Question about Hotpoint RB526 Electric Kitchen Range
I have a Hotpoint electric range. Model RB526. It is only a couple of yrs old. The oven temp is too hot. I set it at 350 degrees and it heats up to 400 degrees. Set it at 325 degrees and it goes to about 375 degrees. Is it a simple fix that I could do myself?
Tech007
  • 63 Answers
SOURCE: Electric Oven very slow to heat
cheak for 240 volts coming out of your wall if it reads 120 volts it is your house breaker
Posted on Aug 29, 2007
SOURCE: Possible Control board problem
You may not necessarily need a new control panel. Sometimes the oven temperature can be calibrated. Look in your owner's manual (if you have one) for calibration instructions. This will usually take care of the problem. If not, you may have to replace the oven sensor located inside the oven in the upper right or left hand corner of the back wall. Good luck.
Posted on Feb 08, 2008
hemantraj
  • 638 Answers
SOURCE: Hotpoint RGB747GER oven does not heat properly
www.repairclinic.com
Posted on Aug 18, 2008
SOURCE: Amana Gas Stove M/N ARG 7302WW set temp. is higher than desired t
the oven safty valve is goin bad. that the part that most oven burners sits on.
Posted on Dec 09, 2008
  • 100 Answers
SOURCE: oven temp low. recalibrated up 35 degrees, 375
no you need to still recalibrate the unit if your using the baking style thermo they are famous for being off 75 degrees
Posted on Aug 09, 2009
Why does the control panel on my Whirlpool electric range get too hot to touch when oven is operating at 350 degrees?
heat transference and radiated heat at that temp is normal
the stove should have an air gap between unit and wall
not pushed up against the wall
and internally insulated
check to see if your whirlpool model oven ever had a safety recall 26301150-vpuqtjtdvoowntuyvcl35auo-4-0.jpg
Oct 04, 2016 | Whirlpool Kitchen Ranges
Oven temp fluctuates
It is normal for the thermal device to turn on and off. Obtaining a steady temp is not always possible. When setting a temperature on some ovens, they have what is called a tolerance point. That means a set temperature has a range of a few degrees up or down. At the Down point, the oven is triggered to energize the coils and bring the interior of the oven back to the settings desired. The other factor is opening the oven and allowing cool air to enter, or in some cases a leaking door seal allows air to enter and heat to escape.
Feb 26, 2014 | Kenmore 30" Slide-In Electric Range...
The oven will pre heat to set temp, then when it reaches temp the oven beeps and both oven elements turn off. At this point the control panel (clock LED) shows an F2 error.
Good afternoon.
F2 for hotpoint means oven temp sensor thinks oven exceeded 650 degrees .Did that happen?
Probably not so have your sensor checked or replaced. It should be a probe device in oven back wall.
Was this helpful?
Aug 16, 2011 | Hotpoint RB787 Electric Kitchen Range
Oven takes 30 minutes to heat up to 350 degrees
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Feb 25, 2011 | Hotpoint RB757 Electric Kitchen Range
On my Hotpoint RB787 range, how can I prevent my broiler element from being on any time the oven has been turned on?
There is no adjustment. When set to bake, BOTH elements are supposed to heat. On broil, only the top heats. To answer your question, you can't..........
Mar 31, 2010 | Hotpoint RB526 Electric Kitchen Range
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 | Ovens
My oven heats up, but then does not maintain the temp.
If it has a pilot then I would say the thermal couple is bad. If it has a glow type ignitor then the ignitor is bad.
Sep 02, 2009 | Whirlpool GS460 Gas Kitchen Range
MY OVEN IS BAKING AT A LOWER TEMPERATURE
Check to make sure the broil element works. If so then change your oven sensor.
Nov 16, 2008 | Hotpoint RB526 Electric Kitchen Range
Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Mar 30, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
Hotpoint RB526 Electric Kitchen Range Logo
44 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
