Question about Denon AVR-1507 Receiver
Denon AVR-1507 speakers don'twork is there something I can reset
    Brigadier General:
  • 8,546 Answers
Yup, don't guess, read. Lots of things to set.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-1507-Receivers-manual/id/696ci071/t/2/
Posted on Mar 15, 2011
Denon avr 1507.recently replaced with new set of speakers.sound got dropped.keeping full volume only i can able to hear something.
Are you using normal impedance speakers? If it worked correctly before, and even better if you can connect the old speakers back to verify the receiver works correctly, would give you a clue.
If the new speakers are a difficult load (below 4 ohms) it may overload the amplifier and it will shutdown to protect itself. You need to provide more info to access correctly.
Removing all speakers and using a headset will also validate the operation of the receiver.
Good luck.
Jan 30, 2015 | Denon AVR-1507 Receiver
THIS IS A PROBLEM FOR AMPLIFIER TRANSISTOR
I'VE seen this error many times, if you need an actual transistor changed, you will want to visit the local electronics repair shop. Many computer shops may also be able to repair your problems. I would recommend that bringing in physically to a shop would be your best choice. The Denon AVR-1507 7.1 is far too expensive to simply replace for a bad set of resistors, transistor, or capacitor, ensure that you realize this is something that some be seen in person to repair.
Jan 12, 2011 | Denon AVR-1507 Receiver
Denon AVR-1507. Worked one night, wouldn't work the next night. Nothing is coming on at all. No known reason just not getting any power. Any ideas on what to check out? Is there a reset button, is there...
This is a common question on this site. Amps of all types have protection circuits to keep them from doing a self meltdown. Testing follows this logic. 1. Remove all speaker wires. 2. Keep the volume down - all the way. 3. Turn the unit on. 4. If it does not trip off, then there is a problem either in a speaker or the wiring. a. Reconnect one at a time until/unless it trips off b. That will tell you where to look further.
If it does trip off, then there is an internal circuit issue in the amp and probably requires professional help to fix.
Dec 08, 2010 | Denon AVR-1507 Receiver
The Denon AVR-1507 switches off and power light blinks red. Its a cool unit and ventilated so no idea what the issue is. This happened when it was off over night. What is the solution. Manual says send to...
Before you send the unit to the service center, check the wiring. Make sure that the speaker wires don't have loose strands that are touching each other or touching the rear panel of the AVR-1507. Check all of the speaker wire connections for loose strands. Since the receiver is minimally used, you could try vacuuming out any dust from the interior of the unit. Note: if the receiver is still under warranty, opening the case to clean it will void your warranty.
If the problem persists, a service center is the best option unless you are very skilled at fixing electronics. Manuals Lib does have a service manual for the AVR-1707, AVR-1507 and other models. However, there is a notation that individual illustrations may not match the receiver being worked on. A Google search can lead you to this manual.
I hope this helps.
(In some environments, electronic equipment can overheat when insects or dust get into the unit.)
Feb 27, 2018 | Denon AVR-1507 Receiver
The left channel on my denon avr-1507 no longer works. The speaker tests out fine. Is there a fuse that can be swapped for this or some other easy fix?
there are no speakers fuses on this model it only shows relays so your probable couse is your left channel went bad specially if you like to play it loud and for long periods of time ( I recomend that you have it repaired by a profesional ) good lock ,, I have the service manual in case you need it
Dec 16, 2009 | Denon AVR-1507 Receiver
No bass from speakers
go in to your settings an adjust the bass volume
Feb 17, 2009 | Denon AVR-1507 Receiver
Denon AVR-1507 No sound on left front channel
Because the sound is only faint says to me that the power amp that controls the left channel is faulty. You need to look at the device(s) on the heatsink and probably replace them.
Dec 28, 2017 | Denon AVR-1507 Receiver
Denon avr 1507 no power
look at power supply and see if blown fuses first and then check for any open resistors.
Sep 14, 2007 | Denon AVR-1507 Receiver
Denon AVR-1507 Receiver Logo
248 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
