Question about Whirlpool GX5FHTXT Bottom Freezer French Door Refrigerator
I am getting a loud buzzing noise when it kicks in any ideas?
  • 4,102 Answers
Hi, the problem you are having could be down to a couple of things, now the first and most likely cause is that its not sitting dead level and this causes it to vibrate more so try moving it slightly, now the usual cause is down to it touching a cupboard or other appliance this to is solved my moving it slightly, so have a got at moving it about a small bit and you should find the noise will stop.
let me know if it dont ok
Posted on Mar 14, 2011
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
The e t c is buzzing what is causing this
ANSWERS: Oil Loss, Buzzing Noise, ETC. - Nissan Forum ' Nissan Forums
forums.nicoclub.com/answers-oil-loss-buzzing-noise-etc-t323273.html
Mar 20, 2008 - 3) Yet another buzzing, rattling or whinning noise. If you own a Quest van, Maxima, Altima 3.5 and some Z/G/FX vehicles, and get a loud ... Mysterious no-spark situation with a buzzing transmission
Mar 31, 2013
ABS brake fault light on, buzzing sound
Feb 7, 2011
ECU making loud buzzing noise
Oct 6, 2009
Buzzing noise under the hood towards the back of the engine ...
May 8, 2008
More results from forums.nicoclub.com
Buzzing noise at 2000-3000 RPM - Nissan Forums : Nissan Forum
www.nissanclub.com/...nissan-altima.../128490-buzzing-noise-2000-300...
Oct 28, 2003 - 6 posts - ‎3 authors
The "buzzing noise"; I can tell that I am not alone in having this problem but has someone figured out ... I fit does, that eliminates the brake rotors, tires, wheelbearings, CV's etc. ... BUT with an Altima it is probable the pre-cats. Loud humming noise when driving
Aug 29, 2009
Noise when accelerating
Jul 21, 2009
engine noise/whine - 05 3.5SE
Nov 17, 2006
My altima has a humming noise under my hood
Jan 17, 2005
More results from www.nissanclub.com
Jan 05, 2016 | 2000 Nissan Altima
The air conditioner makes a loud sound when the ac trys to kick in. When i put it under fan it works fine and makes no noise.
Sounds like your compressor is seized/stuck and the unit needs a new compressor. If this is the case it should make a loud buzzing noise for a while and then click when it stops trying.
Aug 14, 2011 | Amcor Heating & Cooling
My samsung 42 inch hdtv is making a buzzing noise
First. The whirring or buzzing sound you hear is the Color Wheel and it needs to be replaced. Second, since I do not know when and if the original lamp has been replaced it is a good idea to replaced the lamp. The bad Color Wheel is the one causing the set to shut down.
Apr 04, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
Loud buzzing noise
sounds like a color wheel problem, I can send you a DIY File with pictures if you wish. Contact me at techman32K@ yahoo.com. Good Luck!!
techman
Sep 05, 2009 | Samsung HCM5525W 55" Rear Projection...
Samsung 4663w rear projection tv loud buzzing
Hai,
Buzzing can be caused by a bad ballast, colorwheel, or cooling fan... Nothing else makes a noise, unless it's comming from you speaker.
Hope it Helped U!
Aug 04, 2009 | Samsung Televison & Video
Buzzing plenum heater
is the fan relay going bad it is located normally inside control box behind panel where wiring enters unit
Jan 04, 2009 | Heating & Cooling
Carrier 58GS150-CB ignites but fan will not blow (Loud Buzzing)
The loud buzzing soud i found to be the fan blower motor. I removed the fan bracket assembly and sprayed a little WD-40 on the set screws and protruding shaft so that sqirrel cages could be removed. (Also marked position of set screws on shaft) once squirrel cages were removed I removed 4 motor mounting bolts. Cleaned sqirrel cages and housings with industrial strenghth rim cleaner to remove solid dirt and will replace motor and capacitor.
BTW thanks for nothing
Nov 22, 2008 | Goodman GMS90703BXA Heater
50" Samsung dlp rear projection hdtv
More than likely its the color wheel there is a bulletin from samsung indicating that a loud buzzing is often related to the color wheel.Let me know if you need to know where to get a color wheel and I will post a link, just include your full model number.
Apr 14, 2008 | Televison & Video
Whirlpool GX5FHTXT Bottom Freezer French Door Refrigerator Logo
41 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
