the contacts kick in and hum but the compressor nor the fan run. Is this probably my capacitor has gone bad?
I would check the hig voltage power supply to the unit. Check the main breaker and make sure it is on. Check the disconnect and make sure there is power at that point to the condensing unit. The contactor will kick in from the low voltage in the control circuit.
Jul 11, 2008 | Coleman Heating & Cooling
Heating & Cooling Logo
79 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
