Question about Olympus Stylus 850SW Digital Camera
Hi, My Stylus 850 SW door, to where the uploading cord attaches is stuck open. I figure the small latch is bent. What is the easist way to go about getting this problem fixed without costing a fortune. The rest of the camera works great. With the door open it prevents me from being able to submerge the camera. Thanks, Brett
  • Olympus Master
  • 17,129 Answers
This is a tough one as if the camera is opened then the seals are to be reset in proper order. But at the same time the bend latch seems to me as from the inside which might require the camera to be opened out. If by any chance the latch can be straightened using a flat metal against the latch , by applying pressure on it so as to bring the latch to alignment with the port hole , then it can be fixed.
The tip is that since this latch seems to be bend on the inside and so has shifted in a diagonal manner, the door latch must be pulled out with the same angle it had been displaced, Now this is quite technical as the part also is fragile and higher pressure might damage the door or latch.
The final option is to somehow plug using a rubber seal.
Posted on Mar 16, 2011
My front loader washing machine won't open-the lock symbol disappears but despite putting the machine through a variety of cycles I can't unlock it
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique ... to our channels social media as this really helpsmy site and keeps us going. ..... Front Load Washer Door Latch Troubleshooting Replacement ...
How to Open a Washing Machine Door that's Stuck Closed ...
? 1:30
https://www.youtube.com/watch?v=s-_x2tSmd0A
Jun 4, 2010 - Uploaded by eSpares
For all your washing machine spare parts go to http://bit.ly/1828iPF If your washing ... of thumps on the frontpanel next to the lock to see if this shocks it to release. ....impossible for ariston av51 washer, my arm cant go thru it...small space for ... How to open a washing machine door that won't open normally.
How to open a washing machine door that is stuck shut.
www.how-to-repair.com > ... > Door Locks & Switches
Jan 04, 2016 | Beko Washing Machines
My Bosh SHX7ER55UC door won't latch. Trying to figure out the 2-screwdriver method but can't figure out what part to push/pull.
HOW TO FIX YOUR BOSH DISH WASHER DOOR LOCK ...
? 11:11
https://www.youtube.com/watch?v=_uPK5mJmvZM
Jul 23, 2013 - Uploaded by Andrew Wallace
Dishwasher Door Latch (part #W10275768) - How To Replace ...Dishwasher Door Latch Replacement - Bosch DishwasherRepair (part ...
Nov 29, 2015 | Bosch 800 Plus SHX7ER55UC Fully Integrated...
Exterior door stuck closed manually retract ****** remove knobs KWIKSET
You will probably need to replace the latch assembly. There is a small rivet that holds part of the latch together, and it also acts as a pivot point for a small piece that retracts the latch. If it gets bent, the latch won't retract fully, but you might be able to push it back and get the door open.
May 24, 2014 | Kwikset 740ll 3 Smt Lido Keyed Entry Lever...
Oven latch will not open
Sometimes the latch arm is bent causing the latch release not to clear the hook on the door. If the arm goes under the front it is probably bent. Carefully pull the arm back toward the locked position and try to bend it back a small amount and see if the door will open after moving the arm back to the open position. If that fails sometimes you can insert a bent coat hanger between the door and the latch hook and move the latch enough to unlock the door. I hope this helps
Nov 28, 2013 | Ovens
Someone backed into my 1997 volvo 850 and the hood wouldn't open. There was no damage to the hood. Happened again. What is that and how to I open my hood?
IF WORSE GETS TO WORSE I BELIEVE YOU MAY CRAL IN THRU TILTING THE REAR SEATS FORWARD AND CRAWLING IN AND YOULL SEE THE MECHANISIM AND TAKE A SCREW DRIVER AND PRY IT OPEN. THEN ONCE OPEN CHECK FOR ANY MINIMAL DAMAGE OR ANY BENT LATCHES, IF SO CLOSE IT , BUT DONT SHUT IT JUST CHECK WHATS RUBBING AND THE LATCH OPERATION YOU MAY NOT SEE IT BUT SOMETHING IS BENT AND ITS CAUSING TO NOT POP OPEN BY IT SELF. GOOD LUCK
Jan 23, 2010 | 1997 Volvo 850
Door won't close. The door was stuck and now it won't close tight.
If you used force to push it shut when it was stuck open, then you may have bent a hinge. Another possibility is that something fell into the hinge mechanism on one side and is jamming it.
On the other hand, if it was stuck shut, you could have a problem with the door latch.
Aug 28, 2009 | Admiral Dishwashers
05 tacoma tailgate latch stuck
I had the same problem. I figure that dirt/rust may have accumulated inside the latching mechanism. I was able to fix it using the following steps.
1 - Remove the plastic cap that covers the top of the gate.
2 - Remove as many of the remaining torx bolts from the inside cover (you will need to do this to get inside the gate).
3 - Next, try and get some WD40 on/in the latch mechanism.
4 - Using a large screwdriver, you will need to pry the lever attached to the cable in order to release the latch.
Not a pretty process but it seemed to work. I give the latches a good lubrication frequently now, until I get around to replacing them.
Jul 01, 2009 | 2005 Toyota Tacoma
A string from one of the clothes got stuck in the lock mechanism and the door won't unlock
If the door fails to unlock after 11 attempts, you will see the "LO" code. If this was caused by foreign matter infiltrating the latch area try this. Open the dispenser lid and look for a plastic cord tucked away towards the front. It's the same as "weed whacker" cord. Grasp this cord firmly and pull it from right to left (away from the latch). This is the emergency cord to open the door after a latch failure. remove any debris that would hamper the operation of the latch assembly. Close the door and try going into a spin cycle to check the door lock operation.
Apr 29, 2009 | Maytag Neptune Washer
Door wont close
MAKE SURE THE DOOR LATCH IS NOT IN THE LOCK POSITION OPEN DOOR PULL THE INSIDE LATCH TO THE POSITION WHERE YOU WOULD TO OPEN DOOR AND TAKE FINGER AND TRY TO MOVE THE LATCH TO ANOTHER POSITION , HOPEFULLY TO THE POSITION WHERE IT WILL RECEIVE THE STRIKER POST OR THE PART THE DOOR WOULD NORMALLY LATCH ON
Feb 24, 2009 | 1991 Dodge Grand Caravan
Olympus Stylus 850SW Digital Camera Logo
22 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
