Question about Samsung Refrigerators
I have a Samsung side by side fridge. Model no SRS585HDSS. The fridge compartment seems to have stopped refrigerating. I did notice it make louder than normal whirring sounds a couple days prior to it stopping. The evaporator coil fan has stopped running and the freezer side works fine and the fridge coil is cooling but not refrigerating at all, fan has stopped working, am not getting 12v at plug, is there a fuse somewhere?? A wiring diagram and/or a mechanical schematic would be fantastic.
fridgetech
  • 473 Answers
SOURCE: refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Posted on Nov 16, 2007
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
had same exact problem - followed advice for fixing same problem in similar refrig. took of the back panel off the freezer section - 8 hex head screws - and found the cooling fins all frosted over.
Posted on May 31, 2008
Techsim
  • 59 Answers
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
  • 146 Answers
SOURCE: Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Posted on Aug 22, 2009
Testimonial: "Thanks for your help. The control board was faulty. This is what I suspected but I wanted a second opinion before buying the board. "
  • 2180 Answers
SOURCE: Maytag MZD2766GEW side by side refrigerator fridge not cooling
you have a defrost problem, could be bad adaptive defrost board,t-stat heater,when you open freezer door listen for fan if fan is blowing check the t-stat,look at it and see if it has a buldge on it,sometime you can see this and tell it's bad,you'll need a meter to read out the heater and other parts to see whats bad,might be a good idea to call a tech to do this,when you find problem you have to melt everything out again
Posted on Oct 31, 2009
Samsung sr-l3426bs fridge not getting cold
you would need your fridge defrost sensor replace, check for ice build up within the vents of fridge section,
best to a tec to come and replace it for you,you would need the sensor to be reset on your fridge computer board
cheers
Nov 04, 2012 | Frigidaire FRS26R4A Side by Side...
I have a samsung fridge freezer model no RSH1DTMH and the fridge will not go lower than 13degrees and the freezer and water dispenser seem ok. The fridge freezer is only 3 years old. Any ideas/
We had the same fault on our Samsung American style RSH1DBRS fridge freezer as lots of other people seem to be having. After doing lots of research, we found the best solution seemed to be to buy a repair kit from Appliance DIY Repairs. The instructions were fantastic and the installation was a doddle. Excellent service & well priced.
Jan 19, 2011 | Samsung RS2630SH Side by Side Refrigerator
MY GE Refrigerator-Freezer , model TCX20 motor is humming!!!
There may be a build up of ice in the freezer compartment and ice touching the fanblade. The unit needs to be defrosted.
Nov 06, 2009 | Samsung RS2630WW Side by Side Refrigerator
Samsung side-by-side fridge freezer model RS21DCSV. Freezer is fine. Temperature keeps changing in fridge varying from 5-14 degrees and water has stopped coming out of dispenser. Have checked and...
these side by sides use an auger motor in the fridge to open and close according to the temp demand. If its eratic, either the auger is icing up at the outlet possibly due to product being to close to the outlet. On occation i have had to replace them due to being faulty.(to check, adjust the temp. and notice if there is any change on the auger.)
Sep 17, 2009 | Samsung RS2556 Side by Side Refrigerator
Warm refrigerator compartment
There is a fan that blows the cold air down from the freezer to the fridge compartment. It is usually called a freezer fan. Most of them are behind the plastic lining in the freezer. I just noticed that your fridge is a side by side. I have never wored on a side by side but I imagine there is fan in them as well.
Jul 06, 2009 | GE GSH25KGRWW Side by Side Refrigerator
Maytag side by side fridge makes vibration noise
Mine is a different model, and less than three years old, but the vibrating noise was really annoying. I would shift the unit or the door slightly, and it would stop for a while, as you reported. I took a few minutes, applied pressure to different areas, up and down, inside and out. The noise was louder near the floor. I removed the plastic grill and applied upward pressure on the wires covering the coils - it was loose. I noticed an accumulation of dust, and vacuumed as far as I could reach around the underneath area; also pulled fridge out and vacuumed a dust-covered vent on the back near the floor. Was planning to insert some kind of wedge under the loose part, but when I put everything back in place, the vibration stopped - now I only hear a gentle hum. Seems I did something right in this process.
Apr 13, 2009 | Maytag MSD2756G Side by Side Refrigerator
FRIDGE NOT WORKING
Most side by side and other models of refrigerator freezer combinations are of one basic design. The freezer section does the cooling for both compartments. The refrigerator section gets it cold air from the freezer compartment. Therefore check for frost on the back wall of the freezer compartment. If frost is present there you have a defrost problem and it is cutting off the air that cools the refrigerator section.
I think this problem may already be resolved in some manor because of the date of post. Posts should expire after an unreasonable time period.
Mar 19, 2008 | Smeg FA561X Side by Side Refrigerator
SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor
Check fan motor for continity IF none replace fan motor
Oct 12, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
82 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
