Question about LG WM2277HSW XL Front Load Stackable Washing Machine
WM2277HS front loader , the drawer to put the detergent in is stuck, how do I get it open?
I have slightly different model. Tried the remove the top option. It turned out the the drawer assembly had removable top, removed to two screws that held the assembly in place, uncliped e front assymply drawer handle and cleaned out the soap deposits. Soap build up under dispenser parts had caused the problem. It seems like running the machine a few times might have cleared the soap.
Posted on Jul 29, 2012
MNTECH
  • 1543 Answers
SOURCE: Detergent dispenser drawer stuck
You may have to remove the washer top (three phillips screws at the back, then push top back about two inches and lift it off) then drill a hole in the top of the plastic dispenser to allow you to use an object like a screwdriver to maneuver the offending part around so it will drop down and allow you to open the dispenser drawer. Use foil tape to seal hole if you don't want to buy a new dispenser. Clean out blue plastic dispenser parts so detergent will siphon out completely. Pushing down on the center tab at the back of the dispenser should allow you to take the dispenser drawer the remainder of the way out. In the future, make sure you do not use over 1 tablespoon of HE soap (and 1 teaspoon of fabric softner) max per load. Even less if you have 2x or more detergent.
Posted on Oct 11, 2008
SOURCE: Can you use Oxyclean along with detergent in front loaders?
I use 2 Tablespoons of Liquid Detergent and a 1/2 to 3/4 scoop of Oxyclean and I have had good results in my Front Loader. Clothes come out very clean and there is no residue on the inside of my washer.
Posted on Oct 07, 2008
  • 43 Answers
SOURCE: Leaking Water
try pouring boiling water down soap draw possible blockage due to cheap wash powder take off lid and massage down pipe then put on wash with no clothing
Posted on Nov 10, 2008
SOURCE: front loader LG washer drawer for detergent is stuck won't open
Remove the top of the washer by removing the 2 retaining screws (phillips head) from the back of the unit & sliding the washer top back about 2" & pulling up. You will see a white detergent dispenser box with several hoses coming off the back in the left front of the unit (this box contains the detergent drawer). The lid to this box is held on by 8 pressure snap clips. You only need to release the 4 snap clips (3 large, 1 small at the rear) on the right side of the box (nearest the washer drum). Pull up on the right side of the lid while pulling out on the detergent drawer. It should come out normally. Do not reassemble until you read below, then reverse the steps to put the washer back together.
The problem will be the "softener" lid (blue). It will not be sitting down in the drawer assembly & will catch on the lid of the white detergent dispenser box. Simply remove the blue lid to avoid future jambs. It only serves to identify the fabric softener recepticle & it keeps fabric softener from splashing around when water enters the system. You may need to remove the entire detergent drawer periodically to clean (push down on the blue thumb indent inside the drawer to release it from the housing).
Hope this keeps you from drilling through the lid & ruining a $23 part, like I did.
Posted on Jun 16, 2009
SallyUK
  • 9 Answers
SOURCE: which compartment does my detergent/fabric softener go in?
You can get all of Whirlpools user guides here:
http://www.whirlpool.co.uk/app.cnt/whr/en_GB/pageid/pgsrvifuhome001/ifu/home Generally the one one the left - is for pre-wash (if clothes really soiled), the middle one is for powder (if you use it) and the last one is for softener or bleach.
I just use liquitabs - which go directly into the drum, and fabric softender.
The soap drawer won't open. Never had this issue before.
Is the machine a front loader? Is the drawer on the front of the machine? What is the Brand? I have a Samsung front loader and my detergent/bleach & softner drawer pulls out from the front. There are two drawer release locks on the drawer track (one on each side) if the drawer will give you any wiggle try pulling or pushing up gently. This may unlock the track. It sounds like the drawer was pushed in too hard... hope this helps
Oct 13, 2014 | Asko W660
When in wash it dosent remove all soap powder from clothes
I don't know how you are administering the soap powder to the machine..but for one, its recommended that you use detergent thats made exclusively for the front loader washer, usually says "he" on the front of the LIQUID detergent, they recommend that you use liquid detergent on top of that, BUT if you have to use regular powder detergent it must be put inside the tub and NOT the pull out detergent drawer. The reason why they want you to use liquid is because the powder detergent is not concentrated and when you use it, it lathers up alot and its harder for the front loader machine to clean out the clothes and I was told that they (sales agents) have heard of soap suds and bubble floods coming from the machine due to either using the powder detergent or using too much. Hope that this helps!!
May 15, 2010 | Zanussi ZJ1217 Front Load Washer
Water is pouring out of the detergent dispensing drawer from my 1 year old Samsung clothes washer model WF328AAW. When I opened the drawer, it was full of water. Something must be plugged. Is there...
Pull the drawer out you will find detergent has built up in side the dispenser probably from from way too much detergent, modern front loaders work best with a small amount of detergent and liquid detergent normally will wash better.
Apr 17, 2010 | Samsung WF203ANW Front Load Washer
Softner in detergent drawer dispence at the wrong time
Take off the top of the front loader, topfrontleft is the dispenser, there is a movable part that was incrusted and unablble to freely move, clean off parts, little water will do, the movavable piece should move back to the roman numeral one, it is spring loaded, put top back on, done.
Dec 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Laundry detergent drawer stuck
I had the same problem - the fabric softener cup cam loose and I had to break it to get it out and the new drawer cost me about $65 to replace. I hope you made out better than I did.
Dec 13, 2009 | LG WM-2077C Front Load Washer
Front loader LG washer drawer for detergent is stuck won't open
Mar 26, 2009 | LG WD-16115FD Front Load Washer
Detergent drawer will not open
Here's a possible solution: Remove the two screws on the bottom side of the plastic clips on the back of the washer (leaving the clips attached to the washer's top), then use the palms of your hands to sharply push the top back about an inch and a half and lift the top off the machine. Now, if you can see enough through the translucent plastic to tell where the hang up is, you can drill a small hole in the top of it to allow you to push that part down so the drawer will open. Then, use foil duct tape to seal the hole.
Jan 12, 2009 | LG WM-2277HW Front Load Washer
Liquid bleach tank WM2277HS
Liquid bleach tank? Do you mean the small container one puts fabric conditioner into for the final rinse?
They have a siphonic action. In normal use you put a small amount of liquid into the tank and when the machine starts the final rinse, water is added. Once above a certain level the siphon starts and empties the tank into the machine.
Take the drawer out of the machine, put it in the sink and slowly run water into the tank and you'll see that the level rises to a point then the tank empties.
So, perhaps you are adding too much bleach (or whatever) and the liquid is siphoning out before you even close the drawer.
Or do I misunderstand your problem completely?
Steve
Dec 30, 2008 | LG WM-1485FHD Front Load Washer
Hoover Nextra washing machine - water backing up
If this is a front loader see that u use only washing powder for FRONT LOADING MACHINES. Also possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine.
Oct 07, 2007 | Washing Machines
Washing Machines Logo
478 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
