Question about Weber Genesis Silver A Premium (LP) Grill
The knob that controls gas flow to the burners was frozen shut. Ordinarily, one has to depress the knob and turn. It was not possible to do either of these. Pushed down hard and turned, and broke valve body (!) Now, I want to know how one can remove the broken valve body. Does it simply unscrew from the manifold, or is it welded to the manifold?
    Brigadier General:
  • 4,736 Answers
According to the Owners Manual, it appears to be welded. In addition, you can't replace just the one valve, it sold as a complete manifold assembly.
Sorry, I wish I had better news. If you'd like to download and print your Owners Manual go to this link.
http://www.weber.com/help/manuals.aspx
Posted on Mar 15, 2011
Pilot light blew out by a fan..I turned the control off..How do I Ignite Please
First locate where to light pilot. You can do this by following thin aluminum colored tubing from control valve to inside heater.In general on top of your gas control valve is a knob. Turn indicator of this knob to pilot and depress knob. This will start gas flow to pilot at end of thin tube. Hold this knob in the depressed position and light pilot. DO NOT release knob for 30 -45 seconds. Then release knob and pilot will remain lit. Then turn knob to on position. If pilot will not stay lit you may need a new thermo coupler, which senses heat from flame to keep pilot gas flow open.
Good luck
Mar 10, 2015 | Heating & Cooling
American range fryer will not light...the knob you turn to light the pilot light will not turn.you can push it in but won't turn.please help
From the Owners' manual:
LIGHTING
1. Before attempting to light this appliance, the door if so equipped, shall be open.
2. Turn the appliance manual gas shut-off valve to the OFF position.
3. Turn the combination gas control knob to the OFF position.
4. Turn the thermostat control to the OFF position.
5. Wait 5 minutes.
6. Turn the appliance manual gas shut-off valve to the ON position.
7. Turn the combination gas control knob to the PILOT position.
8. Light the pilot with a match while depressing and holding the combination gas control knob until the pilot remains
lit upon releasing the gas control knob.
9. Turn the combination gas control knob to the ON position.
10. Turn the thermostat control knob to the desired temperature to turn burners ON.
11. Ensure that the door is closed during operation.
12. For complete shut-down, repeat steps 2, 3, and 4.
It won't turn any further until the pilot is lit and stays lit.
Jun 14, 2014 | Kitchen Appliances - Others
The oven burner will not turn off possible bad control valve
I would not play with gas, get a gas qualified plumber in before it blows up. A single spark can egnite the lot.
Sep 07, 2012 | Kitchen Ranges
Lighting pilot light
Pilot assembly is located inside the bottom compartment, between the the two middle burners while the gas valve is located under the burner manifold. Make sure that the gas line where the unit is connected is open. You need to turn the gas valve knob to "Pilot" position and depress it (to allow the gas to flow on pilot) then light the pilot assembly using a lighter with extended nozzle ( burner igniter). Once the flame is present at the pilot assembly, wait for about 15 seconds (allowing thermopile to heat up) the gradually release the gas valve knob. If the pilot flame is stable, turn the gas valve knob to "ON" position and set the thermostat to desired temperature setting. This will ignite the burners and heat up the oil to set temperature. Just remember, do not do this if there is no oil on fry tank.
Feb 18, 2011 | Pitco Frialator 35CS Deep Fryer
Our weber grill is suddenly getting too hot... even with only 1 of the 3 burners turned on it is over 400 degrees... any ideas?
Sounds like the regulator is not controlling the flow of gas. Try this. 1. Turn gas tank and burner control knobs off. 2. Turn tank valve on VERY slow. 3. Open front burner knob on and lite grill. Wait a minute and turn on addition burners, (if needed).
Apr 27, 2010 | Weber Genesis Silver A Grill
WHEN I SHUT OFF MY BURNERS AFTER THEY HAVE BEEN ON FOR A WHILE, THEY POP.I WOULD LIKE TO STOP THAT IF POSSIBLE. WE USE PROPANE.
EXTINCTION POP
(1) Recognition of Extinction Pop. Sometimes a small explosion of gas in the burner head occurs when the burner is shut off. Under these conditions flashback on extinction has taken place. This problem is commonly called "extinction pop." Extinction pop, as the name implies, creates a noise or a "bang." Ordinarily, it is not followed by burning in the burner head or mixing tube, since the gas supply is turned off. The pop occurs at the time the gas supply to the burner is shut off. Sometimes it may be delayed for a few seconds.
(2) Results of Extinction Pop. Ordinarily, extinction pop is not unsafe or hazardous, and will not damage the appliance. It may result in a customer complaint because of the noise created. However, the resultant concussion may blow out the pilot flame. If an automatic pilot safety device is used, it will act to shut off the gas supply to the appliance.
(3) Correction of Extinction Pop. It may be possible to eliminate extinction pop by reducing primary air supplied to the burner. Make sure this air adjustment does not cause yellow-tipping during normal burner operation. Check proper gas pressure and proper gas orifice size. If these actions fail to correct the problem, burner change may be required.
Sep 08, 2009 | Tappan Kitchen Ranges
My weber gas grill will not heat up past 300F
Hi John,
I just experienced the same exact problem ! I just bought a brand new Weber E-310 a 3 burner grill.
