Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
The ice cube indicator is blinking - Sub-Zero 650 / O Bottom Freezer Refrigerator
  • 29 Answers
From the manual:
The Control Center monitors refrigerator and
freezer temperatures as well as the ice maker
system. If there is a temperature or ice maker
problem, you'll be alerted by a flashing
SERVICE indicator light. This same SERVICE
light will also flash if the condenser needs
cleaning. Before calling for service, please
check and see if your condenser area needs
cleaning. Refer to Condenser Cleaning,
page 22.
CONDENSER CLEANING
In all Built-In models, the condenser is located
behind the grille. First, remove the grille. Then
using a soft bristle brush, vacuum to remove
dust and lint from the condenser. NOTE: To
avoid bending the condenser fins, be sure to
vacuum in the direction of the fins (up and
down). Clean the condenser area every three
to six months.
CAUTION
Before cleaning the unit, shut the electricity
off at the control panel. When you
clean the condenser, wear gloves to avoid
injury from the sharp condenser fins.
Failure to clean the condenser could
result in temperature loss or mechanical
failure or damage.
Posted on Mar 14, 2011
3 Suggested Answers
  • 103 Answers
SOURCE: can't make ice cubes only crushed ice
Hi: There is a flap right where the ice dispenses. When you remove the bin you will see it when inverted. This flap has to open for the ice to be cubed. You might rember a slap as it swung open when it worked. There is a bar that runs from the flap to the back of the dispenser. Work it manually to see if it's jammed or broken. If not look at the back of the freezer and remove the metal panel if neccessary, to find the jam or defective part. I hope this helps, Jeff
Posted on Jun 03, 2009
woodchuck789
  • 4059 Answers
SOURCE: Dispenses crushed ice and will not dispense ice cubes
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Posted on Aug 17, 2009
Help! Our ice cubes are frozen but not dumping and our tray is filling up with water fitting a solid sheet of ice. Can anyone help? Thanks
Hello;
My name is Peter. I am a retired field refrigeration technician.
It sounds like your ice maker has a bad motor module/circuit board.
It is like a control board. This module reads a temperature sensor that indicates the water is frozen and ready for harvesting the ice cubes. Then it turns on a electric heater under the ice cube mold, then turns on the motor to harvest the ice cubes. After the ice cubes are harvested, it opens the water supply solenoid valve to fill the mold with water. The ice maker needs to be replaced.
Feb 27, 2016 | Liebherr Refrigerators
Refrigeration code on scotsman ice machine model cme506as-32f.What could be the cause?
Unit is off& Refrigeration diagnostic light is on or blinking. Possible Cause,( Low discharge or long freeze cycle. Probable correction, if the Refrigeration light is glowing steadily there is a probable refrigeration problem.) 2. Possible cause. Harvest problem. Probable Correction. If refrigeration light blinks once and repeats, Look for a harvest Problem.**On Controllers 17-1 and higher, This also indicates that cubes were (sensed) by the bin controls. 3. Possible Cause. Hot gas valve failure, Probable Correction. Check hot gas valve operation. 4. Possible Cause, High Discharge Temp. Probable Correction, If the refrigeration diagnostic light blinks 3 times and then repeats, check for a reason for high discharge temperatures. 5. possible Cause, Harvest problem. Probable Correction, Controllers 17-1 and higher, if the light blinks 2 times and repeats, check for a harvest error- no cubes sensed. 6. Possible Cause, Unit dose not go into harvest - exceeds maximum freeze time. Probable Correction, Push and release off button. Push and release Freeze button. Check operation. next Push cube size float down and check operation. 7. Possible Cause, Exceeds maxi harvest time. Probable Correction, Check for cause of long harvest cycle. Try not to put any gauges on system until you have to. Every time you do you loose refrigerant out of the system.
May 02, 2014 | Kitchen Appliances - Others
GE refrigerator is not making ice
There are several types of ice makers with the same model number. Some of my questions may seem over - the - top, but I do not know your level of ability. Do not take offense.
Did this ice maker ever work before, or is it a newly installed maker or a factory installed maker in a new fridge? Have you moved the power switch to on? If yours has an LED power indicator, is it off, blinking or on? Off means there's no power to the maker - you'll need to get the maker powered up before going further (make sure the electrical power connector is mated fully). Blinking means cubes have become stuck in the maker. You'll have to shut the maker off, remove the cubes then power up again. On means it is powered and is working normally. Is the freezer compartment set to maintain a temperature lower than 15 degrees F (-9 C)? The ice maker will not make ice unless the temperature is below 15 F (-9 C). The space under the maker must remain clear of obstructions so that the sweeper arm is not blocked (when blocked indicates a full ice container and will halt ice production until the arm can move freely again). The maker may need as many as 3 cycles (approx 6 hours) before all the air in the ice maker's water lines have been purged completely.
Listen for the solenoid valve to operate. Every couple of hours, this valve should operate and an audible click on and click off heard after a several seconds (as long as set on the ice maker cube size adjustment knob). When this solenoid has clicked on, water should be flowing through the lines and filling the ice maker. If not, there is an obstruction that must be cleared. A dirty or improperly installed filter, pinched line, and even ice can interrupt flow to the ice maker. You might need to remove the ice maker from the freezer to check the water supply line that feeds it for the presence of ice. Melt / clear as needed.
Jan 23, 2012 | GE GSS25LGM Side by Side Refrigerator
My Windchaser ICM12 will not work. The cube size indicator blinks constantly. unplugging the unit to reset does nothing. What is wrong?
What I tried is to manly rotate the water trough that has the swing gate & pushed the Stop button. No results. I then tried rotating it back -n-forth several times, unplugged, replugged, posed Start, AND IT WORKED!!!
Jul 18, 2011 | Windchaser Freezer ICM15 Portable Ice Cube...
I got a new french door frig and it wont make ice CUBES. It makes ice and even though the indicator says cubed ice, it comes out crushed. Is there a way to fix this easily. Otherwise i like the frig very...
Try removing the ice bucket and ensure that there is no obstruction (ice cubes stuck inside of metal blades). If no obstruction, then your problem may be in the electronic dispenser control board (if applicable) that distinguishes between cubed and crushed ice. If it appears that the problem is the board, then contact an appliance service company.
Feb 10, 2010 | Samsung RF265AA Bottom Freezer French Door...
ZIS480DRISS NO MAKING ICE CUBES
FINGERS THAT EJECT THE CUBES WAS JAMMED ON WHITE PLASTIC. REMOVED ICE MAKER THAWED CUBES IN THE TREY AND PRYED AWAY THE WHITE PLASTIC COVER. RE-INSTALLED
Jan 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My ge profile ice machine on off light is blinking and not making
Blinking light indicates a fault with the icemaker. Look for a blockage preventing the ejector from making a complete revolution, such as a cube that was not cleared, or some other mechanical blockage. All other faults are icemaker component, which are not available as separate repair parts, which would require replacement of the entire icemaker assembly. Please don't rate this if you need a new icemaker, as anything less than a Fix-Ya lowers my score. Thanks.
Jan 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
General electic gsh25jfta bb
According to the manual for your refrigerator:
Blinking green light indicates an ice cube is stuck in the icemaker. To fix - Turn off the ice maker with the on/off switch. Then remove all of the ice from the icemaker by hand and turn it back on.
I hope this helps.
Jul 19, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Frigidaire ice cubes coming with square edges...
Get a life, sharp ice cubes? The edges melt and the problem goes away.
Jun 21, 2008 | Frigidaire FRS6R5EMB Side by Side...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
883 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
