I have a cable ready television. To this television the HD receiver is connected, this is the television that I would like to connect the DVD recorder to. With all the information that I have obtained to do this I am not sure if this would work also would I have to purchase another cable to do this properly.
    Genius:
  • 1,112 Answers
Hi:
You need to provide more information on what type of
TV you are hooking up. With a model number there is no waw to determine how you should connect your DVD, but if you have composite video connections on the back or front of your tv then you should use these inputs. but if you have componet connectins which are the Green,Red,Blue you should use these conn's for better viewing.
Posted on Mar 30, 2011
Hi, how can you connect my Mitsubishi ws-73909 to HD? Do I need some sort of an adapter? HDMI - VGA adapter , HDMI - RGB adapter, or etc...? Thanks for you help!
Are you trying to connect this tv to an HD device like a satalite receiver or a cable box. If so you will need an HDMI cable which cose between $20- $60 and your cable or satalite received must be HD ready.
Jul 21, 2011 | Mitsubishi Televison & Video
When trying to connect a phillips soundbar/dvd player into my tv using the HDMI cables/ports - it said it was not HDCP compatible. We tried teh different HDMI ports
If this equipment does cause harmful interference to radio or video reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures:
  • Reorient or relocate the receiving antenna.
  • Increase the separation between the W4207 HD Monitor and receiver.
  • Connect the equipment into an outlet on a circuit different from that to which the receiver is connected.
  • Consult the Westinghouse Service Center or an experienced technician for assistance.
DVI CONNECTION: Connect a Digital DVI cable from your computer to the W4207 HD Monitor DVI port. Using a 3.5mm mini cable to RCA Red/White (Left/Right) audio converter cable, connect the 3.5mm cable plug into the computer
Dec 13, 2010 | Westinghouse W4207 42 in. HD-Ready LCD TV
I have a Panasonic Tx l37S10B tv set, & a PanasonicDVD recorder,DMR-EX768EB. To ensure I receive true HD i have bought a Humax Fox T2 hd Digital receiver. I use these items to receive & record HD...
You didn't fully expain how each device is connected to the others. I don't think you have this set up correctly. Your DVD cannot record in HD so there is no point sending an HD signal to it - it can't process it. This is how I would set it up:
1. Install a 2-way splitter on the input cable
2. Connect output 1 from the splitter to the Humax receiver
3. Connect the Humax receiver to the TV with an HDMI cable
4. Connect output 2 from the splitter to the DVD
5. Connect the DVD to the TV with SCART cable.
This will enable you to watch HDTV via the digital receiver and also provide an input from source (dish/cable) to your DVD player so that you can record.
If you've already set it up this way then it should work. I suspect you've connected the Humax to the DVD and TV and also the DVD to the TV.
Please try this setup and post back if you need further assistance.
Nov 04, 2010 | Panasonic Televison & Video
LC-26DA5U 26 in. HDTV-Ready LCD Television: i connect a hdmi cable 2 my hd cable box - the pic...
The cable box needs to be set to send different signals when using hd tv and standard tv. Usually a good setting would be 720p in hd and 480p in standard. The tv is working fine it is the cable box sending the signal. If you have another hdmi source such as a dvd player you may hook that up to show the tv is working just fine.
May 07, 2010 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
My toshiba television is receiving sound but no picture
If the tv is connected via an S-Video connector then this must be set up in the AV menu ie scart 2 = S-video
Mar 13, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
DTV connection question for Mitsubushi WS55857
Yes, You would need to use a HDMI to Component converter to make the connection. They are in the $200 to $300 range.
Dec 27, 2008 | Panasonic PT-53WX53 53" Rear Projection...
How to connect new HD cable box to receiver
HI:
You are using a new HD Cable box, that are using componet video cables for HD, Unfortunetly this receiver does not have componet inputs, so you will just have to run the audio from the televison directly to the receiver by connecting the video out and audio out from the television to the receiver's video Input one. This will require a normal RCA composite cables yellow,red,white. Connect one end of each of the cables to televisions output terminals, and the other to the input one on the receiver. Note: Your TV might have a seperate term called Monitor out, Connect the yellow here, and the red and white to audio out. You can do the same for the DVD but you have to use the same cables,Also the television will not display HD picture this way as this is not a HDTV Receiver. If you just want TV sound to the receiver then do not use the video(Yellow) cable just use the audio out terminals from the tv and connect to Input one on the receiver. you can do this with the cable box also but you have to use RCA type cables . If you want the full HD experience then a new up todate receiver is necessary.
Dec 06, 2008 | Sony HT-DDW740 System
Picture goes blank but audio on
If you are using component cables to connect your HD box to TV. Make sure your connections are tight. You should make the colors match up. Green, Red, Blue. Check on both TV and HD box. Make sure HD pox is powered on. Make sure to select TV input to Component 1 or whichever you are using. If this doesn't work you may need to call and have COX refresh the HD box. This can be done over the phone. This will make sure you are receiving and sending the proper signal level. Good luck
Oct 05, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
RCA HDTV, indoor antenna and Dish Receiver 311
I want to use two (2) 311 dish receivers with only 1 outside antenna.
Jan 08, 2008 | RCA L32W11 32 in. HD-Ready LCD Television
Connection for tv cable to hitachi 42" plasma Tv
there is no cable slot. the monitor is not a receiver. it has no tuner in it. it will need a signal from a tuner box. and that must be fed to the tv with an hdmi cable or a dvid cable for hd to work. see your manual for further information on cables. see your cable supplier for information on hd boxes available in your area. if you do not buy hd service, you will not get an hd signal. so you will see little difference from a non hd device. your dvd player may have hd capabilities, but will also need the same cable to deliver true hd signal.
the good news is that its fixable by using the right equipment.
good luck
mark
Dec 07, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
