Question about Vivitar ViviCam 3750 Digital Camera
I want to use a sd card and my camera isnt taking it its brand new sd card can you help me its trying to format it but then its saying error
    President:
  • 1,566 Answers
Hello there,
Try to format the memory card first on your computer. And then format it on the camera. Also, you need to make sure that the SD card is not write protected. It means that you should inspect at the side of the memory card for a small switch. You need to move it the other way around.
Posted on Mar 14, 2011
I have a Canon FS200 and a brand new SD 64 GB card. When I try to initialize the card, the camera says, Failed: Process Terminated with Error, but it doesn't tell me what the error is. Can you???
I cannot tell you what the error is, but perhaps I can give you some tips on how to solve the problem. First, try to read the SD card on your computer. Is it formatted? if not, format to FAT 32. Are there any file structures? If so, erase and format the SD card to FAT 32.
If these activities do not work, then try with another SD or SDHC card (type 10 if possible) and see if the error is replicated.
From there, recommend contacting Canon customer support for assistance.
Apr 20, 2015 | Canon FS200 Flash Media Camcorder
I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
Mar 11, 2011 | Kodak EasyShare C330 Digital Camera
I have a polaroid dvf-720 brand new and trying to record and 2mins and it says memory full? i dont understand,and i have a memory card that says card error,need help or im in trouble with the wife!
Ok so I have the same problem I went out and purchased an SD card...but it doesnt work. So I called Polaroid and you need to purchase a CLASS 6 SD card of 2gb or more for it to work properly...figures it does not say that in the manual.
Dec 25, 2010 | Polaroid Cameras
Hi there. i have a canon ixus 30 camera. i brought a brand new 4gb memory card for it. when i put it in the camera it says 'memory card error'. i read somewhere that formatting it helps but when i tried to...
Many people are unaware that the newer SDHC format cannot be used with most older cameras. Your camera was manufactured well before the SDHC format came out. I'm sorry, but there's no way that a 4GB SDHC card will work with your camera, it just doesn't understand the new format of the card. The max size card that you can use with your camera is a standard 2GB SD card. More info may be found at this link.
Nov 18, 2010 | Canon PowerShot SD200 / IXUS 30 Digital...
The screen say's memory card error, card locked, but it is a brand new card. I unlocked it and it still says error
I think you have a HC card, Any SD memory card about 2GB runs at a different compression rate to the 'normal' SD cards. ie High Compression. If you do have a larger card in an older camera it will not read, The camera cannot access the information, and it will not work. If it's a 2GB or smaller, try formatting the card - Go to your review menu, press setup and chose format from the list. This should sort it out.
Jul 25, 2010 | Canon PowerShot SD600 Digital Camera
Error on formating new memory card in camera error says memory card is full brand new card i tried 2 in faact same error kodak c310
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Feb 08, 2010 | Kodak Easyshare C813 Digital Camera
Sandisk micro SD "card error"
The five pics are being stored on the camera's internal memory. The card you used was formatted and used in your phone. It's a miracle it worked at all. You need to get a new card, format it in your new camera have fun.
Dec 28, 2009 | Olympus FE-46 Digital Camera
Was OK, but now memory card requires formatting? Kodak Easy Share C-530. I tried several times to put in new memory card, but it always says it needs reformatting and when i try "continue" it then goes to:...
She is not arguing with the camera. Sheesh. When she says she hits "continue" she is talking about continue for the camera to format the card. But instead of formating the card it says filesystem error e00100. The camera will NOT format the card. I have the same problem. I can format the card on the computer, but again the camera says it can not read the card and needs to format. You choose to format, and it says filesystem error e00100. My card is brand new. So I used cards I have owned for while and used in other cameras. Same thing happens. I tried 4 different cards. A 4gb SDHC, thought that format was not compatible so switched to a regular SD 2gb. Same thing happened. Also tried Standard SD 16mb & 128 mb. All do the same thing.
Jul 21, 2009 | Kodak EasyShare C315 Digital Camera
Format Memory Card Error
The problem with the c350 is that it does not accept a memory card higher than 1GB! I found that out through the Kodak website and not in the User's Guide!
Mar 13, 2008 | Kodak EasyShare C315 Digital Camera
Vivitar ViviCam 3750 Digital Camera Logo
49 people viewed this question
Top Vivitar Cameras Experts
SHARCNET-USA
SHARCNET-USA
James Woodgreaves
James Woodgreaves
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
