Question about American Standard Kitchen Faucet Colony Soft 4275.551 099 Polished Brass Tw...
Restricted flow and noisy diverter valve. How do you remove the spout to get at diverter valve?
  • 528 Answers
Just in case try taking the aerator off and try the faucet.
Posted on Mar 14, 2011
Tub spout diverter
Check the basement. There may be a valve (two valves) that someone partially closed in the past to limit how much water was used for a bath.
Dec 21, 2013 | Plumbing
What to do if i can't stop the water flowing from the shower spout and there's little water pressure coming from the shower head and a hand held shower?
One rule I live by: more parts, more problems. Sounds to me that the plumbing/valves were not insalled properly. If you hired a profesional plumber, have them fix it. I am a licensed profesional plumber and I offer a 1 year warranty on all my work. If the contractor did the work and does not hold a plumbing license, that person is still responsible and may have to suffer legal consequenses.
Sep 10, 2013 | Latoscana TC3TPW690 Water Harmony...
Kitchen fawcett spray nozzle has low flow, however pressure appears
You need to replace the spray diverter valve. It is located on the main body, below the spout, in the sleeve at the base of the spout. The main pivotint sleeve of the spigot. The valve is usually in the rear.
Dec 16, 2012 | Price Pfister Plumbing
Why does the water not flow from shower valve when turned on?
Do you have water coming out of the tub spout and not the shower head? If so how does the water get directed to the shower head,is it by pulling up the diverter on the tub spout?If water is still coming out of the tub spout then the diverter is bad and the tub spout needs to be replaced.
May 09, 2012 | Danze & Single Handle Tub And Shower...
Water comes out of kitchen tap then slows down to nothing at all comin out
If the aerator is clear of debris, there is a valve of sorts in the center of the faucet that diverts water to a spray nozzle (the sprayer on a hose that would be next to the faucet). Even if you don't have the sprayer, most all kitchen faucets have this diverter valve. It's a bit like the thing (in a bathtub/shower combination) that switches the flow from the tub spout to the shower head.
Sometimes, something will work its way into the diverter so that it stops the flow to the tap. It could be a piece of debris (mineral flake, rust flake, etc.) that can be backflushed out. This would require removing the faucet and removing the main valve assembly. Long story short, think about replacing the faucet if the diverter valve is acting up.
Mar 12, 2011 | Washing Machines
Single lever with pull out accessory sprayer. Too little flow from the main spout. The pull out sprayer has more pressure than the main spout. I suspect the diverter valve is the trouble. What is the...
The Diverters Parts is C7005. Here's the parts breakdown for your Rohl faucet. Contact Rohl and have them send you new diveter for free, the A3608 seriers came with a limited liftime warranty.
Sep 17, 2010 | Rohl A3608/11LMAPC Single Lever Country...
Hello. We have a Moen two handle tub/shower faucet. A little over a year ago it started to make a high pitched noise when on. Now the water flow to both the tub and shower are greatly reduced for BOTH...
sounds like the diverter inside the valve body is cloged with debris.
only wat to remedy this is to remove the valve and clean out the diverter, or just replace the valve.
Aug 05, 2010 | Moen 2919 Chateau Two Handle Tub and...
Water quits flowing
There is a little popper in the spout area. You need to remove the top handle and slide the spout off. The popper is in the main tube coming up. It.s a standard part at most big box hardware stores and it costs less than $10.
May 19, 2010 | Delta 2402 Classic Single Handle Kitchen...
Diverter valve does not work correctly.
the connections are reversed,just change them over and this will fix the problem.
Feb 18, 2009 | Grohe Eurosmart, 3-hole Roman Tub Filler...
American Standard Kitchen Faucet Colony Soft 4275.551 099 Polished Brass Tw... Logo
270 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
