Question about Kenmore 80883 Microwave Oven
Model 80083: Microwave works fine; cuts out after about 5-8 minutes. LCD shows "reset clock". After re-set oven runs for 1-2 minutes. Thermostate appears to be tripping, but immediately resets.
MicrowaveSvc
  • 9047 Answers
SOURCE: Clock Trips
Are you saying that the oven seems to shut off while cooking? Does it also happen if you cook at full power? This may be a bad connection on the controller (which we repair) or a failing magnetron. Please give usd a little more detail so we can follow up.
Posted on Sep 28, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Sanyo Microwave Oven EM-D9552SN - cutting out
It may be that the magnetron is running a little hotter with a smaller load: Since fewer microwaves are being absorbed, more are being reflected back.
It may be a bad connection on the control board or a bad relay.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
If not, maybe you can keep a microwave-safe container inside with about 1/2 cup of water to "preload" it. Some people do that, especially when making popcorn.
Posted on Nov 28, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Setting clock on Westinghouse WST3501 microwave oven
Normally you would press Clock, enter the desired numbers, then hit Clock or Start. Try it with door open and with door closed.
Otherwise, contact Westinghouse Small Kitchen Appliances at 800-947-3745 or see http://www.saltoninc.com/contact/contact.html
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 13, 2007
jyackle5
  • 8197 Answers
SOURCE: how do I set the clock on a GE Spacemaker microwave oven?
You can get the manual here.
http://www.retrevo.com/s/GE-JVM1640SJ-Microwaves-review-manual/id/1080ci954/t/1-2/
But usually you just press the clock button to set
Good Luck and Please Rate Fixya!
Posted on Jan 10, 2009
garing
  • 998 Answers
SOURCE: Microwave Totally stopped - nothing turns on HELP Needed
check fuse
Posted on Aug 08, 2009
My microwave display is showing "Lock" and I can't change it
The first thing I would suggest is to consult your manual to see if the child lock is on.
Next is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it's still not working, you may have a bad keypad or moisture or some kind of residue or grease on the control circuit board that's causing a shorting condition.
If you think that may be the case, we would need the brand and full model number to give you further free help.
So you'd need to post a new help request here with brand, model, and detailed symptoms.
Feb 21, 2011 | Microwave Ovens
GE spacemaker Power goes off and clock needs resetting
Try going to the breaker box and shutting off the power to the microwave for 10 minutes. After 10 minutes, turn back on and set the clock. This fixed my clock and turntable both. Apparently turning off the power resets the software in the clock.
Jul 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave does not work.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
You may have a failed keypad or control board.
We repair these for customers nationwide with our guaranteed $39.95 service.
Aug 07, 2008 | Whirlpool GH7155XHS Microwave Oven
I have lost instruction book for Sharp Compact R250A microwave oven-how do I reset the clock?
May be a little late, but... 1. Press Power Level button for approx 5 seconds - you get the 12 hour clock 2. Press again for 24 hour clock 3. Set hours using the 10 min and 1 min buttons 4. Press Power level button 5. Set minutes using the 10 min and 1 min buttons 6. Press Power level button And you are done
Gert
Aug 05, 2008 | Sharp Microwave Ovens
How do i set clock for time of day
You can download your owner's manual free here.
From the manual:
SETTING THE CLOCK - When the microwave oven is plugged into an outlet, the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been
set, the time will appear with blinking colon,
unless the oven is cooking or defrosting.
NOTES:
- To reset the present time in the display window when the oven is off, press the CLOCK button and
reset.
- If you make a mistake when setting the time, press the STOP/CLEAR button.
- To recall the actual time while the oven is cooking or defrosting, simply press the CLOCK button
and the display will show the actual time for three seconds.
Jul 03, 2008 | Emerson MW8107WA Microwave Oven
We are house sitting for friends. They have a Miele Classic, wall mounted combi oven. It has a single dial at the top left of the silver facia. To activate the microwave, I turned the dial one click...
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Please reply back with your brand and full model number.
May 11, 2008 | Microwave Ovens
Microwave suddenly stop working
Apr 04, 2008 | Samsung MW1030WA Microwave Oven
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I have an Emerson Microwave Oven MW8997W and cannot change the hour (time) on my clock. How do I change the clock? Debbie
If your keys do not work at all, you probably have a bad keypad, in which case I'd ask you to reply back. In the meantime:
SETTING THE CLOCK
show the present time. After the clock has been set,
the time will appear with blinking colon, unless
You can actually download your owner's manual here
Mar 10, 2008 | Microwave Ovens
Timer Shuts off after 5 seconds
Is it 5 seconds or 5 minutes? The difference coulsd be important, but either could indicate a bad magnetron.
Let us know if the hard reset doen't fix it.
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 18, 2007 | GE JES1289SK Microwave Oven
Kenmore 80883 Microwave Oven Logo
37 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
