According to the manual for this specific unit, the steps to set the clock are as follows (with minor editing for clarity): 1 Press SOURCE and hold until the unit turns off. 2 Press the MULTI-CONTROL and hold until CLOCK SET appears in the display. 3 Use the MULTI-CONTROL to select CLOCK SET in the initial setting menu. 4 Press MULTI-CONTROL to display the setting mode. 5 Press MULTI-CONTROL to select the segment of the clock display you wish to set. Each time you press MULTI-CONTROL, one segment of the clock display is selected. As you select segments of the clock display, the selected segment blinks. 6 Turn the MULTI-CONTROL to set the clock. You can also perform the same operations by
MULTI-CONTROL Being the round knob on the radio.
pushing MULTI-CONTROL up or down.
I couldn't figure out how to change the time zone because I didn't have the manual. Here's how to change time zone:
1. On top of clock you hold down time zone button
2. Push the up or down button to change the time zone. There are 7 time zones. The clock is set at zone 2 -Eastern Standard time. My zone is 3 -Central Time - I then had to manually set the correct time -(I'm not sure why but I did that) To test if the time zone worked properly I switched the time zones and the time on the clock adjusted automatically to the associated time for that area. I, of course, moved it back to zone 3 and the correct time for central time was displayed. I am waiting to see if the time properly adjust when time the DST changes. Also, for the manual: http://www.emersonradio.com/owner_manuals_list.php?ID=157
This is the manufacturers website (Emerson) for the EZ Set clock radio. Hope this helps.
