Question about Philips Cameras
Where can i buy a switching adapter for our philips 10 in. digital frame? model DSA 12 PFA-05 FUS 050200 input 100-240 V output +5V
If you mean a switching adapter for your phillips 10 in. radio shack has an adapter set with multiple plugs and voltage and amps here is a link to one on amazon http://www.amazon.com/5V-1-2A-Universal-Power-Supply/dp/B001KU44HE that looking up your model should work. also walmart and best buy carry adapters with multiple plugs as well hope this helps let me know
Posted on Mar 14, 2011
Looking for a new plug for a digital photo frame
All you need is an adapter with the following Specifications Output( DC V/A ) :5V 2A Max Power Output(W) :10W Input : 100 AC - 240 AC (50/60HZ, for example this one, copy and paste the whole link into your browser http://www.ebay.co.uk/itm/like/331238268334?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=108&chn=ps&device=c&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0-L&ff12=67&ff13=80&ff14=108&ff19=0
Dec 03, 2014 | PANDIGITAL 7" Digital Photo Frame With...
What do they mean the input voltage range between the wall outlet and this adapter is ac 100v-240v, and the adapter's output voltage is DC 5V,2A
A lot of new computer hardware will accept regular 110-115v like most people have in their homes (USA) or high voltage 220 (mostly used for washer / dryers) or industrial use. Like in a factory. This unit accept both without worries of over loading. Some may even have a switch to swap back and forth. It actually only uses 5v and 2amps. Meaning a single 110-115 power strip can handle many plugs, because of the low voltage.
Aug 28, 2012 | ASUS Google Nexus 7 16GB Tablet 71B16
I just got a multimedia surround system with subwoofer.Spa7650/05, 180w.The subwoofer has three audio connections,front,centre and rear,My tv only has an audio coaxial.I can't connect it.What adapter...
Firs of all lets get agree on something..The subwoofer has three audio connections for "output " to :front,centre and rear speakers...these are not for "input"..Your powered SUB provides necessary signal for other spekers..
You can connect TV audio coaxial to SUB input with a RCA cable.....if your SUB does not have "RCA input " probably it should have "3,5mm Haedphone female Jack"..
if this is the case you need to buy a cable ; one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 22, 2011 | Philips Audio Players & Recorders
How do i charge it
Refer to page 12 of your User Manual.
http://download.p4c.philips.com/files/s/sa3346_37/sa3346_37_dfu_aen.pdf
Connect to your PC with the supplied USB cable and it will charge via the PC USB port.
Dec 29, 2010 | Philips GoGear Flash MP3 Player
I need pinout assignments for a Philips 5.1 Home Theater Speaker system (PWR2006-37)? It has a DB-15 style input connector that hooks to the output of a Philips dvd / amp / control unit. this was...
Pin assignment is as follows (not sure of levels required- preamplification / attenuation may be necessary:
1: Control 0/5V.
2: Unused
3: Unused
4. Center speaker in
5. Ground
6. Ground
7. Subwoofer in
8. Ground
9. Unused
10. Ground
11. Left Front speaker in
12. Right Front speaker in
13. Ground
14. Right surround (rear) in
15. Left surround (rear) in
Jul 10, 2010 | Philips DVP642 DVD Player
I have a smartlink ESK-108 with no power supply can you tell me what voltage is required thanks?
AC/DC power adapter transformer
AD-051A 120v 13W input AC, 5v 1A output
or
JOD-41U-27 120v 100mA input AC, 5v 1A output
I have the latter and it works.
Apr 12, 2009 | Archtek America ESK-108 8x10/100 Mbps...
Need to know power requirements for the kensington k33141 usb hub
hello,
i believe i know the answer. i have the kensington pocket hub se 2.0 model: k33141. it seemed to work with the adapter i found in our closet. it is a dve Model : dsa-0131f-05 us 13 and it outputs 5v 2.5a. the adapter has a thin profiile like it would be plugged into a strip. and it has an rf blocker which suggests computer equipment.
Apr 05, 2009 | Kensington (1500100) Networking Hub
What kind of charger does a shoqbox need?
It needs a Philips AC adapter Model: AY3197/00
Spec:
Input: 100-240V 50/60 Hz
Output: 5V--2A
Apr 04, 2009 | Philips ShoqBox PSS120 MP3 Player
DC Power supply specifications
here is the info you need...
Input Power 100~240V, 50~60Hz
9V DC,1A Max
Hope this helps...
Feb 09, 2008 | Computers & Internet
Cameras Logo
280 people viewed this question
Top Philips Cameras Experts
Lyle Siemens
Lyle Siemens
Are you a Philips Camera Expert? Answer questions, earn points and help others
