Question about Hitachi Televison & Video
Hitachi 53UWX10BA convergence problems error code 4
  • nannygal Aug 02, 2008
    I know I sound stupid... but what did that mean in English? what is "conv ICs" and "DK on Hit"? Thank you so much for your help... but haveNO clue what you just said... again... thank you in advance!!
    Thank you for your reply! Since I do not have a soldering iron... I guess I will have to call a repairman to come to the house... but you really did help! At least I know its not something I can perxonally do!
    God Bless,
    V
    Scholar:
  • 90 Answers
Replace the conv ICs. Sometimes it's just the soldering involved, DK on Hit. But bottom line it's usually the conv ICs. They work very hard in there.
Mr Bob
www.imageperfection.com
510-278-4247
Posted on Aug 01, 2008
  • Robert Jones
    Robert Jones Aug 02, 2008
    conv ICs means convergence ICs. They are the workhorses of the convergence circuit. If you want coaching on how to do that, I am available for phone coaching/consultation.
    DK on Hit means I Don't Know on Hitachi, as to whether they have problems that can be remedied fairly directly via resoldering of their legs at the pads in the boards they are mounted on, like is very prevalently the issue on lots of Mitsubishis. Also as to what exact ICs are used.
    Mr Bob
How do i get my hitachi 53uwx10ba into convergence mode?
This should be a menu option in the video portion or initial set up area of your menu. If you have auto converge it will do it for you otherwise it will put up a screen with color patterns for you to manually converge.
Sep 28, 2012 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi Mo# 53uwx10ba double image
Needs convergence IC's
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Please rate accordingly
Thank you
Computerrep
Apr 04, 2008 | Hitachi 53UDX10B 53" Rear Projection...
I have a Hitachi 53UWX10BA tv. The picture colors are off and blurry. I ran magic focus and it showed a 4 on the bottom of the screen
Ur tv have a problems known as a convergence problems,it dead.Tv have corlors R,G,B lines mis alignments,have colors shadows picture or 3D picture look alike?Yes.The tv convergence board is dead.The convergence board must change 2 STK convergence ICS and some or all of it resistors to fix the convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Feb 28, 2011 | Hitachi Televison & Video
Double image after magic focus with a number 4
Replace Both Of your convergence ICs STK392-110 they are big black IC will have part# on them Call Mats for parts 1-800-628-1118
Sep 25, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53UWX10BA HDTV with convergence problem for blue
No there are no quick fix options for this fault. The convergence amplifiers operate similar to a high power audio amplifier, so if there is an impairment anywhere in the system, it will result in distorted audio, or in the case of television convergence amplifiers, a color won't align. The convergence power pacs need to be replaced and the out of tolerance precision resistors located near the power pacs need to be carefully checked and replaced as necessary.
It is also possible that there are root faults that cause the amplifiers to go bad which include bad connections or a bad digital control module. This repair is possible for anyone having basic electronics knowledge and soldering skills.
Apr 28, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53uwx10ba turns on & off when off red flashing light/clic
Same problem. Replaced both convergence ICs about 5 months ago. Worked fince since then and just recently no sound, no video, blinking red on front panel and clicking sound. I suspect that the ICs went bad again and blew a resistor or two. I used cheap Chinese ICs instead of the Sanyo ones and thing this is why. I'll be looking at it again and post solution.
Jan 21, 2009 | Hitachi 50SBX78B 50" Rear Projection...
PROJECTION TV HITACHI ULTRAVISION COLOR CONVERGENCE PROBLEM
it sounds like your blue convergence ic is getting weak you need to replace the ic's STK392-110 and you should replace both because when 1 is bad the other will go real soon. They are inexspensive at the sight I posted and you will also get free tech online support if you purchase them there.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Green lines along top of Hitachi 53UWX10BA
convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Jan 02, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
  • Screen looks 3D
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Dec 03, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Problem in Hitachi 53UWX10BA
The convergence ic's, and related components that could'be affected need to be replaced cost to repair 250.00 2hrs job max with alignment this depending on the tech. If you need more help let me know
Jun 14, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Televison & Video Logo
286 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
