Question about Toshiba Satellite A135-S4527 Notebook
My Toshiba laptop is stuck on the Toshiba screen when i turn it on? It gives the option F2 setup and F12 for Multibooting when I push either it says please wait but nothing happens?
    Guru:
  • 689 Answers
1]--try waiting for an unreasonably long period (10)min's without touching the keyboard.
2]--re-install operating system with correct recommended system
3}--check manual/manufacturers site to see if you can restore factory settings another(hotkey) way
Posted on Mar 14, 2011
    Scholar:
  • 89 Answers
Please disconnect all external devices (printers, USB hubs, USB drives, etc...) and then boot up at the same time press F8. Try to use the "Last known good configuration" from the Windows Advanced Options menu that will come up. If this option resolves the issue then look for any updates or software installs that may have caused the problem.If it won't, then boot to "Safe Mode" and try system restore. If all fails, then you need to perform re-installation of the Windows OS.Good Luck!
Toshiba Satellite L355D-S7815 had windows 8, opened up laptop and cleaned all the dust out and now when i turn the laptop on it shows the Toshiba screen but no F2 or F12 option's.
What you are talking about is called no POST. You either shocked the cmos and the bios wont load or something is not hooked up right.
Mar 21, 2013 | Computers & Internet
When starting it appears normall gives F2 and f12 option after that the screen becomes black
Was the laptop on? Projector on?
If so this = No.
Toshiba Satellite C600 specifications,
http://egadgetsclub.com/laptops/toshiba-satellite-c600-notebook-review-specifications/
Intel Pentium Dual Core T4500,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_microprocessors#NetBurst_based_Pentiums_2
Go to F2 option. That should be - enter BIOS Setup.
Look at the main menu (Which it automatically goes to)
Or use Down Arrow to highlight Standard BIOS options, and press Enter key.
Is the Harddrive listed? HDD0 has harddrive info listed to the right?
(HarDDrive0)
Post back in a Comment.
Regards,
joecoolvette
Mar 18, 2013 | Computers & Internet
Hi my lenovo g570 gives F2 and F12 options when switched on,but wont start the laptop
hit f2 finish setup, boot from hard drive
if this helps please rate with comment
Feb 02, 2013 | Computers & Internet
How do I enter setup when there is no option to enter
F2 is your bios setup, and F12 is the boot order selection, if you cannot access the two options there is no other way. That shows up when the Toshiba logo is visable. If your windows run properly I would not risk formatting the hard drive. But it might be worth contacting Toshiba, customer and technical support about the unusuall situation.
Mar 14, 2012 | Toshiba Satellite A55-S106 PC Notebook
My toshiba satellite l455 won't start up it keeps going 2 toshiba home screen and telling me 2 push f2 or f12
click on F2 and that will take you to the Bios setup, check that your hard drive and Ram (Memory) are both online if all is ok and no problems press F12 it might take you to a diagnostic screen prompting you to perform a diagnostic test, if so do the tests and write down any errors given, if there is not diagnostic tool you might get the options to restor factory defaults this option will reset your computer to its original state and you will lose all your data. Another option if you have the operating system's cd (windows xp, vista etc) from the bios (F2) change the boot sequence to cd (just click on Cd/DVD Rom)only and reboot, windows will ask you if you want to repair, if all your hardware is ok and you should be able to solve the problem good luck and all the best
Jun 06, 2011 | Toshiba Satellite L455S5000 Notebook
Hello, the problem with my mini toshiba nb200 is that when I on it, it shows the initial screen which says ; TOSHIBA Leading Innovation >>> Press [F2] for ...
If you are getting the Toshiba Select F2 or F12 screen the mother board has finished with POST.
Toshiba laptops are very good normally but don't boot up if there is a device in the USB slot or a CD/DVD in the drive.
If it still refuses to POST, remove the AC Adapter, remove the battery and remove the hard drive.
Power the unit up without the hard drive and it should complete POST and complain that there is no hard drive. If that doesn't work remove AC adapter, ensure battery is disconnected and remove hard drive and RAM. Try again. If it still doesn't work, you have a mother board fault and it needs a service centre. www.Toshiba.com will help you out.
If it does work at one of the options, when you have closed the laptop down, replace the RAM first and test, then the Hard Drive.
Hope this fixes your problem.
Feb 05, 2011 | Toshiba Satellite A205-S4617 Notebook
It is stuck on the " acer empowering people" screen it gives me options at the bottom to press F2 for setup and F12 to change boot order but when i press either of these nothing happens ive tried...
try restarting and push esc a few times should go to boot option screen ,,set it to boot from hdd,,or jus put ur cd that came with or windows disk and repair,,,,,check acer website also
Nov 03, 2010 | Computers & Internet
After turn on is asking for password (bios) and no body set up any password.
Hi, "Reboot" the Computer, look at the bottom of the [Screen] there will be (2) two, "Options" F2 for {Utilitiys Setup} and F12 for [Boot Options]; you want to "Press" the F2 button immediately at "Startup!" Once your in the Utilities, you can change the [Password]. If all go well, let me know by giving a "helpful rating," thanks.
Jun 21, 2010 | Toshiba Satellite A215-S5837 Notebook
Toshiba Satellite M100 Laptop fails to boot
trying holding the F8 key and they may give you a recovery option which could be the only way you can get your system up and running
Dec 07, 2008 | Toshiba Satellite A100-S8111TD Notebook
Entering the bios
There is 2 way to enter, you can use Toshiba HW setup for BIOS setting from windows. Alternately you can hit ESC several times after turn on the computer and hit F1
Good Luck
Jun 18, 2008 | Toshiba Satellite A15-S127 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
244 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
