Question about GPS
Morning, Re: NavMan Trackfish 6600 Sounder - GPS Combo. This unit is only used when I take my annual holiday to the Northern Territory in Aust, each year and would have been used approx 20 weeks in total since 2006.Initially, after 1st boot up of the day, the unit works fine. until. it is exposed to the tropical heat after 15-20 minutes. The unit then regularly either: freezes, requiring power to be turned off-on at the main power switch and re-booted or will drop out and return to the home, acceptance screen. Can you please help. Rgds - Phil Drummond
4 Suggested Answers
my navman trackfish 6600 gps is aquireing and will not give a gps fix ,I have also had the screen ghosting when I enlarge the area with no detail, the unit is 4 years old .
Posted on Sep 05, 2010
SOURCE: Navman 5500 tracker
Navman 5500 does not support C-MAP MAX maps.. only C-MAP NT+ maps.
Posted on May 02, 2008
  • 1156 Answers
SOURCE: Screen is set to 15 Problem
Usually blackening of a part of screen is most probably due to faulty LCD screen.
he Display of a GPS Consists of (2) Separate Devices that Work Together.
# The Liquid Crystal Display (LCD)
# The Touchscreen with Glass
The touchscreen consists of several transparent layers with spacers that are applied with an adhesive to a thin pane of glass. The touchscreen & glass lies on top of the LCD display. The touchscreen & LCD display both have their own flex cables that connect to the main board.
The touch screen has a ribbon flex cable with 4 or more conductors, each conductor representing a direction such as:
1. X-Coordinate, Left
2. X-Coordinate, Right
3. Y-Coordinate, Up
4. Y-Coordinate, Down
Most GPS units use a resistive, analog touchscreen. A voltage is applied to the touchscreen and by pressing anywhere on the touchscreen, it acts like a voltage divider, returning a specific voltage value, based upon the location touched on the screen. The GPS is programmed to read this voltage and it translates it back to a specific position on the screen, which may or may not activate a function.
The touchscreen doesn't have to sit directly on top of the display. If you were able to set it beside the display, you could still press the touchscreen and activate a function. The LCD display has no idea where the touchscreen is mounted, all it is concerned about, is what area is being pressed and whether or not that location matches a particular function on the LCD display menu.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Hope you have the manual..If not, please feel free to download from the below link:
Posted on Jun 17, 2011
Uniden um425 vhf to navman trackfish 6600 what coloured wires do I connect.
Hi Gil!
Easy peasy.
From your 6600, the data sends are the white wire NMEA (+) and the black wire (-). There are two black wires. Doesn't matter which one you use as they're interconnected anyway.
To your UM425, the green wire is NMEA in and the bare wire is ground.
white from 6600 to green and
black from 6600 to bare.
Hope this helps you out.
Jan 09, 2015 | Uniden Boating
Trackfish 6600 stops and starts again by himself many times in a few minutes; first screen map thouthand miles away from real boat position !
Try a factory reset - that worked for me when my Northstar Explorer 660 stopped by itself again and again. You find this reset commando by pressing MENU twice and then under Systems menu, if I remember it correctly. There is also a RAM Clear commando. This is done by holding the MENU button pressed when the GPS is switched off. Keep it pressed while switchin on the GPS, still holding the button pressed until the RAM Clear menu appears. You will probably loose all waypoints etc. by doing this so try Factory Reset as your first alternative. Good Luck! // Jonas, Sweden
May 12, 2011 | Northstar Explorer 660...
Trackfish 6600 will not receive satalite and
moisture and oxidation, neither work well with any electronic devices . many can never be repaired to work due to this .
Sep 14, 2017 | Navman Trackfish 6600 GPS Receiver
When we zoom in we dont see depth i certain areas; but only grey colour. What are we doing wrong?
The image on my fish finder has a ghost like worm going across the screen. It doesn't read structure at all but will give you the depth. The arrow is pointing forward and I was told to point it in. I would think it would at least still have a picture when the boat is stopped. Any advice?
Jul 07, 2009 | Navman Trackfish 6600 GPS Receiver
No gps fix NavMan trackfish 6500
May 09, 2009 | Navman Trackfish 6600 GPS Receiver
I need a manual for Navman trackfish 6600
I need a manual for a Navman Trackfish 6600. Can i download it or where can i purchase it from?-
Dec 30, 2008 | Northstar Explorer 660...
Missing the target.
I had the same probelm.
Check that you are using the right time zone in your settings particulary if there is daylight savings adjust your time zone accordingly in your settings
Aug 19, 2008 | Navman Trackfish 6600 GPS Receiver
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