After I seasoned it up with cooking oil,I turned all the burners to high, opened the tank and clicked electrnic button several times , the grill was on then I went inside, I came out about an half-hour later and it was saying around 275 degrees..
I looked into my manual and there is a gas limit control valve that shuts down gas flow, when it thinks there is too much gas flow.
Sloution;
Turn the propane gas knob to off
Turn the gas grill knobs to Off.
Click the igniter several times to clear out any gas.
Then unscrew the regulator from the tank,( I then blew into the tank hole and regulator),
Screw back on the regulator to the propane tank.
I then clicked igniter again couple of times.
Now open your propane tank.
Then turn on front burner while clicking igniter, this will lite 1st burner.
Then turn 2nd burner on low then to high.
And if you have 3rd burner or more, turn low then to high!
John I did this and my grill went to 600 plus in a few minutes!!
The problem was turning the gas grill knobs on first then opening the tank then lighting...
You have to open propane tank with knobs off, THEN AS SOON AS YOU TURN ON 1ST KNOB, YOU MUST IGNITE ...
Mar 21, 2009 | Thermos Stainless Steel Gas Grill
The temp/flame on my weber grill won't get hotter
Check the excess flow safety device, which is part if the barbeque to cylinder connection, may have activated. To reset the excess flow safety device turn all burner control knobs and the cylinder valve off.
Disconnect the regulator from the cylinder. Turn burner control knobs to high. Wait at least 1 minute . Turn burner control knobs OFF. Reconnect the regulator to the cylinder. turn cylinder valve slowly.
Mar 06, 2009 | Weber Spirit? E-310 Propane Grill
Lighting the pilot light
The steps involved can vary slightly depending on your furnace model and pilot valve type, so if possible try and find the instructions inside the furnace door cover or in the instruction manual. This is for a gas fired furnace, but applies to any gas-fueled appliance including water heater. Two of the most common types of pilot valve body assemblies either have a red reset button and a gas valve or no reset button and a valve knob that can be depressed. But whichever type you've got, if you have an older model furnace with a standing pilot (flame is lit all the time) then this is the basic procedure.
  • Turn you thermostat to 80 degrees or to a setting that will demand heat. Make sure the thermostat is in "Heat" mode.
  • Go to the furnace and find the pilot valve. The pilot valve body is a box shaped device into which the main gas line will run and is located near the gas burners. It will usually have a gas **** or valve knob that reads "On, "Pilot" and "Off." Locate this gas **** or knob.
  • Turn the knob or gas **** to the "Off" position and wait about 3 minutes for any residual gas to clear away.
  • Find the pilot. It's located near the gas burner tube assembly in the furnace.
  • Get your match or lighter ready. Sometimes the pilot is hard to reach. If possible, try and use a long fireplace match when you light it. If you don't have a fireplace match then a butane BBQ grill lighter works well too. If you don't have that, then you can fasten a match to the end of a stick when you light the pilot
  • If you have a pilot with a red Reset button, turn the gas valve from "Off," to "Pilot."
  • If you have a pilot with no red button, turn the knob from "Off" to "Pilot."
  • Place the lit match or ignited lighter tip at the pilot and depress and hold the button or depress the knob as appropriate. Depress the button or knob for about 30 seconds. This maintains gas flow to the pilot until the thermocouple gets hot enough to open the main gas valve.
  • Once the pilot stays lit, slowly release the button or knob and turn the gas **** or knob from the "Pilot" position to the "On" position. This will ignite the burners and keep the flow of gas supplied as required for the burners as called for by the thermostat.
  • If the burners fail to ignite then it may be because the thermocouple did not get hot enough to open the gas valve. Wait a few minutes and then repeat the above procedure. This time hold the red reset button or depress the knob for about 45-60 seconds.
  • Once the main furnace burners ignite, adjust the thermostat to the desired setting.
  • If you've followed the previous steps on lighting the pilot and it still does not light after, or will not stay lit, then you probably have a problem with the thermocouple or an adjustment needs to be made to the pilot. You'll need a furnace service technician to replace or repair these parts. You may find that the pilot lights, but it is an anemic looking flame. That's a different problem we'll look at in the next section.
  • If the pilot lights but the flame is a weak yellow flame, it will not get hot enough to heat the thermocouple to its set point allowing the gas valve to open.
    A natural gas flame should be a bright blue with the tip of the flame having just a tinge of yellow. A propane flame should have a bluish green flame with a tinge of yellow at the tip. The flame should be strong enough to hit the thermocouple tip about 1/2 inch from the tip end. If the flame is weak or shaky looking, check to see that a breeze or draft is not blowing on it. Adjusting the Flame
    There is usually a small screw on the pilot valve body that will adjust the flame. You may have to refer to the manufacturer's instructions to find the screw. Turn the screw as needed to adjust the flame throw. Yellow Flame
    A yellow flame is caused by lack of air and incomplete combustion. It can be caused by a dirty pilot tube tip. Split Flame
    This is caused by dirt in the pilot tube. Take a needle or small nail and gently clean the tube. Flickering or Wavering Flame
    A flame that flickers is usually caused by a draft.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 18, 2009 | Water Heaters
Weber Genesis Silver A Premium (LP) Grill Logo
705 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
