Question about Electric Mobility 3 Wheel Motorized Electric Wheelchair Scooter Cart
3-wheel go go scooter, on a full charged battery, [batteries have been checked], scooter goes fine for my approx. quarter mile destination, then on my return trip home begins to slow way down to almost a crawl a short distance before I get home. It will fully charge again on the charger in about one hour. Batteries were checked and appeared O.K. at battery exchange where purchased approximatly seven months ago.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 140 Answers
I would say that both the batteries are not holding a full charge ....I had one in the past for my mother and if it was not chraged on a regular basis the batteries would die out ....the cheapest and easiest route here is to try new batteries.
Posted on Mar 14, 2011
I have a golden companion II 3 wheel scooter with new batteries, the problem isafter a complete charge the scooter starts off fine but gradually loses power as indicated by meter in 5 to 10 minutes. A
hi ,there are two parts to batteries holding power and preforming well, firstly how good are the batteries, secondly how good is the charger ?, good batteries and a bad charger will make the batteries appear bad...
Regards
Rob
www.gewizrepairs.co.uk
Feb 22, 2014 | Golden Technologies Golden CompanioN II -...
Battery won't hold charge
hi, have you tried another charger ? a bad charger will make the batteries appear bad
Regards
Rob
Jan 14, 2014 | ActiveCare Medical ActiveCare Osprey 4410...
Mercury prism mobility scooter
The distance a scooter will go depends on the size and weight of the load also. If two people are different height ( wind drag ) and different weight or there is a difference in load you are carrying then there will be a difference in how long the charge will last. Since you switched the batteries with no change then this could be the case. There are other factors that can cause this as well , such as brake dragging, wheel bearings going out, low tire pressure if your tires are air, if 4 wheel scoters then wheel alignment. hope that helps.
Jun 06, 2013 | Health & Beauty
I have a Pride legend three wheeler- I replace the battery charger because it would not charge the batteries. I pluged the new charger into the control module it will charge the batteries. Batteries are...
if I understanding this correctly , you cannot use the scooter why it is being charged, there is a inhibit pin that stops the scooter from being used,
All scooters are designed this way.
Regards
Dec 14, 2012 | Pride New Mobility Legend 4 Wheel Scooter
Victory 4 pride mobilty scooter,the charger dont seem to charge up the batterys. is the charger faulty.
DID YOU HAVE THE MANUAL? YOU CAN FIND THE RIGHT WAY TO CHARGE IF IT DO NOT CHARGE AT ALL MAY BE BATTERY IS BAD OR IF IT DO NOT CHARGER NOTHING PROBABLY THE PROBLEM IS THE ADAPTER, TRY TEST IT USING VOLTMETER OR POWER TESTER.
CLICK HERE MANUAL
Aug 27, 2012 | Pride Go Go Ultra 4 Wheel Travel Scooter
Batteries are fully charged. Scooter goes at full speed for approx. 1 block, then will slow to 1/2 speed and back up to full then back to 1/2. We have new batteries, checked for voltage at end of run, one...
Based on your description you have a bad throttle potentiometer or speed potentiometer. Remove the covers of the front console and check the resistance throughout the range of both pots at the connector. It should be even throughout the range with no dead spots. The newer CTE throttle pot is more reliable than the older model Celebrity scooter with the 5K ohm potentiometer. I usually replace the throttle and speed pots as a pair since they are connected electrically in the console.
Load test the batteries while you are driving. Using your voltmeter that is still connected under the rear cover while you are driving, check to see if you get a voltage drop of more than 1 volt. Static testing of batteries only tells you that there is a full charge. It does not give you an indication of how the batteries perform under load.
If you have clean brushes, you can still have a large amount of conductive brush dust in the motor and armature. Blow out the dust with compressed air. Check the motor and brake with you meter. The motor coil resistance should be less than 1.5 ohms and the brake should read between 40 to 60 ohms. Hope this helps.
Jan 05, 2011 | Pride Mobility Products Celebrity X - 3...
Shoprider cadiz scooter, batteries show full charge when first charged up but when driving scooter battery power runs out after about 3 miles. brakes work fine, no noises from motor or gearbox, what's...
I think your batteries haven`t been charged properly,or they have been left standing so the charge has leaked out.At a minimum your batteries need to be charged for 12 hrs a day for the first month if not they will not build the capacity and will dwindle and die for example it is at only 25% capacity,but looks like a fullcharge, it says it fully charged but will die
quickly this happens because it is charged to its full capacity but that is only 25% of the batteries true potential
resulting in short battery life.
Unfortunately majority of scooter batteries like this have to be newly replaced.
Nov 06, 2009 | Health & Beauty
Battery power on mobility scooter
Most scooters show a drop on the battery level meter when in use, as long as it is`nt slowing down it should`nt be a prob. I mean,when you engage the throttle you ARE putting a load on the batteries,so it`s only par for the course that the indicator would drop a bit.
Jan 04, 2009 | Pride Mobility Products Pride Mobility...
Electric scooter Troubleshooting
A small tip here - bigger is better. The large diameter wheels clear gaps in concrete or pavement that would hang up a skate wheel or a scooter with smaller wheels. Most electric scooters also handle well in gravel and small terrain features. We don't recommend slamming electric scooters into a curb to get over it like some people do with their bike. This could result in damage to the electric scooter. Simply Ollie up a curb and keep going.
Aug 27, 2008 | Drive Medical Mini Phantom Three Wheel...
Electric Mobility 3 Wheel Motorized Electric Wheelchair Scooter Cart Logo
210 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
