Question about Kitchen Ranges
Where are the bottom elements located on a kenmore electric stove c880 type 30s..
  • 33 Answers
They are under the oven cavity. The Built in elements are considered a deluxe feature. In case it needs to be changed depending of the manufacturer ( Kenmore is only a name and many suppliers build product that are rebranded Kenmore ) the element is accessible through the right or left side. In case it needs to be changed you can remove the side panel and slide the baking element out to change itr
Posted on Mar 14, 2011
Kenmore oven C880 676239J2 is not heating up... is the only fuse the one located under the light on top of the control panel?
I doubt that fuse is used for the heating element. If you can unplug the element in the oven, an ohmmeter should show you if it has opened up (burned out) on you. Turn off the 220 breaker in the breaker box before doing this even though there should be no voltage with the controls turned off. (There usually will still be 110 to the top of the unit.)
Jun 05, 2017 | Kenmore Microwave Ovens
MOD# C880-6402990 ser IMF0216838 Type 30S My issue is I had my microwave plugged into the extra outlet. I turned on the microwave and then it seems like it tripped something in the stove.
Check the circuit breaker for the house. It might be tripped. Sometimes a breaker will trip without moving the handle to indicate a trip. Reset the breaker several times.
May 15, 2017 | The Kitchen Appliances - Others
I have kenmore c880 model stove , both oven and stove are not heating up after shifting to new house...any tips to get it resolved? Only oven light is working.
Make sure there is 220 volts at the wall socket where you plug the oven into. A faulty circuit breaker in the power panel on your house will only let 110 volts get to the oven so the lights and timers will work but not the heating elements.
Sep 09, 2016 | Kenmore Ovens
How do I change a burner on a smooth top stove?
usually the top will tilt back so you can get to the elements .
Apr 09, 2016 | Kenmore Kitchen Ranges
How to replace switch for 8" element in Kenmore electric stove model c880 6373190
Stove Surface Element Control Switch Replacement ...
? 3:09
www.youtube.com/watch?v=UPC1YgOi2cM
Nov 14, 2013 - Uploaded by RepairClinic.com
This video provides step-by-step repair instructions for replacingthe surface element control switch on a ..
Oct 30, 2015 | Kenmore Kitchen Ranges
Where are the fuses for the Sears Kenmore stove to elements located on Model C880 675080L0
Most likely no fuses. Either the element or the switch that turns it on is bad. If lighat comes on when you turn on burner the switch is probably ok and the burner went bad.
Jan 02, 2015 | Kenmore Sears Electric Range Surface...
Have a Kenmore electric range. A model C880 sold by Sears Canada. One of the "element on" indicator lights stay on even though the elements are not switched on.
This is usually the infinite switch has failed. They are easy to check and inexpensive. Here is a video that will walk you thru testing an infinite switch. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
Oct 23, 2010 | Kenmore Kitchen Ranges
We have a Kenmore (whirlpool ?) mod#C880 63981961
The temp sensor comes out of the back wall of the oven looks kinda like a chrome rod protruding from the wall towards the top can be on either side but usually left side. if you have an ohm meter you can check it.It should ohm around 1075 at room temp.
Sep 20, 2009 | Kitchen Ranges
Kitchen Ranges Logo
448 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
