Question about Element Electronics ELDTW401 TV
Only showing on 480i even with hdmi cables on my element 55"
  • Element Elec... Master
  • 8,457 Answers
Not the problems with a HDMI cable.U getting only 480i because the tv station u are watching are broadcasting tv signal are in 480i only.Tries difference channels like 2 CBS or 4 NBC alway broadcasting in 1080i.See,u will getting 1080i.Ur tv good,it doesn't have any problems.
Posted on Mar 14, 2011
I have a 47" Visio 1080p. Tv is always set at hdmi
AV inputs are for standard analog video which is 480i. HDMI and Component inputs are the high definition inputs that run at either 1080i or 1080p You won't ever get 1080i or p through AV inputs.
Oct 22, 2012 | Televison & Video
How can I switch my screen resolution on the Pioneer PDP-4270 from 480i to 720i or 1080i? HDMI cable is connected appropriately. I have tried new HDMI cables, and pressing reset to factory settings along...
Change the resolution on the cable box or satellite box, witch ever you have. A set by itself cannot change the resolution, if the cable is giving you 720p, that's what you'll see for that station. All stations do not transmit in HD. The best picture is only as good as they're giving you.
Dec 19, 2010 | Pioneer PDP-4270HD 42 in. Plasma...
I have a 720p tv but when i press info it says its showing the cable in 480i. Will a HDMI cable fix this?
It's not a cable problem, it's the channel that it's broadcasting this way. You can't change that  - only the channels that are clearly labelled HD have the image resolution that you want.
Aug 24, 2010 | Televison & Video
I have an RCA D52W20 that I connected to my PS3 with an HDMI/DVI Cable. The display is fine in 480i. However, No sound is coming from the TV.
This is normal my friend. A dvi port can't use audio even if it is using a hdmi cable. A easy fix is to connect your A/V cable into your ps3 and connect the red and white cables next to your dvi cable or connect it to your stereo. After that go into your setting, go to audio setting, click on audio output, and select A/V cable. it should work after that.
Mar 26, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Mitsubishi 55 in. 1080 series
If I remember correctly, this TV has a couple of constraints that will cramp your style:
1. It supports 480i, 480p and 1080i. NO 720P
2. It has component video inputs, but NO HDMI. (as you stated)
There is no easy solution here, because I've never found an upconverting DVD player that would upconvert anything past 480p using the analog component outputs...
So..
Perhaps you can find an Upconverting BLU-RAY disk player that may allow older DVDs to be upconverted to 1080i via the component outputs.
MOST Blu-Ray players allow 1080i output via the analog connections on Blu-Ray discs, so perhaps there is your solution.
Mar 09, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Ps3 hdmi cable with adapterto tv's rca's
Just use the regular AV cords. They are 480i using an HDMI to this and that isn't going to improve picture quality.
Mar 01, 2009 | Sony Playstation 3 (PS3) Console
Convert 480i to 720p
Turn off cable box.
Turn on TV.
Hold down media and guide for a few seconds.
On TV pick the resolution you want. Your choices are 480i, 480p, 720p, some wide screen resolutions and 1080i.
Save the results.
You should be good to go.
Jan 25, 2009 | Philips Magnavox Learning Universal Remote
Phillips hdtv
to switch that you need rca 3 color red, blue, green to view
more that 480i , or HDMI conection
Jan 20, 2008 | Philips 55PW9363 55" Rear Projection...
Element Electronics ELDTW401 TV Logo
386 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
