Question about iLO IWT3206 TV
Have cable through comcast and cant get picture. i hit a button on remote and lost it
  • 3 Answers
Make sure your tv is on the correct input and/or channel
Posted on Apr 23, 2011
What is the remote code for signature2000
I dont think there is a usable 1 listed in our instructions. So you will need to use the manual search option on your Comcast remote. With the TV on stand close to the TV and hit the TV button then hold the set button until the cable light flashes 3 times...let the button go and type 991 then 1 again now tap the channel up button slowly 1 at a time until the TV shuts off then hit the set button again to lock that code in. If you miss it try the process again.
Aug 21, 2014 | Comcast XFINITY
I have the gray Comcast DVR remote control-it is so unresponsive!
I called Comcast about this today and they had me turn off the TV, unplug the DVR, unplug the coaxle cable, wait a second, rescrew in the coaxle cable, replug in the DVR. It worked! The DVR is snappy like it used to be. Such a relief because it was soooo annoying. Good luck.
Feb 28, 2010 | Televison & Video
I have a 32 inch Haier TV and my comcast cable remote wont work with it. I need to know how to get my tv to sync with my cable remote.
there is an auto search method....some remotes you can hold the tv button down and then the select button simultanteously for a few seconds to make the light turn red and then proceed with codes, when you get the right code you press the select button again, the light blinks and you are done..... well with out a code its the luck of the draw..... the auto search method is similar to programming the code in....hold the tv button and the select button for a couple seconds until the tv button lights up, but instead of a code.....press the channel up button(that represents the first autosearch code), continue until the tv turns itself off and then press the select button to lock it into the remote...........if you go past the trigger point you can channel down to backtrack.... otherwise drop it in the toilet until it wont work, call the cable company and have them send out a tech with anew remote. they cant charge you for their equipment not working correctly.
trust me, i am a supervisor at a major cable company.
Jan 17, 2010 | Haier HTF20R21 20" TV
I have a 42 inch aoc flatscreen hdtv. Every thing was working fine until I hit a wrong button on the remote. Now all I get is a no signal message. I have tried every thing, but I cannot get the picture...
If you're on cable then I would think you are connected via a scart, therefore you need to select use your Input button on the remote or the manual button & scroll through the menu & select the AV source.
Nov 02, 2009 | AOC Envision L32W461 32 in. LCD HDTV
Daewoo DVQ13H1FC No Original Remote, stuck in LINE! Help!!!
It's been years but in case any poor future soul comes across this site, this is a solvable problem, if you have an older gray/silver Comcast remote. Plug the white/yellow front cables into your cable box, then the remote can be programmed using the instructions on the Comcast site for Daewoo, after that you hit the tv/cable button and viola, off line in and on to antenna!!
Oct 18, 2009 | Daewoo DVQ13H1FC 13 in. Combo
Have sound, no picture
After fooling around with all of the buttons, and disconnecting the power to the TV, it occured to me that it may be the Comcast digital cable box. I unplugged the cable box for a few minutes, plugged it back in and the TV works just fine!
Jul 22, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Jumbo Universal Remote
I have a Motorola DVR from Comcast. Code 051 will make all the cable functions work. Haven't figured out how to do anything with the DVR bits,
Dec 26, 2007 | Universal Remote Control NspireGear MP3...
No tv picture
Its possible that you changed the channel or the input line your TV gets the cable signal from. unless you caused more of a problem while trying to fix it, I would suggest you to go through the TV(not cable) channels to see if you can find the one that gives cable picture, or to go through the different input settings(TV/AV on older TV's, and 1, 2, 3 etc on newer ones). one general icon for the later is an arrow going into a circle. I think its the "select" button on your TV remote. Good luck
Mar 29, 2006 | Philips 30PW8402 30" TV
iLO IWT3206 TV Logo
42 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Radames Pagan
Radames Pagan
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
