Whenever I insert the charger into my phone, it cuts off. Same thing happens whenever I try the USB connection. The phone cuts right back on as soon as I pull out the charger and will not turn on unless I do so.
  • 51 Answers
Keep the charger in and see if while the phone is off it is charging, it may be the charger or it may be a setting on the phone, maybe a phone model or brand will help answer the question.
Posted on Mar 14, 2011
I have a LG KP107b phone . from past two days my phone switch off automatically whenever i connect my phone to charger. with attached charger i cant switch on my phone but once i removed the charger and...
Why the phone goes off when you connect the charger is because the connection was not straight up, so it will turn off the phone and it will go blank. When it does that, you just have to remove it, turn off the phone and remove the battery and insert it back in, then you fix in the charger before connecting it to the power outlet.
TIP: Always attach the charger into the phone first before you connect it to the power socket or outlet. That way it will never trip off when you attach it to the charger.
Thank you for using fixya
Caseytech
Jun 29, 2011 | LG Kp107 Cell Phone
My GPS screen says "USB Connected" whenever the
your cord has a short in it. Try to fix it or buy another.
That happened with my Magellan last month when the silver square connector started coming out of the cord. Try pushing it back in, but they do short out there at the connector for some reason
Feb 23, 2011 | Magellan Maestro 4350 GPS Receiver
My Nokia X2 is not connecting to he computer using the USB cable.I accidentally removed it once when it was connected without disabling the USB connection. Now whenever i try to connect using USB cable it...
hey man,,to solve this just take out your memory card first and then go to setting then select restore factory setting then select all then select continue,,,,the phone will ask you to key in your security number so just key in your security number then wait for the phone to restore back all the setting,,,problem solve,,,
Feb 08, 2011 | Cell Phones
Whenever I insert charger into cigarette lighter, I get the charging screen only and cannot access maps unless I disconnect charger
sounds like you have a charger that is not compatable with the unit, have you changed the charger? try pluging it into your pc with a mini usb and down loading software updates from the maker of the gps, or getting a genuine charger
Dec 06, 2009 | Cars & Trucks
My name is samuel adjei boadi from ghana. the fault of my phone is that the z310i happens to be a new phone.whenever i charge the phone with a charger, the phone stops charging or switches off.when you...
there was a connector problems with your sim card and the battery connectors please try to stretch it to up and try again.........if you dint get what i said call me on my mobile +91 9704788855
Dec 05, 2009 | Sony Ericsson Z310i Cellular Phone
Problem with Data storage devices
check the usb ports or drivers if those are your connecting port and get the right drivers from the MOB manufacturer
Dec 01, 2009 | Intel Computers & Internet
N70 not charging
Here is a generic solution for all mobilephones!
This problem could be caused by either battery, charger or firmware failure. you can try the following to secure which!
-Try your mobilephone with another charger or connect it to a PC using a USB cable
> if ok? the problem is your charger!
-Try your mobilephone with another battery
> if ok? the problem is your the battery!
-Try your battery and charger on another phone
> if ok? the problem is your mobilephone/firmware :(
If you dont have access to other phone, battery, charger or USB-cable you can at least try the steps below:
1. Turn off your mobilephone
2. Take out your battery, Sim-card and memmory-card
3. Connect your charger
4. Put the battery in
5. Turn on the phone
If it doesn't help, with a little luck! you should get a USB-cable, back yor phone up and reset it to factory default and upgrade your firmware/software on the phone to the latest version!
OBS! You should only do it with a fully charged battery! or you could damage your phone irreversibly!!!
Jul 12, 2009 | Nokia N70 Cellular Phone
Everything on my phone works fine except for one thing, the internet doesn't work whenever i try to connect it says 'communication error. please check your settings' plaese assist me with this...
Try delete any existing connection .If not work then reset to factory setting ...for do that You have press & hold two buttons on top left & right button at that same time insert the stylus in the hole provided near charging point...
Nov 29, 2008 | Cell Phones
PHONE TURNS OFF WHEN I CHARGE IT
Both of my e815's had this same problem. I was able to remidy it by taking a tooth pick and cleaning the contacts where the phone charger plugs into. Since I have done this neither one of my phones turns off when it is plugged it. Hope it works for you too!
Dec 10, 2006 | Motorola Mobility E815
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
