Question about Line 6 Spider Iii 75 Guitar Combo Amplifier
The amp was working fine and than just stoped , it wont turn on and all power is working.
  • 15 Answers
The most likely problem in this instance is damage to the power supply, probably caused by a power surge. The second most likely cause is damage to the power cord. If you can take it to a shop that has similar amps on display, you can probably test it on one of there power cords. If the power supply is damaged, it will be a bit more challenging. At this point, if you know a bit about circuit boards and soldering, you might be able to fix it. If not, you will probably have to pay someone, or simply replace the amp.
Posted on Mar 14, 2011
It suddenly stoped working. Doesn't turn on anymore. What can it be?
Julio, If you already changed power supply and no success, it is probably a bad solder joint on board. I will post a link below that may help or you can try a forum.
http://roland.com/support/article/?q=manuals&p=GT-10
Feb 19, 2016 | Roland Boss Gt-10 Guitar Effects Processor...
No Power after Valves glowed bright
This could be a transformer failure. Take it to the repairs shop.
Jun 08, 2013 | Peavey Valveking Vk100 Guitar Head
I have a marshall mg100hdfx head. it was working fine and I turned it on it started screaming like feedback at full volume. it does this with all volume at zero and without anything plugged in the inp
This could be many things and unless you are electronically adept it is unlikely you can DIY the repair... HOWEVER I want you to try one thing first: Sometimes the contacts on the switches of the Effects send and return go bad leaving the input to the power amp section floating and it can feedback. To test this, plug an INSTRUMENT cable between the send and return effects jacks on the back. This bypasses the contacts, If the amp behaves, you could run it this way getting a short cable or have the amp worked on at a shop to replace the jack. The jacks are really rather poor quality on musical amps in general.
May 13, 2012 | Marshall MG100HDFX 100-Watt Amplifier Head
It just wont turn on, and i'v tried other power supplies that deffinately work and it still wont. help!
Use the correct PSC power adapter. 9 volts, 1 amp... not sure of the polarity... searched all over for the spec. The unit draws 900ma so you need a 1 amp supply. Most "universal" supplies will not provide enough current. If you have tried the wrong polarity you may have damaged the unit.
Sep 14, 2011 | Roland Boss BR900CD Digital Recording...
My amp, was working fine last night, it wont turn on, and i tried switching guitar, cables, even power supplys and still wont turn on, i heard a pop last time i used my amp, and then the signal was lost...
The unit will require repair and if you are not adept at electronics, you will need to take it to a shop. Likely there is failure in the power supply or amplifier that has blown the fuse. Replacing the fuse WITHOUT repairing the cause MAY do additional damage.
Dec 28, 2010 | Fender Hot Rod Deluxe Guitar Combo...
My bass guitar wont connect to my amp.
Assuming that the amplifier is functioning properly, I suspect that the problem is either in the cord, the plug socket on the bass, or the volume control potentiometer. First, I would try another cord that is known to be in good condition (ALWAYS plug the cord into the instrument FIRST). Second, carefully remove the cord receptacle plug from the bass and examine the solder joints (check for loose wires). Third, carefully remove the plate that holds the volume and tone pots. Examine these controls for loose wires or faulty solder joints. CAUTION: If solder joints are found to be the culprit, care must be taken to correct this problem. If too much heat enters the pot, it can be ruined!
Dec 31, 2009 | Music
Peavy viper 75 watt modulating amplifier stops getting power.
Your are on the right track. This fuse may look good but still be bad. once you in there all ways replace with new, it helps extend the life. 95% sure it s the fuse. If not it will need to go on the bench. Good luck DFD
Apr 11, 2009 | Peavey Music
Fender Rumble 100 210 pop noise then hum after strong low e note
I just fixed my bass amp with a similar problem last week: the problem is related to a loose connection on the PCB board (likely).
A bass amp is a rough place for circuitry: the low rumble and power shake a bass amp more than a guitar amp.
In my case, the power transistors needed to be re-soldered and then the grounding bolts and screws needed to be removed and cleaned because the connection was bad. Remember that when two different metals needed for an electric connection are toughing, there is the likelyhood that corrosion WILL happen.
My bass amp did basically the same thing yours did: sounded good at low volumes, but at higher volumes it would act up.
In short, there is nothing you can do (unless you are a repair person): you need to take it to a local music shop and have a tech fix the intermittant contact problem: someone who knows what they are doing should only take an hour at most.
Hope that helps!
-mike
Feb 22, 2009 | Fender Rumble 100 Bass Guitar Amplifier
Electric Guitar wont play through Amp
the buzzing is indicative of an open ground connection, check the cord by substitution or with an ohm meter, if the cord is good look at the connections to the jack inside the amp ( im guessing you built the amp from a kit). Is this a solid state amplifier? Tube amps have lethal votages and should not be experimented on without knowledge of electronic safety. Also if there is more than one input to the amp try plugging the guitar into another one and see if its still the same.
Dec 30, 2008 | Yamaha Electric Guitar
Line 6 Spider Iii 75 Guitar Combo Amplifier Logo
222 people viewed this question
Top Line 6 Music Experts
Vito Vacirca Jr.
Larry Stiles
Larry Stiles
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Line 6 Music Expert? Answer questions, earn points and help others
